icelancer Samba Member
Joined: September 23, 2014 Posts: 149 Location: Square Bernardino, CA
Posted: Tue Sep 23, 2014 12:13 pm Post subject: New 71 squareback owner |
Hello everyone! I just recently purchased a 71 squareback. I drove the car 150 miles to my house! It's pretty solid but needs a lot of TLC. I have several cars and I am always working on something. This car is going to be my daily driver for now.
FI was already removed and replaced with 34ICTs. Tuned them but car still seems sad. Plan to rebuild and jet them soon.
Stock rims were bent beyond repair and were replaced with EMPI gasser 15x5.5 with 25 offset on 165/80/15s. Car seems to sit too high for my liking though.
After a month I have already learned a lot and will attempt to answer any questions.
Post will be updated when I make progress!
PICS!
On the way home after I bought it
Added auto trans kickdown +wire. Every bolt was loose from severely bent rims.
new seat upholstery soon whenever jbugs sends them...
cleaned rusty gauge rings and painted rusted insets black.
new rims _________________ 71 squareback (1904 A/T)
71 super beetle (1904 M/T)
B5.5 wagon M/T daily driver
SB for squareback or san bernardino....who knows. |
eyetzr Samba Member
Joined: October 09, 2013 Posts: 1426 Location: Toronto, Ontario. Canada
Posted: Tue Sep 23, 2014 12:32 pm Post subject: |
Welcome, nice ride, lots to do & see here. _________________ I think he meant "rare", as in "not well-done" |
Donnie strickland Samba Member
Joined: December 21, 2009 Posts: 2403 Location: Moody, AL
Posted: Tue Sep 23, 2014 4:37 pm Post subject: |
Nice!
I'm guessing neither your clock nor odometer are working? _________________ 71 Elm Green FI A/T Squareback |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22438 Location: Kimball, Mi
Posted: Tue Sep 23, 2014 7:19 pm Post subject: |
Welcome. That's a nice looking 71 you've got there.
Spend some time looking around the forum, as I'm sure there's some info you can use to help your car run better, drive better, stop better, and make it even more enjoyable. We're also here to help, if you get stuck on something, or just need a little kick in the butt to get motivated. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Thu Sep 25, 2014 2:10 am Post subject: |
Thanks for the positive feedback everyone.
I took the speedometer apart and a pin with 2 cogs is worn down. I took it out for now but I plan to get the gauge working properly one of these days. Odo stopped over 3 years ago according to title with 87k miles and engine has a type 1 dipstick. That is all I have pieced together so far. The clock only works when it feels like it.
No plans this week since the car is still running strong and I have to reassemble a 1200 T1 sandrail to sell it, but I will make a list to keep motivated.
To do:
Replace front seat pads and all seat covers
Fix fuel vapor leak into cabin/charcoal canister leak
Reassemble ventilation/heater system
Fix AT leak(s)
Make fiberglass heater vent covers and nice headliner clips
Replace damaged weatherstrips and window scrapers
Unpaint various pieces previous owner painted ford? blue _________________ 71 squareback (1904 A/T)
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34023 Location: Conejo Valley, CA
Posted: Thu Sep 25, 2014 9:42 am Post subject: |
A few Type-3 unique tips for safety and reliability:
- check the top torsion arm endplay. It is adjusted at the top right side. This is routinely neglected and creates both a safety hazard, extra wear, and sloppy steering.
- Check overflow/vent at the gas filler. This is often rotted and will let water and dirt into your fuel system. Also check the fat hose to the tank-- they often weep and to fix it you need the thin rubber sleeve inside replaced.
- as with any car this age, replace soft brake lines if there is any sign of wear... not just on the outside, but in brake behavior. |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17974 Location: Eugene, OR
Posted: Thu Sep 25, 2014 9:57 am Post subject: |
Most people just take out the charcoal filters/cap off the vents as they are always plugged up and ineffectual anyway. Your new wheels are call 'gas burners' because they look like a stove top burner. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
TMI Products Samba Member
Joined: February 14, 2014 Posts: 744 Location: Corona, Ca
Posted: Thu Sep 25, 2014 10:21 am Post subject: |
Why do engines/cars that have the moustache bar also have a rear mount that isn't used? _________________ Mario De Leon
1965 Turbo Mustang Fastback
1966 Type 3 Fastback
VW Division Sales Manager
[email protected]
TMI Products
1493 Bentley Dr.
Corona Ca, 92879
1-800-624-7960
951-272-1584 FAX |
Posted: Thu Sep 25, 2014 11:04 am Post subject: |
Tram says it was because it was used on the production line to aid installation of the engine/trans assembly, so they kept it even on later cars. _________________ 71 Elm Green FI A/T Squareback |
Posted: Tue Sep 30, 2014 2:31 am Post subject: |
Have not had a chance to do much maintenance yet but sitting on wire frames sucks. Started with the passenger seat just in case. Feel free to ask questions or comment. First time I have ever done upholstery and took me 4 hours for the seat. Used tweed sand covers from TMI and new foam pads which didn't seem to fit quite right. 10.5oz Canvas was used instead of burlap over frame. Time for beer!
Kick Kombi Samba Member
Joined: July 09, 2008 Posts: 184 Location: Central Coast, NSW, Australia
freizusein Samba Member
Posted: Tue Sep 30, 2014 5:05 pm Post subject: |
Thats a sweet ride . My wife owns a fabric shop and been considering doing my own upholstery. what was the hardest part? Thanks I Love the coors light can on the ignition coil. |
Posted: Sat Oct 04, 2014 11:32 am Post subject: |
Seats are finished, maybe now I wont get back pain! Just purchased some heat exchangers, its time to get the heater working.
Posted: Sat Oct 11, 2014 10:39 pm Post subject: |
Update: added electronic ignition and 3ohm resistance coil. Went with compufire, but doesnt seem any different from the chinese knock off.(i have the $40 pointless on my 1200.) general igniton tune up as well.
I have made progress although its poorly documented. Next things are new door seals/scrapers and jetting the carbs!
dfelz Samba Member
Joined: October 09, 2013 Posts: 34 Location: San Diego, CA
Posted: Sun Oct 12, 2014 1:21 am Post subject: |
Welcome to the Club! great looking squareback, I remember seeing it in the classifieds a few weeks back when i was looking to get mine. Your seats sure did turn out great for that being your first time doing upholstery, bravo to you! _________________ David
'67 SquareBack, 1600cc - Daily Driver
'71 Porsche 914, 1911cc - Twisties Car
'04 Infinti G35 Coupe 6MT - Backup |
Posted: Tue Oct 28, 2014 1:03 pm Post subject: |
Heres a quick update...
replaced a leaky fuel filler hose and kinked filler vent
re jetted and rebuilt carbs...cant remember jet sizes but they were recommended
painted some tins
auto trans vacuum lines were split. Used some 6mm silicone i had lying around.
attempted to bring life back to air filters
fixed cyl 1 spark plug with an insert. used a borrowed tap and a ratchet
set the valves..cyl 4 valves sit low. almost unable to adjust
compression check! a-ok
Replace oil cooler seals...which were incorrect and blocking 95% of oil flow.
replaced oil cooler seals again because one missed the first time. oops.
KTPhil Samba Member
Posted: Tue Oct 28, 2014 1:20 pm Post subject: |
Are your fan shroud outlets plugged up? Otherwise you lose all cooling air pressure. |
Posted: Tue Oct 28, 2014 1:31 pm Post subject: |
Right now the outlets have plugs. im working on re installing some heater boxed i purchased on the classifieds. i still need to get the elbow pipes though. _________________ 71 squareback (1904 A/T)
Posted: Wed Oct 29, 2014 11:51 pm Post subject: |
Alright so after tuning and syncing my newly jetted icts...along with the help of my dad. Well he did most if it and I read him Ruffturns post(because I work on fuel injection); the square runs much better! Cyl 1 is still kind of weak from not firing but hopefully it will build up some carbon and be ok. Car starts fine cold and idles smooth! misses significantly less as well.
Jets swapped: 52 to 55 idle. 130 to 140 main. f78 to f6 emulsion. 160 to 170 air. Total cost about $100 from aircooled.
I do have a few questions if anyone is willing...
Will the car ever run without missing with 34 icts? or is it not adjusted quite right. I did use a bubble sync tool, and checked it after driving for sync as well. I would estimate idle to be around 950rpm.
Does any one have a problem with their flasher sticking on? mine will fix itself if I pull the ememergency flasher for a few seconds. _________________ 71 squareback (1904 A/T)
Posted: Fri Oct 31, 2014 10:03 am Post subject: |
Replaced a whimpy looking spdt starter relay and 16ga harness which was zip tied to the starter. Never again will I be in the parking lot starting my square with a screwdriver! _________________ 71 squareback (1904 A/T)
