Convoy Samba Member
Joined: March 17, 2011 Posts: 312 Location: San Clemente
Posted: Fri Jul 29, 2016 2:23 pm Post subject: Stranded in Morro Bay (Home now) |
Anyone in the area from Aires Rescue or reputable members here in morro bay. It's 2:20 on Friday and driving down hwy 1 when all of a sudden the bus made cluttering sound and I pulled off the highway at exit Morro Bay Blvd. the clattering sounds like valves. Anyone can reach me or close by to assist?
Convoy Samba Member
Posted: Fri Jul 29, 2016 2:30 pm Post subject: Re: Stranded in Morro Bay |
Btw type iv 2.0 dual carbs. Valves adjusted to spec. 1000 miles earlier. |
SGKent Samba Member
Posted: Fri Jul 29, 2016 2:55 pm Post subject: Re: Stranded in Morro Bay |
late bay most common catastrophic is a dropped valve seat. Did the power drop off too? Any chance a carb screw fell into a cylinder? You can look at the fan belt to see if it is shredded and maybe you heard it flailing but if there is nothing visual it will probably be a valve seat. Very common. If you pop the valve cover one valve will seem out of place when you turn it over by hand. The only thing other it could be would be if you just gassed up and got some bad gas and it was pinging or the timing changed suddenly like the distributor or points changed.
Sad to say but better prepare for a tow home. AAA Premier has a 1 x 200 mile or 3 x 100 mile tow so if you have that plan like we always recommend here you can get towed home for free since you are only 266 miles from home, and deal with it later. If you don't have that plan you can't buy it on the spot as there is a waiting period so have a buddy in San Clemente come get you on a flat bed or dolly. pull the bus backwards with the rear wheels in the dolly, or remove the drive shafts. Sorry it happened to you. It sure sounds like a classic valve seat failure. Let's hope someone locally can look at it and it is something simpler like a piece of wire or rope got caught in a wheel and you heard it hitting the wheel well.
If I seem less than optimistic - there isn't a lot around Morro Bay - just miles of coast on both sides, at least that is how it used to be. If you start it up and it still does it you should be able to use a long screwdriver or stick to listen to the engine thru to see which side the sound is loudest. If you have AAA Premier don't give up a 100 mile tow being towed 10 miles into town because you may need that 100 mile tow as part of getting home. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51173 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Jul 29, 2016 2:59 pm Post subject: Re: Stranded in Morro Bay |
You can also try turning the engine by hand with a wrench on the alternator nut through 4 full turns, any clunking or binding aside from the springy compression resistance?, does the compression feel the same through all 4 turns? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Fri Jul 29, 2016 4:22 pm Post subject: Re: Stranded in Morro Bay |
There was an air cooled shop near Atascadero or Paso Robles. I cannot vouch for them; they might not deal with Type 4 engines. You will need to do a Google search, but I know they are right on 101.
I am about two and a half hours east from Morro Bay. If you're bad off and need to do an engine swap, PM me. I can arrange for un-fenced off-street level work area and I also have a at least one pre-1979 2.0 fuel injected engine and probably enough chunks of most everything else to cobble you back together, if need be. I can support you with most tools and supplies.
I can also arrange to flatbed transport. |
Posted: Fri Jul 29, 2016 4:44 pm Post subject: Re: Stranded in Morro Bay |
Convoy wrote: |
Anyone in the area from Aires Rescue or reputable members here in morro bay. It's 2:20 on Friday and driving down hwy 1 when all of a sudden the bus made cluttering sound and I pulled off the highway at exit Morro Bay Blvd. the clattering sounds like valves. Anyone can reach me or close by to assist? |
Pull both valve covers and looks for a valve adjustment screw that has backed out. Once a screw backs out far enough to hit the valve cover it will make an awful noise. |
ninjaorgtfo Samba Member
Joined: March 26, 2016 Posts: 12 Location: Los Angeles, CA
Posted: Fri Jul 29, 2016 4:56 pm Post subject: Re: Stranded in Morro Bay |
I believe I saw a place with a nicely restored bus in San Luis Obispo. Not sure if they can help you, but its worth a shot. Good luck, keep your head up. |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Fri Jul 29, 2016 5:47 pm Post subject: Re: Stranded in Morro Bay |
...in the late 80s...was driving back from The Sunshine State to NY in a nice '71 Westy and on I95, we threw a rod... bought a case of oil and hobbled back to a VW dealer... long story short, they wanted $4K to rebuild the 1600 sp and we couldn't afford that... we rented a small Pontiac from Hertz and gave our bus to one of the mechanics and went home...
... here's that same bus on vacation in Canada, the summer before...
_________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4145 Location: Los Gatos,Ca.
Posted: Fri Jul 29, 2016 6:49 pm Post subject: Re: Stranded in Morro Bay |
Westy Works in SLO is closed sat&sun and that is the only shop i know of
but, call GoWesty also in SLO in the morning as i believe their parts department may be open and possibly recommend someone
Westy Works repairs alot of the vehicles that Go-Westy used to repair
805-549-0100
SLO is only 13 miles north from you. _________________ V.W.owner since 1967 |
Convoy Samba Member
Posted: Fri Jul 29, 2016 6:57 pm Post subject: Re: Stranded in Morro Bay |
Thank you everyone for your suggestions. Currently my wife are now in Santa Barbara heading south. Not sure what it was?? Started it back up and clack clack clack so turned it back off. Then when we found a place to store it overnight I started back up for the third time and it purr'd. No sign of clack clack. Gave it a few revs and still no sign of clack clack knock. Now we are traveling along the 101 and keeping a sign on all the vitals. Once We are safely back home I investigate further. |
Posted: Fri Jul 29, 2016 7:22 pm Post subject: Re: Stranded in Morro Bay |
How is your shifting?
Just reaching out here, but maybe one of the clips on the throw-out bearing broke.
And, getting back to the engine... did you feel a loss of power? |
Convoy Samba Member
Posted: Fri Jul 29, 2016 11:41 pm Post subject: Re: Stranded in Morro Bay |
Well back home without an issue after driving over 250 miles after it occurred.
However When it did occur it popped and felt like a few firing misses occurred inconjunction with the knocking/clicking. Weirdest thing as it sounded internal and had a more dense sound unlike a valve but more rod sounding. The power loss wasn't really noticeable almost like fuel starvation feeling. |
Convoy Samba Member
Posted: Fri Jul 29, 2016 11:46 pm Post subject: Re: Stranded in Morro Bay |
And to add it ran like a finely tuned 2.0 for the entire trip afterwards. No miss, ping, clatter, knock. No nothing. |
SGKent Samba Member
Posted: Sat Jul 30, 2016 12:58 am Post subject: Re: Stranded in Morro Bay |
First - thank God you are home.
Second - some things are hard to explain. I can't imagine a piece carbon or ice causing the issue but I guess strange things happen. T4 engines are very prone to loosening valve seats. A valve seat can slip loose from the head being hot, cause a backfire and loss of power then slip back in and last another 1000 miles. When you get refreshed, pull the valve covers and check the valves again. Make sure one is not a little more off than the others.
Really glad you got home - it was on my mind. A seat can sit in place for thousands of miles loose, then slip out, turn sideways, fracture and go thru a piston.
Likewise a piece of carbon can sound like someone tossed marbles into the engine. If you have hydraulic lifters one may have gotten a piece of debris in it and collapsed for a minute. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sat Jul 30, 2016 3:11 am Post subject: Re: Stranded in Morro Bay |
Convoy wrote: |
Do you have solid lifters or hydraulics? |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22679 Location: NYC/Upstate/ROW
Posted: Sat Jul 30, 2016 4:12 am Post subject: Re: Stranded in Morro Bay |
Glad you made it home. Its a tougher world out there to find someone who can really work on a car. The franchises have taken the money job (brakes, batteries tires, oil changes) from the independents and left them with the tough jobs that require diagnostic skills.
..and,change your thread title!!
_________________ .ssS! |
Convoy Samba Member
Posted: Sat Jul 30, 2016 10:33 am Post subject: Re: Stranded in Morro Bay (home now) |
Solid lifters
Convoy Samba Member
Posted: Sat Jul 30, 2016 10:45 am Post subject: Re: Stranded in Morro Bay (home now) |
Solid lifters. I'll verify valve clearance later this week and report back and also of my findings as I may dig deeper at a later date. |
Starbucket Samba Member
Posted: Sat Jul 30, 2016 12:11 pm Post subject: Re: Stranded in Morro Bay (Home now) |
Look in your carbs to see if all the butterfly screws are still there as it sounds like a small screw went through the motor and it finally either passed out the exhaust port or embedded itself in the head or piston. |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Sat Jul 30, 2016 5:08 pm Post subject: Re: Stranded in Morro Bay (Home now) |
Starbucket wrote: |
That would be my guess-- square deal niel built an engine that had a spitzer tube stuck in the intake- wow -- what a racket- Kenny to the rescue just reved it up and it ran like a top-- so ya- check the carbs for missing parts. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
