CiderGuy Samba Member
Joined: December 23, 2013 Posts: 1351 Location: Bucks County, Pa
Posted: Wed Aug 15, 2018 3:56 pm Post subject: Re: Fun with my 71 Ghia project |
Any updates ? Post some pictures, its been awhile... |
SoCalJes Samba Member
Joined: November 02, 2011 Posts: 1093 Location: Broward, FL
Posted: Tue Sep 12, 2017 5:06 pm Post subject: Re: Fun with my 71 Ghia project |
I think there is a pretty good count that got either pushed inland or sunk. _________________ Jesse
71 Ghia
______________________________________
Just because it didn't come that way, doesn't mean it shouldn't have. |
Posted: Tue Sep 12, 2017 3:30 pm Post subject: Re: Fun with my 71 Ghia project |
Good to hear everyone came out on the other side OK. I had a 34 foot sailboat that was hulled and moved 3 city blocks by super storm Sandy. The 12,500 boat had been pulled from the water prior to the storm. _________________ ----------------------
Cars Currently Owned:
1970 Karmann Ghia Coupe
1973 Karmann Ghia Coupe - Project car for sale
1970 Karmann Ghia Convertible (Body off restoration)
Timing is everything |
Posted: Tue Sep 12, 2017 1:01 pm Post subject: Re: Fun with my 71 Ghia project |
kiwighia68 wrote: |
It's good to hear you're safe, Jesse.
I've been following your thread and I can't help thinking that when you finish the restoration/rebuild you're going to suffer withdrawal symptoms (like I did). |
Thanks buddy, much appreciated. Hopefully when/if I finish I will find something else interesting to build. _________________ Jesse
71 Ghia
Posted: Tue Sep 12, 2017 12:59 pm Post subject: Re: Fun with my 71 Ghia project |
So glad it wasn't nailed by anything...
The neighbors across the street are still on generators. A palm tree ripped their power lines for their entire block off the pole. FPL said it only effected 40 homes and was not a priority. I think it would be if they lived there! Getting a new carburetor for a generator I have to hand out for a couple of homes to share. _________________ Jesse
71 Ghia
kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2877 Location: Auckland, New Zealand
Posted: Tue Sep 12, 2017 12:55 pm Post subject: Re: Fun with my 71 Ghia project |
I've been following your thread and I can't help thinking that when you finish the restoration/rebuild you're going to suffer withdrawal symptoms (like I did). _________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
Posted: Tue Sep 12, 2017 12:47 pm Post subject: Re: Fun with my 71 Ghia project |
Thanks for checking up. We are doing fine now. We got power back up and internet today!!!!
I was freaking out because I still hadn't finished the air suspension electrical and air lines yet and my Ghia had to spend the hurricane in the driveway.
Happy to say not a single scratch even though the winds were strong enough to topple over 3 30 foot + trees over into the canal behind my house and rip the car cover off my Chrysler 300 to shreds.
Been supper busy running my business and life. I'll post some progress soon.
Hope everyone else here from Florida came out as blessed as we did. _________________ Jesse
71 Ghia
Posted: Mon Sep 11, 2017 9:52 pm Post subject: Re: Fun with my 71 Ghia project |
Its been a long time since you posted any updates. How is your car coming along, but more important are you and yours safe ? _________________ ----------------------
slalombuggy Samba Member
Posted: Sun Feb 12, 2017 8:47 am Post subject: Re: Fun with my 71 Ghia project |
Yes that's from my green Oval. it sits on a 70 pan with a 3.5" raised rear torsion housing.
I'll never point out things like this in malice, my only reasons would be in the name of safety or to save someone the trouble of spending money badly and having to do something again after a failure.
Cheers
brad |
Posted: Sun Feb 12, 2017 8:28 am Post subject: Re: Fun with my 71 Ghia project |
Thanks and you are 100% correct on your comments.
Those pictures were during mockup and a lot of things have changed since then. I have a bracket at the end of the hard line by the stainless now. Without it the weight of the stainless line how you see it on that picture would have slowly bent the hardline on every bump from its own weight. Also the strap in the middle of the soft line above the trailing arm is not tight and used more as a guide to keep them away from the bags and have free movement within it.
I have a tendacy to be vaige sometimes because I take for granted that everyone else has done things like this before but your comments will most likely save someone time and hartache.
Are those pics from your bug? Looks nice. I'm by no means a VW expert and this is the first one I've ever touched one so I honestly appreciate when you guys when you chime in. _________________ Jesse
71 Ghia
Posted: Sat Feb 11, 2017 9:44 pm Post subject: Re: Fun with my 71 Ghia project |
Hey Jesse, Your car is an inspiration. One thing about your brake lines. It looks like the line to the rear caliper is only solid on one end, braced in the middle and then the flexible line to the caliper at the other end, You should support both ends of the hardline, not just one end. On a part that moves constantly like a control arm, a set up like that will fatigue the brake line where it is braced in the middle. By supporting both ends you keep the line solid and then just let the S/S hose move with the caliper.
Best practice is to always mount a hardline solid at both ends
brad |
Posted: Sat Feb 11, 2017 7:36 pm Post subject: Re: Fun with my 71 Ghia project |
I'm pretty sure I got the manifold from AVS www.airbagparts.com
They pretty much have whatever you could possibly need to bag anything.
I found a couple of pictures of when I was mocking up the rear suspension. Yes I'm running 1/4 lines on all 4 corners. And don't forget to use an air muffler for your manifold unless you want to make your car sound like a Peterbilt truck bleeding the air brakes
I'm using narrowed rear trailing arms so it might look a little different.
It pretty much tucks all the way. Let me know if you need anything.
71 Ghia
xzener Samba Member
Posted: Sat Feb 11, 2017 5:42 pm Post subject: Re: Fun with my 71 Ghia project |
SoCalJes,
Where did you get that air ride solenoid manifold?? Are you running 1/4" lines? What are you using in the rear end? Been buying all my parts for air ride, mocked up a nice control system, just need to figure out a manifold and rear end setup. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
Posted: Fri Feb 10, 2017 1:56 pm Post subject: Re: Fun with my 71 Ghia project |
Got them in. The guy at the shop where I bought the pedals told me that he had seen someone else put these pedals in a Ghia before but that they had to do a whole bunch of cutting to get them in. I just sued a drill and a hole saw.
By the way if you want to do custom bends on your lines what I do is start with a piece of solid copper 12 gauge wire cut to the same length as the pipe that you need to fit in. I put in all the bends that I need on the cooper wire. Then I just get a brake/fuel line bender and I copy the copper wire's bends.
Now I just want to design a way of having a switch on the pedals for the brakes. The pressure switch on the distribution block will just be a safety backup switch.
71 Ghia
Posted: Tue Feb 07, 2017 2:50 pm Post subject: Re: Fun with my 71 Ghia project |
Close, but no cigar on the hydraulic pedal assembly today...
Everything is looking good as far as clearance. At least I'm that much closer.
71 Ghia
Posted: Fri Jan 27, 2017 3:20 pm Post subject: Re: Fun with my 71 Ghia project |
Yeah you're so right! I chipped the hell out of the door pillar between the front and rear door getting into my 300 with the hammer of a Beretta 9mm I used to carry on my hip. It's in a pretty big double car garage and its the only car in there. If I trip Ill try to steer my body towards some other less lamentable object
I'm a bit or a realist and what is done is done, worrying about it is not going to make things better.
If it can be fixed great, nothing to worry about since it can be fixed. If it can not be fixed, then there is nothing to do.
I say keep your chin up, put your tail between your legs, fix it and move on. Now if you haven't learned from it and continue to do the same failure well there is a name for that. _________________ Jesse
71 Ghia
KGCoupe Samba Member
Joined: July 01, 2005 Posts: 3580 Location: Putting the "ill" and "annoy" in Illinois
Posted: Fri Jan 27, 2017 6:19 am Post subject: Re: Fun with my 71 Ghia project |
SoCalJes wrote: |
kiwighia68 wrote: |
SoCalJes wrote: |
I have been using these rivets to mount everything around the car except the mirrors so I think I'm going to borrow that idea from you... |
Remember to fix a reinforcing panel of metal on the inside of the door skin for the day some drunk stumbles against your door mirror and bends the (thin) sheet metal of the door skin. Maybe an inch and a half wide and three inches long. |
Hopefully since this will never be a daily driver I'll be lucky since it will never sit at a parking lot anywhere. It will sit in a garage and come out for some high octane, raise some hell on weekends and back to the garage.
Mostly not because I think it's some priceless jewel but because there is no way to do a touch up on candy paint. If you get some damage you need to reshoot the entire car.
If I can get to the fabric store I want to get the headliner up this weekend. I was looking through your posts on covering the pillars. Great work! Hopefully I can get through the whole thing without getting pulled away. |
So are we to assume this means that you will never stumble through your own garage?
The only thing worse than having some stranger accidentally damage your car is accidentally damaging it yourself.
Posted: Thu Jan 26, 2017 4:16 pm Post subject: Re: Fun with my 71 Ghia project |
kiwighia68 wrote: |
SoCalJes wrote: |
If I can get to the fabric store I want to get the headliner up this weekend. I was looking through your posts on covering the pillars. Great work! Hopefully I can get through the whole thing without getting pulled away. _________________ Jesse
71 Ghia
Posted: Thu Jan 26, 2017 3:31 pm Post subject: Re: Fun with my 71 Ghia project |
SoCalJes wrote: |
Remember to fix a reinforcing panel of metal on the inside of the door skin for the day some drunk stumbles against your door mirror and bends the (thin) sheet metal of the door skin. Maybe an inch and a half wide and three inches long. _________________ Festina lente - hasten slowly
Posted: Thu Jan 26, 2017 2:49 pm Post subject: Re: Fun with my 71 Ghia project |
[quote="Evil_Fiz"]
I like the way you think
It already has a turbo and it gets out of it's own way pretty good. I think the only thing I will do to this one is just replace the stock exhaust with 3" all the way back to the tips though. I grew up with a passion for Chevys by the time I was 19 I had a 10.5 second 1978 Z28 and always looked down at Fords. Now I bought one so I guess its true what they say "Never say never"
I have been talking with my son about building a 1/4 mile track car. Hopefully it will keep him from racing on the street! _________________ Jesse
71 Ghia
