IndyCrosstrek Samba Member
Posted: Sat May 28, 2016 9:51 pm Post subject: Re: Allstate by Sears '73 two wheel restoration-where do you source? |
Lastly, updated photo of the unit
Red Fau Veh Samba Member
Joined: September 07, 2012 Posts: 3037 Location: Prescott Az.
Posted: Fri May 27, 2016 9:54 am Post subject: Re: Allstate by Sears '73 two wheel restoration-where do you source? |
That is awesome! _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
1973 Orange transporter stock type 4 with dual 40 Dellortos and Empi single quiet pack
1969 Adventurewagen blue whale Gene Berg 1776 built by Dave Kawell dual 36 DRLA's, Vintage Speed exhaust, Bosch 019 screamer
1961 Swivel Seat camper, L345 grey
Touch Nicks Thing wrote: |
Swivel Seat panels are for people with no friends |
MonT3 Samba Member
Joined: January 07, 2012 Posts: 1988 Location: South Dakota
Posted: Fri May 27, 2016 7:57 am Post subject: Re: Allstate by Sears '73 two wheel restoration-where do you source? |
Red Fau Veh wrote: |
Thanks, I saw the Shinco ones are like 50 bucks. I just wonder where are the Continentals made, and are they dot approved. the others are obviously Chinese or something like that, but see if they are dot also please because that price is low and it could be a great tire plus a spare or two would be cheap. I only have single wheels. |
Sent an inquiry into the Conti tires from Scooterworks as well as the ScooterWest. Here's Scooterworks response
I asked an additional question on the where the tire was made. The response from Andy, "I’m not sure. Continental is a German company but their tires are made in several factories all over the world."
You can inquire with similar questions or give them a buzz. Don't think those tires are a bad deal. But, don't take my word for it as I haven't ordered them yet but that's what I'm looking at to outfit my trailer. Good luck with your search.
Sorry for the highjack _________________ MonT3
67 Squareback
64 Squareback
63 Squareback
Engine rebuild
Trailer rebuild |
Posted: Thu May 26, 2016 11:07 pm Post subject: Re: Allstate by Sears '73 two wheel restoration-where do you source? |
Thanks, I saw the Shinco ones are like 50 bucks. I just wonder where are the Continentals made, and are they dot approved. the others are obviously Chinese or something like that, but see if they are dot also please because that price is low and it could be a great tire plus a spare or two would be cheap. I only have single wheels. _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
MonT3 Samba Member
Posted: Thu May 26, 2016 8:28 pm Post subject: Re: Allstate by Sears '73 two wheel restoration-where do you source? |
I only know of the Coker site and that price is the same basically but I don't know of any compatible Continental tires, are you sure they are dot and use tubes? |
I do believe they use tubes. However the DOT piece I'd need to get clarification on. These are scooter tires so I'd think they'd need to be. I'll reach out and send a message on the specific tire and ask if they are DOT rated. _________________ MonT3
67 Squareback
64 Squareback
63 Squareback
Engine rebuild
Trailer rebuild |
Posted: Thu May 26, 2016 10:58 am Post subject: Re: Allstate by Sears '73 two wheel restoration-where do you source? |
I only know of the Coker site and that price is the same basically but I don't know of any compatible Continental tires, are you sure they are dot and use tubes? _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
MonT3 Samba Member
Posted: Tue May 24, 2016 1:34 pm Post subject: Re: Allstate by Sears '73 two wheel restoration-where do you source? |
That's cool, what tires that use tubes did you get? The only ones I know of are the Cushman scooter tires from Coker. They are street legal and use tubes, and rated for some speed. No other tires have all that from what I can find. And don't run tubes in tubeless tires unless you find some that are made for it, they will heat up and fail. |
I haven't bought my tires yet as my trailer's in the build stage but I'm leaning on the Continentals. I did see the cushman tires on
http://shop.ruppparts.com/480x8-Scooter-Minute-Miser-tire-wide-whitewall-ww480cushtire.htm
but after working up cost, I found the shipping charges were a bit too much. I had 5 tires shipped from SC to SD for less that 3 trailer tires so I continued to shop until I found what I think is reasonable. If you found another site offering these tires, please share it as I'd like to take a look at it. _________________ MonT3
67 Squareback
64 Squareback
63 Squareback
Engine rebuild
Trailer rebuild |
Posted: Mon May 23, 2016 3:01 pm Post subject: Re: Allstate by Sears '73 two wheel restoration-where do you source? |
That's cool, what tires that use tubes did you get? The only ones I know of are the Cushman scooter tires from Coker. They are street legal and use tubes, and rated for some speed. No other tires have all that from what I can find. And don't run tubes in tubeless tires unless you find some that are made for it, they will heat up and fail. _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
Posted: Mon May 16, 2016 8:21 pm Post subject: Re: Allstate by Sears '73 two wheel restoration-where do you source? |
Was able to find factory bearings and races, and compatible tires and tubes. Back on the road! Thanks all |
MonT3 Samba Member
Posted: Tue May 10, 2016 8:20 pm Post subject: Re: Allstate by Sears '73 two wheel restoration-where do you source? |
IndyCrosstrek wrote: |
Anyone know how to get wheels off to inspect the bearings/grease? Caps are on pretty tight don't want to damage. |
I used some channel locks to pried mine off. Single nut with a cotter pin. Since I was replacing everything, it didn't matter much to me. Take your time with them. Good luck with your inspection and keep everything1 _________________ MonT3
67 Squareback
64 Squareback
63 Squareback
Engine rebuild
Trailer rebuild |
Posted: Tue May 10, 2016 11:22 am Post subject: Re: Allstate by Sears '73 two wheel restoration-where do you source? |
MonT3 Samba Member
Posted: Mon May 09, 2016 7:31 pm Post subject: Re: Allstate by Sears '73 two wheel restoration-where do you source? |
I'm with you on the hub conversion idea. I don't have experience with this type of single-bolt mounted wheel trailer, but I like the idea of hubs with at least 4 lugs, for simplicity of sourcing components. Though I'm geeking out a bit over the original hubs, wheels and tires. |
Folks like going OG with it all and that's cool. I looked for those pieces and found them after spending the money on the new stuff. The spindle size drove me that way but I'm ok with it as I like trying to keep that thing current with the old vibe since I'll be pulling it. my trailer is going to be near new as the floor and sub-frame was rotted as well as the top piece. I'll be hitting mine up soon and can't wait!
Oh, sorry for my spelling errors in my earlier post. _________________ MonT3
67 Squareback
64 Squareback
63 Squareback
Engine rebuild
Trailer rebuild |
Posted: Mon May 09, 2016 12:21 pm Post subject: Re: Allstate by Sears '73 two wheel restoration-where do you source? |
Posted: Mon May 09, 2016 12:14 pm Post subject: Re: Allstate by Sears '73 two wheel restoration-where do you source? |
Thank you for such a thoughtful and detailed response. I will check out all of these resources. |
MonT3 Samba Member
Posted: Sat May 07, 2016 4:15 pm Post subject: Allstate by Sears '73 two wheel restoration-where do you source? |
Folks,
Bought a 1973 Allstate by Sears utility trailer with home-made storage top. Purchased from the original owner. Overall, it was in good shape. I know several of you are into these and wondered where you source wheels, tires and bearings or other parts? This one has the original wheels and tires.
I need to at least start by greasing the bearings and wondered what the trick is. One sounds like it might be going bad due to a faint rhythmic, almost bearing like noise.
So far:
Grinded all rust, primed and painted underbody, bed, sides, tailgate and fenders
Cleaned, re-caulked and repainted top sides. Kept historic decals and added a few of the vintage.
New, safer coupler, wiring, and security chains.
