Porsche 914 and Bus engine differences
Aass2505
Aass2505 is offline
PostPosted: Thu May 19, 2016 2:04 pm    Post subject: Porsche 914 and Bus engine differences Reply with quote
Hi Is there a difference between the engine Porsche 914 2.0l and 2.0l engine Volkswagen bus
raygreenwood
raygreenwood is offline
PostPosted: Thu May 19, 2016 3:44 pm    Post subject: Re: porsche 914 Reply with quote
Yes.
With regard to just the mechanical parts first:
The engine cases except for some very minor casting differences that make no difference at all......the engine cases are identical.
The piston rods, crank, bearings and oil pump are identical.
The cylinders are identical.
The pistons themselves.....are different.
The heads are very different. Different plug angle, the 914 valves are 42mm x 36mm the bus are 39mm x 33mm
The cam is totally different.
The fan is the same except for timing marks. The cooling manifold is largely the same except for the timing mark hole. The alternator is the same.
Because the 914 is mid engine and has different plug angles......most of the sheet metal and the heat exchangers are different.
Now.....if you have a 914, have a 1.7 or 1.8L case...and/or have all of the sheet metal etc from those engines. ....and have access to the crank and rods from a bus 2.0.....you can buy new 2.0 repro heads on new castings from HAM inc......not cheap but actually better than stock 914 2.0 heads........and you can build a 2.0 914 engine.
Ray
porkchop-rob
porkchop-rob is offline
PostPosted: Fri May 20, 2016 2:29 pm    Post subject: Re: Porsche 914 and Bus engine differences Reply with quote
Rarely do you see such a complete and helpful response to an open ended question like this!
Cheers to Ray for the super detailed response.
1965 Beetle
1968 Beetle Baja (Son's First Car)
1976 Bus with Subaru (Wife's Riviera Camper)
raygreenwood
PostPosted: Fri May 20, 2016 6:59 pm    Post subject: Re: Porsche 914 and Bus engine differences Reply with quote
Why thank you!......I will expect my bill to be paid promptly. .... Laughing
Ray
Wolfgangdieter
Wolfgangdieter is offline
PostPosted: Sat May 21, 2016 5:56 pm    Post subject: Re: Porsche 914 and Bus engine differences Reply with quote
Oil dipstick and filler are different. Early T2 had dual Solex carbs stock while ALL US 914 were FI. The carb and FI cams and distributors were different too. The 914 had FI trigger in distributor. Since T2 were lower compression (dished pistons) hence they produced less HP. And of course the heat exchangers and engine hangers were different since engines pointed in different directions. You'll see the boss for a mechanical fuel pump too on 914 engines which was never used since FI took a high pressure fuel pump.
CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy
raygreenwood
PostPosted: Sat May 21, 2016 10:04 pm    Post subject: Re: Porsche 914 and Bus engine differences Reply with quote
Yes.....thank you for the little details....I was being lazy.....Wink
Ray
old DKP driver
old DKP driver is offline
PostPosted: Thu Jun 02, 2016 10:17 pm    Post subject: Re: Porsche 914 and Bus engine differences Reply with quote
Ray is a superb type-4 poster Razz
V.W.owner since 1967
raygreenwood
PostPosted: Thu Jun 02, 2016 10:32 pm    Post subject: Re: Porsche 914 and Bus engine differences Reply with quote
Its a fetish.....now if I could only get my engines to love me.....Wink
Ray
old DKP driver
PostPosted: Thu Jun 02, 2016 10:42 pm    Post subject: Re: Porsche 914 and Bus engine differences Reply with quote
Same here RAY,
Let bygones be bygones
You are truly an asset. Very Happy
