Varthog Samba Member
Joined: June 15, 2016 Posts: 17 Location: Bosnia&Herzegovina
Posted: Tue Jul 26, 2016 4:02 am Post subject: Possibility to put PTO on Beetle or t3 Gearbox? |
Hi there guys,
Well i am rather curious person so started research regarding PTO's. I was thinking is there any kind of possibility of installing PTO to the t3/Beetle gearbox...kinda odd but dead serious question? Since we (couple of buddies) are trying to build all purpose buggy we wanted professional opinion about this.
So if anyone can share their information it would be perfect.
Where to get one? How to obtain it? Procedure?
Thank you guys in advance, glad to have this forum |
raul arrese Samba Member
Joined: July 23, 2006 Posts: 1330 Location: miami florida
Posted: Tue Jul 26, 2016 4:07 am Post subject: Re: Possibility to put PTO on Beetle or t3 Gearbox? |
Explain what your trying to do and maybe we can give you some ideas.?? _________________ " Hot vw feature , may 2014 issue "
" 2013 Bug Jam class winner "
" Bug Jam best motor and best paint "
" 2013 Lakeland Classic Best of Show "
" 2014 Show and Shine , First in class "
Like my facebook https://www.facebook.com/pages/Raul-Arrese-custom-fabrication-and-performance/1832968110262608 |
Posted: Tue Jul 26, 2016 4:20 am Post subject: Re: Possibility to put PTO on Beetle or t3 Gearbox? |
For now there are possibility of having winch or turning it into 4x4 in the time of need. These are just first thoughts i have in mind. |
Posted: Tue Jul 26, 2016 4:33 am Post subject: Re: Possibility to put PTO on Beetle or t3 Gearbox? |
pto for hydraulics or air pressure is third idea and the more i think i would go in this direction (reason for pto). |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15316 Location: Deep in the 405
Posted: Tue Jul 26, 2016 4:44 am Post subject: Re: Possibility to put PTO on Beetle or t3 Gearbox? |
No, not with a Type I gearbox. Your only choice would be to adapt a transaxle out of a 4WD Syncro. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Tue Jul 26, 2016 4:50 am Post subject: Re: Possibility to put PTO on Beetle or t3 Gearbox? |
Type 1 out of question, what about type3? These two are the choices i have for now, thats why i am so glued to those two .
Because i am totally in the dark regarding this thats why i seek your help guys. |
esde Samba Member
Joined: October 20, 2007 Posts: 5971 Location: central rust belt
Posted: Tue Jul 26, 2016 4:51 am Post subject: Re: Possibility to put PTO on Beetle or t3 Gearbox? |
Belt drive pump with an electric clutch will be the easiest way _________________ modok wrote:
Posted: Tue Jul 26, 2016 4:59 am Post subject: Re: Possibility to put PTO on Beetle or t3 Gearbox? |
Okey that is one way to approach the problem. |
Posted: Tue Jul 26, 2016 5:29 am Post subject: Re: Possibility to put PTO on Beetle or t3 Gearbox? |
Any other advice for this ? |
timcurtis67 Samba Member
Joined: August 21, 2013 Posts: 87 Location: Carlisle PA
Posted: Tue Jul 26, 2016 5:33 am Post subject: Re: Possibility to put PTO on Beetle or t3 Gearbox? |
Subaru tranny.... _________________ 67 Desert Fox Spoiler |
TinCanFab Samba Member
Joined: April 04, 2006 Posts: 2743 Location: Waterford, California
Posted: Tue Jul 26, 2016 5:43 am Post subject: Re: Possibility to put PTO on Beetle or t3 Gearbox? |
I've worked on some big railroad trucks where the PTO was mounted to the front bumper and driven by a short driveshaft with u-joints. IIRC the driveshaft mounted directly to the crank, in the center of the pulley. If you can't or don't want to do a belt drive. Depending on the type of buggy and if you don't mind seeing the thing hanging off the back. Maybe you can make the whole setup quick release when not using it. I have no idea how well this would work on a VW compared to a big Diesel engine though. _________________ Check out my truck brought back from the dead... http://www.thesamba.com/vw/forum/viewtopic.php?t=420762&highlight=sprayed+blood
They're never really ever finished 58 rag build...
http://www.thesamba.com/vw/forum/viewtopic.php?t=658092 |
bpritchert87 The Idea Man
Joined: February 26, 2007 Posts: 1507 Location: Wisconsin
Posted: Tue Jul 26, 2016 6:22 am Post subject: Re: Possibility to put PTO on Beetle or t3 Gearbox? |
Aww subaru ...im not that kinda good with the money that is why i stick with the T3 & T1 transmission (i have no other options)
Seems like i asked for taboo XD |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20388 Location: Just a tiny bit west of Yosemite Valley
Posted: Tue Jul 26, 2016 6:28 am Post subject: Re: Possibility to put PTO on Beetle or t3 Gearbox? |
Electric winch.... Or some thing like hydraulic pump or air compressor run off crank pulley with belts...
You will be building a $5,000 transaxle to run a $500 (or less) device...
Posted: Tue Jul 26, 2016 6:43 am Post subject: Re: Possibility to put PTO on Beetle or t3 Gearbox? |
Dale M. wrote: |
Dale |
Even if i go in this direction "pto for hydraulics or air pressure is third idea and the more i think i would go in this direction (reason for pto)." |
slalombuggy Samba Member
Posted: Tue Jul 26, 2016 8:22 am Post subject: Re: Possibility to put PTO on Beetle or t3 Gearbox? |
Type 1 and 3 use the same transaxle. I seem to remember an AWD sand dragster back in the late 80s that used a hydraulic system to drive the front wheels using a glorified engine oil pump. Killed the competition and got protested out of the class. Was in HVWs mag
brad |
luvthemvws Samba Member
Joined: February 13, 2012 Posts: 117 Location: Middle of nowhere
Posted: Tue Jul 26, 2016 8:31 am Post subject: Re: Possibility to put PTO on Beetle or t3 Gearbox? |
Nothin to it.
Simply install the oil pump into the engine from an Autostick application and use the fluid pressure to drive a hydraulic motor. It's only about 50psi, but geared properly it should drive almost anything you need.
Rock on. |
Posted: Tue Jul 26, 2016 2:18 pm Post subject: Re: Possibility to put PTO on Beetle or t3 Gearbox? |
Dale M. wrote: |
Dale |
Some winches use hydraulics tapped into vehicles power steering system.... If you neet rotational power, how about using power steering pump (belt driven) tied to hydrostatic drive motor...
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4858 Location: sanger ca
Posted: Tue Jul 26, 2016 2:22 pm Post subject: Re: Possibility to put PTO on Beetle or t3 Gearbox? |
slalombuggy wrote: |
brad |
If I remember right, that was the black widow, it was a mud racer. It originally got protested because it was a 2 wheel drive, thats when they came up with the hyd. drives for the front. _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13286 Location: Tejas!
