aRabidGerbil Samba Member
Posted: Thu Apr 25, 2024 12:28 pm Post subject: 71 Super Beetle losing power and won't start when warm |
I've got a 71 Super Beetle that's having problems when it's warm, either from driving, or just a hot day. If it's hot it takes a few goes to start and sometimes just won't start, I get starter noise and nothing else. If it's running it idles smoothly and runs fine at speed, but if I'm trying to start from a stop, I need to slowly coax the RPMs up, because it will immediately die if I just give it gas.
What I've tried so far:
-Checked the coil, got a weak spark so I replaced it, problem still there
-adjusted all valves to make sure none of them were stuck closed
-sprayed propane around the intake manifold and carburetor looking for a vacuum leak, didn't see any change
-tested pulling spark plug wires to make sure each cylinder was firing, all were
Does anyone have any idea where to look next? |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 10045 Location: Huntington Beach, CA
Posted: Thu Apr 25, 2024 12:41 pm Post subject: Re: 71 Super Beetle losing power and won't start when warm |
Like your handle! Are you a friend to Richard Gere?
What is your choke doing?
What is the spark output WHILE cranking the starter? This could be a voltage problem. Check your resting battery voltage first thing in the morning. Write it down. Then crank the engine. What is the voltage while cranking?
What ignition system are you running?
Engine compression with a warm motor is?
Got a picture of your engine? _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
bsairhead Samba Member
Joined: October 08, 2008 Posts: 3642 Location: viroqua wi.
Posted: Thu Apr 25, 2024 1:22 pm Post subject: Re: 71 Super Beetle losing power and won't start when warm |
Could be choke, or timing. |
Posted: Mon Apr 29, 2024 10:44 am Post subject: Re: 71 Super Beetle losing power and won't start when warm |
Sorry for the late reply, I needed to wait a bit to get someone to crank the car for me.
Choke is adjusted when cold and is opening when it warms up
Coil is giving a strong spark when cranking, voltage on the battery drops to around 10-11 volts
I've got an electronic ignition, so no points to worry about
Unfortunately, I don't currently have a compression testing kit, I'm waiting to borrow one from a friend
Picture of engine
sb001 Samba Member
Joined: May 19, 2011 Posts: 10408 Location: NW Arkansas
Posted: Mon Apr 29, 2024 11:18 am Post subject: Re: 71 Super Beetle losing power and won't start when warm |
Normal in warm/ hot weather.
WAAAYY fewer owners DON'T have this problem, than those that do. _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
baldessariclan Samba Member
Joined: October 14, 2016 Posts: 1417 Location: Wichita, KS
Posted: Mon Apr 29, 2024 2:02 pm Post subject: Re: 71 Super Beetle losing power and won't start when warm |
Owner’s manual procedure for starting an engine at “operating temperature” (i.e. hot) is to hold the accelerator all the way to the floor while cranking (ref. below) — quite a bit different than when starting the engine cold or merely “warm”:
Definitely don’t pump the accelerator or otherwise flood the engine when hot, or yes will be much harder to start. Slowly depressing and holding the accelerator all the way to the floor prior to or during cranking always seems to work for me when my engine is really hot.
The 34 PICT-3 carb and 009 distributor combination (which looks like is what you have in your engine pic) is well known to often cause flat spots and stumbling on initial acceleration. However, sounds like you have a bit more than just that going on. Perhaps a bit of poor tuning, and/or malfunctioning distributor advance? Or alternately your carb’s accelerator pump not working, or other partial fuel starvation issue? Just a couple ideas to think about… _________________ 1971 Standard Beetle — fairly stock / driver
baldessariclan -- often in error, never in doubt... |
jinx758 Samba Member
Joined: October 04, 2014 Posts: 758 Location: half a bubble from plumb
Posted: Mon Apr 29, 2024 4:55 pm Post subject: Re: 71 Super Beetle losing power and won't start when warm |
Also ...
*accelerator pump squirt
*fuel cutoff solenoid
*gas tank not venting
*vapor lock from fuel line/hose touching a hot item
Ideas that mite stick to a wall ... stay safe
jinx _________________ " It's not valuable unless you learn something from an experience. " Henry Ford
It's not unlike the same difference
You can't push a rope
Cheap parts ain't good
and good parts ain't cheap.
My Craigslist rescued 100 footer :
1971 Standard Bug
1776cc dual port
034 distributor
38mm EGAS Carburetor |
Posted: Tue May 07, 2024 5:36 pm Post subject: Re: 71 Super Beetle losing power and won't start when warm |
Thank you so much all for your help, I believe the issue has been resolved. I had a bad accelerator pump diaphragm, which was squirting fuel directly behind the carburetor, out of sight. |
