Pertronix for VJUR 4 BR8 distributor
ghia_67
ghia_67 is offline
PostPosted: Wed Mar 09, 2016 7:37 am    Post subject: Pertronix for VJUR 4 BR8 distributor Reply with quote
I'm converting a 1960 30 horse to 12volt using a 356 small case generator.
I really want to run 12 volt electronic ignition in the original vacuum advance dizzy, which is a VJUR 4 BR8 but i can't seem to find one that states it's for this use.
Does anyone know which is the right kit or which kit i could use?
Would a Pertronix 1844 as used in a Bosch 010 work? I know that's not a vacuum advance dizzy but it is 2 piece points and I can't for the life of me work out how the dizzy gets it's advance curve would effect the ignition module?
Any help would be appreciated
Cheers
Steve
tasb
The Distributor Distributor
tasb is offline
PostPosted: Wed Mar 09, 2016 9:10 pm    Post subject: Re: Pertronix for VJUR 4 BR8 distributor Reply with quote
Hello Steve, I don't believe anyone makes a points replacement module for the VJU 4 BR 8 Beetle distributor. They are available for the VJ 4 BR 8 Bus distributor because it's the same unit as fitted to the 019 and 010. The points are a different design on the bus distributor.
Roads Scholar &
ghia_67
ghia_67 is offline
PostPosted: Thu Mar 10, 2016 9:58 am    Post subject: Re: Pertronix for VJUR 4 BR8 distributor Reply with quote
Thanks for the reply tasb
I've been in touch with Hotspark and they say they have a unit the will fit with a small amount of filing. I'm going to give it a go and will report back if it works
Cheers
Steve
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Thu Mar 10, 2016 10:51 am    Post subject: Re: Pertronix for VJUR 4 BR8 distributor Reply with quote
The Pertronix 2843 should fit the VJU4BR8.
I would stay away from hot spark.
Glenn
Member #1009
#BlueSquare
ghia_67
ghia_67 is offline
PostPosted: Fri Mar 11, 2016 6:58 am    Post subject: Re: Pertronix for VJUR 4 BR8 distributor Reply with quote
Thank you Glenn, I was hoping you would reply, you are Mr Distributor! I'll order up the Pertronix
Cheers
Steve
D-train
D-train is offline
PostPosted: Sat Mar 19, 2016 12:05 am    Post subject: Re: Pertronix for VJUR 4 BR8 distributor Reply with quote
I'm running a 6v version in my distributor, works well. Not running the flame thrower tho, using it with a judson coil an have no problems.
shiny paint doesnt make it worth any more
Mr. 010
Glenn is offline
PostPosted: Sat Mar 19, 2016 5:03 am    Post subject: Re: Pertronix for VJUR 4 BR8 distributor Reply with quote
Just note that the 6v versions can have problems if the voltage drops below 6v. I've had Porsche owners tell me they had engine missing when driving in the rain with the headlights on.
Glenn
Member #1009
#BlueSquare
jdub63
jdub63 is offline
PostPosted: Sat Mar 19, 2016 7:52 am    Post subject: Re: Pertronix for VJUR 4 BR8 distributor Reply with quote
So will the Pertronix #91844 work with a Bosch 010 in a 12 volt system? Does it matter 12v or 6v??
Mr. 010
Glenn is offline
PostPosted: Sat Mar 19, 2016 8:35 am    Post subject: Re: Pertronix for VJUR 4 BR8 distributor Reply with quote
I'm pretty sure the 91844 is 12v and yes it does matter. You can't run a 12v in a 6v and visa versa.
Glenn
Member #1009
#BlueSquare
D-train
D-train is offline
PostPosted: Sat Mar 19, 2016 10:26 pm    Post subject: Re: Pertronix for VJUR 4 BR8 distributor Reply with quote
Glenn, I've had the elecs rebuilt. Drive it as a daily so there is times that the lights/wipers/semaphores are all on with no problems yet.
Schnage
Schnage is offline
PostPosted: Wed Apr 27, 2016 11:50 pm    Post subject: Re: Pertronix for VJUR 4 BR8 distributor Reply with quote
Hello, is the pertronix really working with a 6v judson magneto?
D-train
D-train is offline
PostPosted: Thu Apr 28, 2016 12:14 am    Post subject: Re: Pertronix for VJUR 4 BR8 distributor Reply with quote
Sure is. No problems with it.
