KKiley Samba Member
Joined: March 08, 2016 Posts: 662 Location: Aruba, Jamica, nope, Kokomo
Posted: Sat May 21, 2016 1:49 pm Post subject: 78 SB FI diagnostics, step 3, almost there |
I am reinstalling my engine, but I didn't remove it and need some help with the wiring.
I don't know which wire goes to each injector. I know the side, and I am sure they need to be on the correct cylinder. Need some guidance.
In this image, does the fuel pressure line go here? and what is the wire I have marked?
Are these ground wires?
2 wires and the throttle cable. I think I am missing some pieces to hook the cable up. I have the set piece for the end of the cable
Throttle assembly and a vacuum port.
I have been searching a lot. Hard to find a motor just like mine. I think I am finding where all the EGR and lines go, the ones I have questions about are the fuel pressure and the surge valve.
Any help would be greatly appreciated. Hard to do when I didn't take it apart. Engine has a new crank, bearings, flywheel, clutch, pressure plate, throw out bearing, new tranny main seal. It's close to being done.
Thanks![/img][/url]
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51171 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat May 21, 2016 3:43 pm Post subject: Re: 78 SB FI wiring |
Quote: |
I don't know which wire goes to each injector. I know the side, and I am sure they need to be on the correct cylinder |
Nope, doesn't matter since they all fire at once.
Quote: |
does the fuel pressure line go here? |
If you mean the line from the pump, yes. Got a grommet for where it goes through the tin?
Quote: |
and what is the wire I have marked? |
Looks like the tail light ground, is it brown?
Quote: |
Are these ground wires? |
Yes, they all screw on to the alternator body near the strap.
Quote: |
2 wires and the throttle cable. |
The black ones go on coil terminal #15, can't see what color the others are except for something yellow, VW didn't put that there, what color is it spliced to? The throttle cable attaches with a short clevis through the arm and a long nut on the end of the cable.
Quote: |
Throttle assembly and a vacuum port |
Can't find the vacuum diagram right now, but the EGR, FPR and sometimes the distributor retard all Tee together usually. Is there another port higher up on the throttle body as well? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
Posted: Sat May 21, 2016 3:48 pm Post subject: Re: 78 SB FI wiring |
Did you put in a new engine compartment seal while it was out? It looks like it is missing in your first pic, pretty important to have it installed...
Also put some hose clamps on the manifold rubber hose where it attaches to the plenum.
Remember- brown=ground for VW.
The first pic brown wire should go to a tab that is spot welded to the left hand side of the engine bay near the wall close to where that big clear connector is. _________________ 73 super beetle thread http://www.thesamba.com/vw/forum/viewtopic.php?t=649622 Back on the Road!
Modify your Kadrons for SVDA http://www.thesamba.com/vw/forum/viewtopic.php?p=8115884#8115884
Cast iron VJU4BR8 SVDA reference thread- https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Need replacement filters for original Kadron aircleaners? WIX #42087 is a perfect fit, as is Napa Gold #2087! |
glutamodo The Android
Joined: July 13, 2004 Posts: 26325 Location: Douglas, WY
Posted: Sat May 21, 2016 5:12 pm Post subject: Re: 78 SB FI wiring |
Do you have the metal conduit tube for the throttle cable to go through the fan shroud? _________________ Andy T.
KKiley Samba Member
Posted: Sat May 21, 2016 5:23 pm Post subject: Re: 78 SB FI wiring |
You guys are great. Making good progress today. A few more questions.
I need to hook up this temp sensor and I don't know what plugs into this plastic plug:
Here are my remaining wires:
I am guessing that the blue wire goes to the oil pressure sensor
And I was going to ask what this was:
I am guessing it goes thru the shroud for the accel cable. I still don't know how to hook the cable to the throttle body.
It does have the engine compartment seal at the back of the engine. I hope I can install the one around the rest of it without pulling the engine. It looks like I should be able too.
I really do appreciate the help. I am sure more questions will follow.[/url] |
Dwayne1m Samba Member
Joined: December 31, 2011 Posts: 3538 Location: Pennsylvania
Posted: Sat May 21, 2016 5:42 pm Post subject: Re: 78 SB FI wiring |
The throttle cable is threaded and it goes thru a barrel, then you put the nut on the end.
Posted: Sat May 21, 2016 5:45 pm Post subject: Re: 78 SB FI wiring |
Yes that's the accel cable tube. What other pieces do you have?
The wire for the oil pressure switch is blue with black stripe. FYI, here's a wiring diagram, the Bentley (do you have the Bentley manual?) is in black/white but I colored this one in:
Black is terminal 15 (coil)
http://www.thesamba.com/vw/archives/info/wiring/76-79113wiring.jpg
http://www.thesamba.com/vw/archives/info/wiring/76-79113wiring-key.jpg
If the connector hoses on the manifold are in good shape, no need for any clamps on them, VW did not use clamps on those on EFI.
Engine compartment seals usally easier to deal with if the engine is removed. You said "back of the engine"... when we say "back" and "front" we refer to the entire vehicle. So did you mean the firewall seal at the FRONT OF CAR part of the engine? _________________ Andy T.
Posted: Sat May 21, 2016 6:11 pm Post subject: Re: 78 SB FI wiring |
The temp sensor 2 plugs into that white wire with the rectangular plastic end on it.
The other white wire wire goes on coil terminal #1. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
KKiley Samba Member
Posted: Sat May 21, 2016 8:21 pm Post subject: Re: 78 SB FI wiring |
Just so you guys don't think I am completely inept, here is where I started:
The flywheel broke off the crankshaft, so a complete teardown was in order:
Took it all the way down, had the block checked, new crank, mains and rod bearings, flywheel and new clutch assembly. I cleaned every single part on this engine and painted most of them.
As it sits tonight:
I am just taking my time and cleaning, painting, checking every part, no hurry to finish. Electrical is not one of my talents, so here I am
Here's what it is going in:
KKiley Samba Member
Posted: Fri Jun 03, 2016 6:44 pm Post subject: Re: 78 SB FI wiring, update phase 2 |
So, thanks to the great help from the forum, we have an engine installed. We also seem to have 2 of the 3 basics covered: Compression and spark:
I know the wiring is not pretty and I have some items to replace, but I wanted to get a battery in it and at least try turning it over. It does crank, and I pulled a plug wire and confirmed I have spark, did a basic timing set and nada as far as a hint of firing from the engine.
I didn't hear a thing as far as the fuel pump went, so I got underneath it and found this (it was laying on the suspension)
I had already pulled the gas tank to make sure it was ok, and I think it must have been replaced, because it was extremely clean inside. But having the fuel pump unbolted tells me something must be going on. I did a direct wire to the fuel pump and it does operate, so that is good news.
I found a good link on this site to start with:
http://itinerant-air-cooled.com/viewtopic.php?t=54...highlight=
I don't have a whiff of gas yet, so it's fuel injection 101 time. Any basic testing tips would be appreciated, as I search the forum for help.
Thanks!
Kevin |
KKiley Samba Member
Posted: Fri Jun 03, 2016 6:48 pm Post subject: Re: 78 SB FI wiring, update phase 2 |
My initial thoughts are:
check cold start injector
checking injectors for voltage
checking injectors for spray
I'd like to see they are capable of spraying gas, because they could have been sitting for 7 years at this point. |
Posted: Fri Jun 03, 2016 10:25 pm Post subject: Re: 78 SB FI diagnostics, step 2 |
Start by shoving a chopstick into the AFM inlet (air filter lid and element removed) and depressing the flap in there while the key is on and listen for the fuel pump, or at least a click. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
KKiley Samba Member
Posted: Fri Jun 03, 2016 11:34 pm Post subject: Re: 78 SB FI diagnostics, step 2 |
Ok, did that, nothing, not a sound... |
KKiley Samba Member
KKiley Samba Member
Posted: Sat Jun 04, 2016 8:13 am Post subject: Re: 78 SB FI diagnostics, step 2 |
Does the ECU just lay under the carpet loose like this? I have it turned in the pic
KKiley Samba Member
Posted: Sat Jun 04, 2016 8:33 am Post subject: Re: 78 SB FI diagnostics, step 2 |
Since I have moved from wiring the engine to the fuel injection system, should I start a new thread? Or move it to a different forum? |
KKiley Samba Member
Posted: Sat Jun 04, 2016 9:13 am Post subject: Re: 78 SB FI diagnostics, step 2 |
Ok, step 2 was checking for voltage at the fuel pump and cold start valve when cranking it over. No voltage... |
KKiley Samba Member
Posted: Sat Jun 04, 2016 10:09 am Post subject: Re: 78 SB FI diagnostics, step 2 |
Temp Sensor 2 has a reading of 65 ohms, not good |
Posted: Sat Jun 04, 2016 10:45 am Post subject: Re: 78 SB FI diagnostics, step 2 |
KKiley wrote: |
Any chance that black relay on the left in the pic is full of water?, is the fat red wire leading forward from it connected to the battery or starter stud?, is the little brown wire connected to the negative battery post?, are all the white ground wires with ring teminals screwed down to the alternator body near the strap? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
