lumbee Samba Member
Joined: June 15, 2012 Posts: 180 Location: Asheville, NC
Posted: Wed Jun 22, 2016 10:18 am Post subject: Engine removal on 56 Oval |
Hey folks! I have a 56 Beetle and am trying to remove the engine on my 56 oval. My question is about the two bottom bolts. I have found what I think is the bolts, but not sure how to get at them. See the pic attached. Note the bolt the arrow is pointing too, but also note the surrounding brackets. Can I remove that bracket, or is this not even the correct bolt. Any help appreciated.
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Wed Jun 22, 2016 10:57 am Post subject: Re: Engine removal on 56 Oval |
Should have a 17mm head and take a 17mm socket or box wrench like the top two nuts.
txoval Samba Member
Joined: January 23, 2004 Posts: 3557 Location: The Woodlands, TX
Posted: Wed Jun 22, 2016 11:00 am Post subject: Re: Engine removal on 56 Oval |
That's it, 17mm socket and long extension or socket with universal or use a 17mm wrench
Lay down beneath there and attack from the bottom...I've never had an issue removing it |
lumbee Samba Member
Posted: Wed Jun 22, 2016 1:46 pm Post subject: Re: Engine removal on 56 Oval |
Thanks all for the quick replies. I will take another stab at it. Seemed way to tight for both a box end wrench, and a socket. |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Wed Jun 22, 2016 1:53 pm Post subject: Re: Engine removal on 56 Oval |
... if that was mine, I'd jack up the ass and rest the rear wheels on car ramps or jack stands under the frame. Then, shimmy under there, on my back with a 17 mm wrench, a drop light and a small putty knife. Set up the light and use the putty knife to scrape all the crud from around that 17 mm nut... then loosen the nut and remove it... do both sides... the 17 mm nut is on a stud... the top ones are a 17 mm nut on a bolt.
I'd clean it up under there, once the engine is out, from top to bottom.
Another thing I do to all my type ones, I neatly cut an access, like all splits had to 9/52, to gain easy access to that trans area...
... do all that once and you'll be an expert.
_________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
EverettB Administrator
Joined: April 11, 2000 Posts: 69834 Location: Phoenix Metro
Posted: Wed Jun 22, 2016 5:58 pm Post subject: Re: Engine removal on 56 Oval |
I haven't done an Oval but I always use a box wrench on my Bus.
No issues.
If the car still drives right now, you could grab some degreaser and visit the local car wash. Use their high pressure sprayers and degreasers to get a bunch of the dirt/grease out of there first. _________________ How to Post Photos
Posted: Wed Jun 22, 2016 6:29 pm Post subject: Re: Engine removal on 56 Oval |
ZENVWDRIVER wrote: |
We've undone some of that type of butchery |
Posted: Thu Jun 23, 2016 6:59 am Post subject: Re: Engine removal on 56 Oval |
nlorntson wrote: |
Perfect nlorntson, un doing the access would be your prerogative, once the car is yours... LOL, when it's mine, I always make an access... is interesting to me, that VW made such an access and discontinued it in September, 1952... Would you un do that one too? _________________ 5/50, pastel green 11G - SOLD
1960 single cab
'87 Toyota MR2
Posted: Thu Jun 23, 2016 7:06 am Post subject: Re: Engine removal on 56 Oval |
My 49 has that access including the bolted on cover, and it sits below a thick, glued on padding, carpet and two bolted on luggage rails. You'd have to completely tear apart your back seat area, pull up the carpet, and glued on padding to get to the cover.
More likely that cover was used for access during assembly at the factory before the interior went in. |
Posted: Thu Jun 23, 2016 7:42 am Post subject: Re: Engine removal on 56 Oval |
nlorntson wrote: |
My 49 has that access including the bolted on cover, and it sits below a thick, glued on padding, carpet and two bolted on luggage rails. You'd have to completely tear apart your back seat area, pull up the carpet, and glued on padding to get to the cover...
Oh, ho, ho, ho, your assessment of VWs access is inaccurate... first, until 1950, there was no padding or carpet, back there. So, if you have all that, it's a good move for the sound deadening qualities, but is not as original. Second, that access was used initially to check and fill the transmission oil. Until 1950 there was no little side holes in the tranny to add fluid. The fill hole was on top, below that access cover. the dealers could put the car on a lift to gain access, but it could also be checked and filled through that access
I had a 1950 11G early on, then a '49 sedan, in my VW life and I remember that wonderful access. Not butchery, I carefully make a cut and add an oak lip for the cut piece to lay on... you (mistakenly) refer to it as "butchery"... granted, it is not OE, but neither is your glued-in padding and carpet... is your preference, like the access is my preference...
... my little access affords me to gain access to the starter and connections, top engine mounting bolts, fuel line and added fuel filter, trans fluid checking and filling, easy clutch adjusting and other minor conveniences. I can't help it that VW forgot to continue this very handy access. I sure don't enjoy doing all those things laying on the ground and at age, close to 70, would prefer the ease of working comfortably from the top... I often wonder if my critics even do their own maintenance ...
Just so you know, I fasten the metal cover on with screws and install the square weave carpet over the area with no padding, glued only on the vertical plane, with the rest of it laying flat and roll it back, to gain access... with the carpet installed, no harsh critics are the wiser, knowing about my wonderful secret... is for me to enjoy... _________________ 5/50, pastel green 11G - SOLD
1960 single cab
'87 Toyota MR2
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
Posted: Thu Jun 23, 2016 10:41 am Post subject: Re: Engine removal on 56 Oval |
lumbee wrote: |
I use a Craftsman 17mm/19mm box wrench . . . You will get only an eighth of a turn!
Those are the FIRST of the four engine mount nuts to be removed, after disconnecting ALL the cables (2 heater; throttle; choke), ALL the wires, and the fuel line.
After you remove the bottom two nuts, place your jack under the engine and raise the jack just enough to support the weight of the engine.
Lastly, remove the top two bolts and ease the engine out/down. _________________ Jesucristo es mi Seņor y Salvador! |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24772 Location: Olympia Wash Rinse & Repeat
lumbee Samba Member
Posted: Fri Jun 24, 2016 4:27 am Post subject: Re: Engine removal on 56 Oval |
Got it out yesterday. There was a metal bracket that runs along the bottom of the engine that holds what looks to be rubber engine mounts in place. Once I removed that I was able to get at the bolts.
So much oil and gunk on everything its tough to tell whats part of the frame, or what is removable.
At any rate, one I got those bolts removed I had it dropped in about 5 minutes. |
Posted: Fri Jun 24, 2016 5:23 am Post subject: Re: Engine removal on 56 Oval |
lumbee wrote: |
Got it out yesterday. There was a metal bracket that runs along the bottom of the engine that holds what looks to be rubber engine mounts in place. Once I removed that I was able to get at the bolts. |
What's supporting the rear of the transmission now? |
splitjunkie Samba Member
Posted: Fri Jun 24, 2016 9:06 am Post subject: Re: Engine removal on 56 Oval |
nlorntson wrote: |
lumbee wrote: |
If he doesn't reply then we will know that he is supporting it...
Seriously that bracket is the rear transmission cradle and it supports the rear of the transmission and the engine. If you removed it then there is nothing supporting the transmission other than the front transmission mount and the axles which are pressing outward on the spring plates. Not a good or safe situation. _________________ Chris
Posted: Fri Jun 24, 2016 11:51 am Post subject: Re: Engine removal on 56 Oval |
nlorntson wrote: |
Oh, ho, ho, ho, your assessment of VWs access is inaccurate... first, until 1950, there was no padding or carpet, back there. So, if you have all that, it's a good move for the sound deadening qualities, but is not as original. Second, that access was used initially to check and fill the transmission oil. Until 9/52 there was no little side holes in the tranny to add fluid. The fill hole was on top, below that access cover. the dealers could put the car on a lift to gain access, but it could also be checked and filled through that access
Just so you know, I fasten the metal cover on with screws and install the square weave carpet over the area with no padding, glued only on the vertical plane, with the rest of it laying flat and roll it back, to gain access... with the carpet installed, no harsh critics are the wiser, knowing about my wonderful secret... is for me to enjoy... |
1960 single cab
'87 Toyota MR2
Posted: Fri Jun 24, 2016 4:02 pm Post subject: Re: Engine removal on 56 Oval |
Oh, ho, ho, ho, your assessment of VWs access is inaccurate... first, until 1950, there was no padding or carpet, back there. So, if you have all that, it's a good move for the sound deadening qualities, but is not as original. |
1949 deluxe.
Now, let's get back to wondering what's holding up the guys tranny now. |
Posted: Fri Jun 24, 2016 4:31 pm Post subject: Re: Engine removal on 56 Oval |
nlorntson wrote: |
. . . let's get back to wondering what's holding up the guys tranny now. |
A pair of axle boots!
And speaking of Split-Windows . . . ya gotta check-out the SUPER NICE brown split in the latest Hot VWs magazine! _________________ Jesucristo es mi Seņor y Salvador! |
Posted: Sat Jun 25, 2016 8:14 am Post subject: Re: Engine removal on 56 Oval |
nlorntson wrote: |
1949 deluxe.
... exactly, a PO (mistakenly) installed all that insulation and carpet over the access, probably at the same time the red plastic was put on the interior panels... good idea for noise suppression... easier to get at the access with no carpet though... I like the din of a good running VW engine.
... i'll bet, the tranny is sagging _________________ 5/50, pastel green 11G - SOLD
1960 single cab
'87 Toyota MR2
Mr. OGPaint Samba Member
Joined: September 24, 2010 Posts: 823 Location: Oregon
Posted: Sat Jun 25, 2016 10:01 am Post subject: Re: Engine removal on 56 Oval |
For sure cutting one in is a hack! Some people like some hacks, in this case you like this hack Zen. Similar to all the "bay window" engine accesses cut into split buses, also similar but less noticeable than wheel wells cut to clear tires.
-factory didn't use oak, which will hold moisture and cause rust
-factory had a reinforced "landing" around the hole for strength
-factory cover was ribbed
-factory bolted in, not using Home Depot screws
NLorentsen knows her splits. The beautiful '49 on the cover of the current hotvws belongs to her. I don't know for certain what kind of padding is on a '49 but I do know on an unmodified 51 or 52 that removing the factory luggage rails and carpet is far more work than anything you would need to access from the bottom. An unmodified car with split case and 25/36hp engine is not hard to access the starter, clutch cable, or engine bolts from below with proper tools and jackstands.
Apologies to the OP for the thread hijack. No more from me on this cut luggage area subject _________________ https://instagram.com/mr.ogpaint
Patrick Hall |
