Globespotter Samba Member
Joined: February 16, 2012 Posts: 1770 Location: Newmarket, ON
VWinVT Samba Member
Joined: April 21, 2013 Posts: 1541 Location: North East Kingdom
Posted: Sat Jun 25, 2016 6:34 pm Post subject: Re: On the road in NH |
Westfield, VT...if you need a hand PM me. _________________ 1981 Westfalia with a 2001 Cabrio ABA
Small wheel turns by the firing rod,
Big wheel turns by the grace of God.
Every time that wheel turns 'round,
You're bound to cover just a little more ground. |
rottenkid Samba Member
Joined: June 19, 2015 Posts: 236 Location: Warkworth, ontario
Posted: Sat Jun 25, 2016 2:29 pm Post subject: Re: On the road in NH |
My drivers side door handle is tight to. I was checking the door rubber today to see if I can reduce the pressure.
I had a great time at Bug Fest Niagara. I wish I were on a trip like your taking, but our dog is older and is not as comfortable riding in the bus these days.
Have a great trip. |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22677 Location: NYC/Upstate/ROW
Posted: Fri Jun 24, 2016 5:02 pm Post subject: Re: On the road in NH |
The handle breaking might be the symptom, not the cause. Check the lock actuator for smooth and buttery release. Excess stress on the pivot will snap pot metal of course _________________ .ssS! |
Tcash Samba Member
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15148 Location: Syracuse, NY
Posted: Fri Jun 24, 2016 7:47 am Post subject: Re: On the road in NH |
hopefully you don't need any of these but if you do.
garages in quebec http://www.leswests.qc.ca/mecanique-liste-garage.php3
enjoy the Eastern Townships (Cantons-de-l'Est)
we'll be crossing your path headed to Quebec city & Tadoussac shortly. _________________
Abscate wrote: |
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Thu Jun 23, 2016 9:11 pm Post subject: Re: On the road in NH |
Globespotter wrote: |
WD-40 seems to have lovers and haters. It is marketed as a lubricant, that leaves oil behind, so not just water displacement. All I can say is that for now, it did the job. |
I use engine oil on rear hinge. The rear hinge has two separate bushings, one visible at the door and the other under the sliding door cover. Both need a good baptism of engine oil. Wipe off residual oil drooling over the next week or so with great gladness.
Colin _________________ www.itinerant-air-cooled.com |
Tcash Samba Member
Posted: Thu Jun 23, 2016 2:42 pm Post subject: Re: On the road in NH |
It does leave lubricant behind. It isn't a great penetrant, there are better things.
Originally designed to stop rockets from rusting... _________________ .ssS! |
Posted: Thu Jun 23, 2016 1:13 pm Post subject: Re: On the road in NH |
I squirted WD-40 in the lock and latch, and it is great now. Thanks. Should be ok for the trip. |
That will stay longer than silicone. Bravo Zulu. _________________ .ssS! |
cmonSTART Samba Member
Posted: Thu Jun 23, 2016 10:53 am Post subject: Re: On the road in NH |
+1 o. John's.. that guy has everything.
You're a couple hours north of me, otherwise I would come say hello. _________________ '78 Bus 2.0FI
de K1IGS |
