lecktrix Samba Member
Posted: Tue Jun 21, 2016 10:33 am Post subject: Re: Rear IRS engine mount repair advise needed |
Thanks guys!!... I just stripped them down... Got the welder out, fixed cracks, made the curve notch for the CV clearance, and reinforced the bottom with some 1/8 inch pipe cut in half. |
weasel_ugs Samba Member
Joined: March 16, 2012 Posts: 721 Location: Prescott Valley,Az.
Posted: Thu Jun 16, 2016 11:30 pm Post subject: Re: Rear IRS engine mount repair advise needed |
just what the doctor ordered! |
GoMopar440 Samba Member
Joined: February 06, 2015 Posts: 491 Location: Montana
Posted: Thu Jun 16, 2016 10:39 pm Post subject: Re: Rear IRS engine mount repair advise needed |
weasel_ugs wrote: |
I have seen tubular replacement frame horns, I cant remember who makes them so hopefully someone will post up a link to those. |
Acme/Berrien makes them. They're about $100.
http://acmecarco.com/store/index.php?main_page=product_info&cPath=21&products_id=3461 _________________ Homemade rail for street & off road: BJ front beam (bent), IRS rear (boxed/maybe bent), stock T1 DP 1600, 009, 34PICT-3 (soon to be dual 40HPMXs), 4-1 glass pack exh, T3 brakes (F disk, R drum & Dual MC), Bug trans (002, 5 rib going in soon).
Link to my rail (re)build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=629493 |
cbeck Samba Member
Posted: Wed Jun 15, 2016 7:10 am Post subject: Re: Rear IRS engine mount repair advise needed |
I think you can get replacement frame horns at appletree. |
Posted: Tue Jun 14, 2016 6:45 pm Post subject: Re: Rear IRS engine mount repair advise needed |
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6767 Location: Northern California
Posted: Mon Jun 13, 2016 10:25 pm Post subject: Re: Rear IRS engine mount repair advise needed |
As Joe described, much simpler than replacing horns and probably straighter
http://www.thesamba.com/vw/forum/viewtopic.php?t=451376
jsturtlebuggy Samba Member
Posted: Mon Jun 13, 2016 9:18 pm Post subject: Re: Rear IRS engine mount repair advise needed |
Looks like someone did a hack job to clear early swing axle frame horns for CV joints. Clean off the paint and crap and see if there are any cracks anywhere else.
If not just cut out area for the CV clearance and weld in 1/8in flat strap or plate to fix it. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
Posted: Mon Jun 13, 2016 8:01 pm Post subject: Rear IRS engine mount repair advise needed |
Hello all... Just bought this buggy and found out it has some serious issues.... In my mind its a scrap, but maybe theyres a trick fix for this issue. Iv been out of the bug world for 20 years.... My last was a 56 Oval Rag... And I wish I never sold it. But anyways... Please look at pictures and hopefully someone has some good advice for fixing. I have no problem fabricating, welding, etc. Work doesnt scare me, just want it to be safe.
Thanks!!
Craig
