bugheadred Samba Member
Posted: Thu Sep 21, 2017 5:59 pm Post subject: Re: working on the 67 |
67ctbug wrote: |
Hey BugHead,
How did you fix this piece? On my '67 its gone and I'm lost for how to fix it. |
most of it with a new rear quarter panel and the made the rest by hand |
67ctbug Samba Member
Posted: Wed Sep 20, 2017 4:27 am Post subject: Re: working on the 67 |
Hey BugHead,
How did you fix this piece? On my '67 its gone and I'm lost for how to fix it. _________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote: |
mukluk wrote: |
Posted: Tue Sep 19, 2017 9:23 pm Post subject: Re: working on the 67 |
out in the sun ! it hasn't been out in the sun in 2 years. |
Posted: Sun Dec 04, 2016 7:40 pm Post subject: Re: working on the 67 |
sad to have to put this car out (for now ) I need to work on the 1960 |
Posted: Sat Jul 30, 2016 6:28 pm Post subject: Re: working on the 67 |
Posted: Thu Jul 21, 2016 12:10 pm Post subject: Re: working on the 67 |
Posted: Mon Jul 04, 2016 8:39 pm Post subject: Re: working on the 67 |
Posted: Tue Jun 07, 2016 8:03 pm Post subject: Re: working on the 67 |
next |
Posted: Tue Jun 07, 2016 4:24 pm Post subject: Re: working on the 67 |
last patch drivers side hf mig wire works well |
Posted: Sun Jun 05, 2016 10:42 pm Post subject: Re: working on the 67 |
ran out of mig wire going to give harbor freight wire a try |
Posted: Tue May 31, 2016 9:25 am Post subject: Re: working on the 67 |
Digger89L wrote: |
Nice work on the panel replacement work. Can't really tell from the photos ...I can see that you are not 'butt-welding' the replacement panels to the existing body panels, so are you flanging the body-side of the metal and then doing a lap-joint weld?? If you are flanging, what tool are you using? I need to do this exact same work on my 66 bug, so looking for a little more detail ..... |
60's Burnout Samba Member
Joined: December 10, 2006 Posts: 424 Location: SF Bay Area
Posted: Mon May 30, 2016 11:36 pm Post subject: Re: working on the 67 |
OP, where do you live? Must be salt country from what I've seen. I've got a '67 bug, California all it's life. It's intact. Want to buy it? |
Digger89L Samba Member
Joined: May 16, 2013 Posts: 1130 Location: Western Canada (SK)
Posted: Sat May 28, 2016 7:48 pm Post subject: Re: working on the 67 |
Nice work on the panel replacement work. Can't really tell from the photos ...I can see that you are not 'butt-welding' the replacement panels to the existing body panels, so are you flanging the body-side of the metal and then doing a lap-joint weld?? If you are flanging, what tool are you using? I need to do this exact same work on my 66 bug, so looking for a little more detail ..... _________________ "If you can't fix it with pop rivets, crazy glue and duct tape, or hold it together with zip ties, velcro or magnets, it REALLY is broken." |
Posted: Mon May 23, 2016 11:37 am Post subject: Re: working on the 67 |
Digger89L wrote: |
I can get a Cleico-like result using pop-rivets ...same process: line up the work, drill a hole, pop in a rivet ..etc. etc. And then, after most of the welding is done, simply grind off the rivet with a flap disk, and plug-weld the hole. Works especially well in situations where you can easily retreive the pop rivet stubs so they don't end up rattling around inside the body somewhere. Red-neck Cleicos, I guess .... |
Cleicos you can reuse there spring loaded so it brings the panels tight together and I can take the panel on and of for fitting without drilling out rivets and a kit costs about 20.00 or less but yes you could use rivets I have and don't think they work as well |
Posted: Mon May 23, 2016 11:19 am Post subject: Re: working on the 67 |
I can get a Cleico-like result using pop-rivets ...same process: line up the work, drill a hole, pop in a rivet ..etc. etc. And then, after most of the welding is done, simply grind off the rivet with a flap disk, and plug-weld the hole. Works especially well in situations where you can easily retreive the pop rivet stubs so they don't end up rattling around inside the body somewhere. Red-neck Cleicos, I guess .... _________________ "If you can't fix it with pop rivets, crazy glue and duct tape, or hold it together with zip ties, velcro or magnets, it REALLY is broken." |
Posted: Sun May 22, 2016 1:21 pm Post subject: Re: working on the 67 |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9798 Location: Oregon
Posted: Tue Apr 12, 2016 8:43 pm Post subject: Re: working on the 67 |
[email protected] wrote: |
been having a hard time getting to work on the car had a gout attack . but did get a little time to get out there today no pic worthy progress but it did feel good to get out there |
Dude, I feel your pain. I too suffer from gout from time to time. I can deal with it in my feet. But when I get an attack in the knees. It's all over. I'm down for at least four days. It sucks.
Get well and work on your 67 when you can. It all takes time to complete.
I wish you well. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Tue Apr 12, 2016 8:12 pm Post subject: Re: working on the 67 |
Posted: Sat Mar 12, 2016 9:44 pm Post subject: Re: working on the 67 |
Posted: Thu Mar 03, 2016 8:01 pm Post subject: Re: working on the 67 |
yes I am this is a cool car Zenith blue 67 I have had it a few years I paid 300.00 for it . new floors heater channels . need a new front clip. but I even have the window tag for it . I don't have the original motor but I do have one out of a 67 (with all the tin work) |
