MICHANICAL™ Samba Member
Posted: Thu Jun 01, 2006 8:37 pm Post subject: Rotisserie |
Build @ your own risk. I Michael Allen of the Studio 3 Project, assume zero responsibility to these plans, rotisserie and all person's using them. I have donated my ideas and time for free to aid in the restoration of projects. Please apply common sense when building this contraption, and Safety first!
I built this from $50. in scrap materials. I estimate new material cost @ $300. This design was ideal for transporting use. Other rotisseries may be more appropriate for in place rotation. My design is simple and builder friendly. Take your time and study the plans. You will need a welder, welding mask, 1/2 drill, 1/2 inch drill bit, chop saw or cutting devise, tape measure, thick leather gloves, safety goggles and possibly a calculator.
Step one: Build a 30 degree jig out of 2 x 2 angle iron; Weld the two 23 inch angle iron sections (long point to long point) with 15 degree cuts @ a perfect 30 degree angle. To verify true degree reference length of A sq. + B sq. = C squared.
Step two: Cut your 0.23622047 decimal inch wall thickness 2" x 2" tubing @ 15 degree cuts to length. Mark all lengths, 21 inches and 23 inches. (Please see foot note). Pair the correct to plans sections in two, double check and make minor adjustments if needed. Break the rotisserie into a top and bottom, each should share parallels angles and one side. Using Jig, weld pairs, then weld pairs together. Now you have a complete multigon making a 360 degree circle, I.E. 12 30 degree angles make 360 degree multigon. Repeat this step for second multigon.
Step three: Cut your multigon "B" to a top and bottom, note location to plans. Insert "b" solid stock in bottom half and weld in place @ all four locations. Slide top half of multigon back in place and drill out a hole for a holding pin. Remove top half.
Step four: Weld "A" in place. Note "a" (receives a 2 inch x 2 inch tubing)
Step five: Make your mounting bracket arms and plates. Mount the plate's (flat 1/2" steel plate) in place on your vehicle, and get ready for some muscle work. Slide the arms in place on the multigon. Raise the vehicle to center point of gravity. Raise the bottom half multigon with all in place, steady the bottom half w/ tack welded temporary stabilizer. Weld the arms "C & D" to the 1/2 plate that is bolted on your bus. Note: the bracket arms should be removable from the "A" pockets. Note: "c & d" were designed for barndoor bus, when building rotisserie for non barndoor; mount plates in place and correct the dimension width on arms prior to welding. Allow 1/2 inch of total play.
Step six: Build a safety bar. See jpg. This is very important. You don't want the bus rolling back on your ass or squashing your precious hands! Please note safety bar jpg. Use this bar.
Step seven: Lift the top half's of the multigon's in place and safety pin. Roll that bus over, safety bar the position and fix that nasty rust to factory standards. If its worth doing, do it right!
Foot note: 21 and 23 inch length's can all be changed to 23 inches. This will simplify the layout but make the overall height taller and you should consider the height of your garage opening prior to making this change.
Michael Allen
www.theStudio3Project.com
Rotisserie #2
Plans by sgellis later in this thread.
Post with photos:
http://www.thesamba.com/vw/forum/viewtopic.php?p=8252247#8252247
Link to PDF:
http://www.thesamba.com/vw/archives/manuals/bus_rotisserie/VWBus_Rotisserie.pdf
Rotisserie #3
By user aeLiXihr
Post with photos:
https://www.thesamba.com/vw/forum/viewtopic.php?p=8941620#8941620
DXF Autocad file:
https://www.thesamba.com/vw/archives/manuals/bus_rotisserie/kantelraam.dxf |
combiwagon1969 Samba Member
Posted: Wed Jun 27, 2007 1:32 am Post subject: the vw Rotisserie |
Hi. first of all I have to say MUCH RESPECT for this one.
First class, really. Now, do you have any more pictures, dimensions etc. the info that you have given, while good, is a bit hard to follow so any extra pics and stuff would be handy. |
Bugs'n'Pugs Samba Member
Joined: July 18, 2004 Posts: 1453 Location: Charleston, South Carolina USA
thom Samba Member
Joined: October 12, 2000 Posts: 5944 Location: Sacramento
Posted: Tue Mar 25, 2008 9:26 am Post subject: |
Bugs'n'Pugs wrote: |
Would something similar to this work on a Beetle or a Super Beetle? |
In theory, yes. Just make the whole thing smaller, and change the mounting points accordingly. _________________ -Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type |
The Sage Samba Member
Joined: December 10, 2005 Posts: 2470 Location: Traverse City
Posted: Tue Mar 25, 2008 9:33 am Post subject: |
thom wrote: |
In theory, yes. Just make the whole thing smaller, and change the mounting points accordingly. |
Russ and I were discussing this, the mounting points would be very similar..
You could make an adjustable version to use on both models, but honestly, with the pan / body of a bug, you really don't need this. _________________ Feel My Pain l Sage Ad World |
Volksparts Samba Member
Posted: Tue Mar 25, 2008 9:39 am Post subject: |
Maybe I am easily impressed but that is one of the coolest things I have ever seen. Thanks for posting the schematics. |
NOS PARTS Samba Member
Joined: June 24, 2001 Posts: 377 Location: behind the wheel, safari's open
Posted: Tue Mar 25, 2008 12:06 pm Post subject: |
here some interesting ones;
this last 1 I like more!
crukab Samba Chef
Joined: December 13, 2002 Posts: 6116 Location: Vermont
Posted: Tue Mar 25, 2008 12:28 pm Post subject: |
NOS PARTS wrote: |
Hey, thats my truck !
Here is a shot of the plates & arms I made to attach to the front end, you also can see the extra wheels added, to lower the rig down a few inches.
The best part is it works with a 8 foot ceiling, in basicly 1 garage bay.
I like the one that Michael posted, But don't have that much space. _________________ Tom
My Pops:
In the yard right now:
'51 Dodge 5 window truck
'65 Bug
'66 Singlecab
'82 Rabbit Truck Diesel from CALI
'86 Doublecab W/T
'88 Dodge Ram pickup
'11 Jetta Wagon |
thom Samba Member
Posted: Tue Mar 25, 2008 1:35 pm Post subject: |
1956 Single Cab
1963 Unimog 404
1965 E-Type |
thom Samba Member
Posted: Tue Mar 25, 2008 1:36 pm Post subject: |
LiquiTilter
http://www.liqui-tilter.com/
1956 Single Cab
1963 Unimog 404
1965 E-Type |
candyman Samba Trout Slayer
Joined: December 20, 2003 Posts: 2694 Location: Missoula MT
Posted: Tue Mar 25, 2008 4:30 pm Post subject: |
this is all bad ass!!! i gotta build one of these |
Posted: Tue Mar 25, 2008 4:32 pm Post subject: |
crukab wrote: |
NOS PARTS wrote: |
I like the one that Michael posted, But don't have that much space. |
from the looks of it crucab, you bottom needs it love that vermont salt. mmmm salt crusted crucab |
UZI Platinum FUBU
Joined: February 08, 2002 Posts: 13335 Location: phila-DELFT-ia
Posted: Tue Mar 25, 2008 6:20 pm Post subject: |
_________________ Extravagant Lifestyle
Quote: |
mannys66: South Philly Van Club, only the most influential and freshest van club in the vw scene |
Quote: |
Cuñado: Chrome will get you home!!!!!!!!!! |
crukab Samba Chef
Posted: Thu Mar 27, 2008 8:51 am Post subject: |
Is that Jdots Rotisserie ? _________________ Tom
My Pops:
'65 Bug
'66 Singlecab
'86 Doublecab W/T
'11 Jetta Wagon |
jeremyrockjock Samba Towbar Builder
Joined: January 01, 2002 Posts: 5008 Location: Richmond, Verjinya
Posted: Thu Mar 27, 2008 3:32 pm Post subject: |
I like mine.
_________________ Why buy what you can build.
Step away from the fiberglass and no one gets hurt!! |
bubblehead Samba Member
Posted: Thu Mar 27, 2008 5:28 pm Post subject: |
Jeremy
Could you post some more detailed pictures of your setup? I've been considering going the engine hoist route for a while. I see those things for sale cheap all the time and its similar to the ready made rotisseries out there.
Crukabs setup is really cool, just more coin than I want to spend. I also like the other one pictured above, with the two 45's that put it at a ninety.
In my opinion probably the cheapest, most effective setup. |
Mr. Bubblehead El Chupa Nibre
Joined: October 25, 2002 Posts: 2756 Location: 612 Wharf Avenue
Posted: Thu Mar 27, 2008 6:56 pm Post subject: |
Jeremy are you putting that swingaxle in the bay??!!? _________________ OGST
Samba Member #4862 |
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9797 Location: Exit 7, New Jersey
Posted: Thu Mar 27, 2008 9:47 pm Post subject: |
crukab wrote: |
Is that Jdots Rotisserie ? |
yes _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
Posted: Sat Mar 29, 2008 6:35 pm Post subject: |
LOL the swing axle is for a 67 deluxe belonging to my friend.
The rotisserie is scratch built from old wheelchair lift parts and box tubing. They look like engine stands but are much bigger. _________________ Why buy what you can build.
Nic B-C Samba Member
Joined: January 02, 2006 Posts: 605 Location: North East UK
Posted: Sun Mar 30, 2008 8:20 am Post subject: |
Liking these but always wondered how you lift both ends on a rotiserie to get high enough to roll and also what controls the roll speed.
Any help would be grateful please as got several vehicles here which need chassis sorting plus im considering getting a sandblasting machine as well
Cheers _________________ www.durhamoldschooldubbers.co.uk |
