Schnage Samba Member
Posted: Sat Sep 03, 2016 8:22 am Post subject: Re: Hot Judson 36er |
After all the trouble with my 60 beetle ant the judson, it seems today i have solved the problems. I had the issue that the engine dont rev up when teh engine becomes hot, now i installed a pertronix ignitor and a new coil,it was some work, because the ignitor dosent fit out of the box, but with some thinking abaut and handwork i get the parts installed.
As i stripped down the distributor i found out that the centrifugally adjustment of the igniton point was sticking by some old grease in the shaft.....and that the cap has some tears?? Inside where the electricity can find new ways, but not to the spark plug.
After this, today 50 kilometer on autobahn and bundesstraße i had no problem, accelrate fine, runs without problems 130 km/h an, that is the best, has no problem starting when hot.....
So, i have a new coil, but i want to try what happend when i put the judson magneto back in, hopefully it works too and i can use this cool magneto coil.....
In the carb i have try some different nozzels, actually i am not shure wich size, maybe 132 main and 175 air correction...
Thank to all who give me hints! |
D-train Samba Member
Posted: Wed Apr 27, 2016 1:21 pm Post subject: Re: Hot Judson 36er |
Packed away now... _________________ shiny paint doesnt make it worth any more |
henry roberts Samba Member
Joined: February 24, 2003 Posts: 1276 Location: australia
Posted: Wed Apr 27, 2016 2:36 am Post subject: Re: Hot Judson 36er |
and that's why we can't give you nice toys dion. |
Posted: Wed Apr 27, 2016 1:52 am Post subject: Re: Hot Judson 36er |
How hot is your Judson body after the drive? Is the fuel evaporating before it gets to the heads?
Mines now broken, so back to stock 36hp for me... Damn. _________________ shiny paint doesnt make it worth any more |
Posted: Sat Apr 09, 2016 9:26 am Post subject: Re: Hot Judson 36er |
I have always trouble to restart my '60 beetle with judsen when the engine is hot after a drive on the autobahn. I stoped the engine an in the same second i can't start again. 2 hours later it will be no problem....
An other problem is when i drive longer withe the same speed, an then i have ro rev up, the engine stucks an dont rev up.....
No idea... |
steven wardlaw Samba Member
Posted: Mon Oct 05, 2015 10:18 am Post subject: |
Congrats on getting the old Judson to run correct. I had the same problem with my 40HP Judson setup. Best to always check the plug color and go for a little richer mixture than to run it on the lean side. |
Posted: Sun Oct 04, 2015 2:44 pm Post subject: |
Little update here.
All those years ago when I built the carb up I swapped all the bits from one to another, I didn't have the 140 air jet. I inquired about it to someone and they said it would be fine.
I was at work racking my brain again and it brought me back to the air correction jet. I couldn't remember if I did swap it over so I pulled it apart.
195 air jet as I left it.
So I soldered up a jet and drilled it out until I could find a proper jet, also rebuilt another carb, too much throttle shaft play on the other one and was leaking fuel.
Replaced the carb and air jet, actually found a few 122.5 mains in my collection of 28pcis with 195-180 air jets too.
So far it runs epic, pulls better up hills doesn't get hot, doesn't make any sounds either! Think it's a win now.
And all from not having a small jet. It's amazing the difference now. _________________ shiny paint doesnt make it worth any more |
Posted: Fri Sep 05, 2014 11:39 pm Post subject: |
Ok, little update, finally had time to rebuild the pump, been chatting with a mate an we are putting it down to fuel pressure.
Pulled the pump out, dismantled it, swapped the ww diaphragm out for a black made in USA one from another pump, it felt like a stronger material than the ww one, made a new preload jig, changed the bottom out for a straighter one.
So far so good, doesn't have that "rattle" sound when I'm under load up hills which is a bonus. So will trial this for now until it proves it doesn't work then will try another idea. _________________ shiny paint doesnt make it worth any more |
fabbe Samba Member
Posted: Sat Jun 21, 2014 4:19 am Post subject: |
do you use a judson coil ?
try with a original bosch coil (I had the same problem as you) |
vwhelmot Samba Member
Joined: May 04, 2006 Posts: 617 Location: united kingdom
Posted: Tue Jun 17, 2014 2:54 am Post subject: |
It was a mixture of a few things to be honest. This year I`ve really tried to solve the problem, rebuilt the fuel pump, carb, Judson charger rebuilt a few years ago.
The coil thing threw me as it was an intermittent fault, it wouldn't fail all the time. I hold my hand up with the timing , not realizing that the notch indicated 7.5 and not tdc. My fault, its timed right now but the vacuum advance touched the fuel line so had to bend the fuel outlet ever so slightly. We live and learn. :oops: It really is running like a swiss watch now, instant starting hot or cold. :D |
Jacks Samba Member
Joined: July 15, 2006 Posts: 2348 Location: San Clemente, Ca.
Posted: Mon Jun 16, 2014 11:52 pm Post subject: |
vwhelmot wrote: |
I think its either a faulty coil,(breaking down with the heat ,I run a Judson magneto coil) or a petrol evaporating problem.
Im going to hook up another coil and try that first.
GGGRRRRRRRRRRR!!!!!!! Ive had this problem for the last 9 years! |
Bad coil & timing off for 9 years _________________ Jack Staggs
Actual name |
Posted: Mon Jun 16, 2014 11:44 pm Post subject: |
7.5 , it wasn't near :oops:
Its made a huge difference. |
Posted: Thu Jun 12, 2014 1:11 pm Post subject: |
U said that last time! Haha..
Bad coil hey, where did u set the timing at now? _________________ shiny paint doesnt make it worth any more |
Posted: Thu Jun 12, 2014 8:57 am Post subject: |
New starter fitted inc a new starter bush in the gearbox.
I`ve finally cured it, a combo of bad coil and timing was not 100% right. |
tinlizard Samba Member
Joined: June 28, 2010 Posts: 74 Location: Murfreesboro, TN
Posted: Wed Jun 11, 2014 12:45 pm Post subject: |
vwhelmot wrote: |
I can go for a drive say 25 miles and it runs perfect, no splutters, nothing. If I stop it sometimes and try to restart it , it will crank over and over till the cows come home and it wont even cough or fire whatsoever.
Ive tried squirting easy start down the carb, nothing
Ive opened the top of the carb to make sure there was fuel in the float chamber , which there was.
Ive removed the plugs which were not wet, but are sparking
Ive tried new condenser, points, starter, starter gearbox bushing, installed a yellow top modern gell optima 6v battery
Ive checked for air leaks around the manifold
Ive checked the tank for shit and venting
Valve clearences
Timing
The list goes on.
As you can see, it boils my piss and I cant trust the car . the only way it will start is by bumping it. Once it starts it smokes a little bit but not bad and will continue to run fine. I can then stop the engine with the key and it will restart straight away.
Sounds as if your voltage to the coil is reduced on a hot start with starter, but not on a bump start. Too much starter draw when hot may be the problem. New starter might fix it, but it would be easy to confirm the diagnosis with a volt meter. _________________ 68 Beetle Vert
70 Single Cab
79 Transporter |
Posted: Mon Jun 02, 2014 2:20 am Post subject: |
I have a couple spares to trial if that's the case with yours, an a couple of see dees too _________________ shiny paint doesnt make it worth any more |
Posted: Mon Jun 02, 2014 12:24 am Post subject: |
I`m thinking that the coil maybe breaking down with age. Maybe!!! |
Posted: Mon Jun 02, 2014 12:16 am Post subject: |
I've been running the Judson coil the whole time and hav alternated between regular points n electronic points. Didn't make much of a difference. Even rebuilt a distributor so I knew the contacts and bits were all good on it too.. _________________ shiny paint doesnt make it worth any more |
Posted: Mon Jun 02, 2014 12:13 am Post subject: |
It doesn't seem to start when I release the key no, it just refuses to do anything. With the engine turning over quicker due to the lower compression (plug out) could that be a fuel pressure issue? It actually started on three cylinders and when I replaced the plug it fired and ran normal. When I skimmed the fuel pump (to stop it leaking) I added another gasket to reduce the pressure but to be honest its exactly the same as before. Replacing the Judson coil is my next route. After that a rebuild Glen 010 dizzy would be on the list.
I`m starting to think its cursed and am getting ideas of a 2110cc IDA replacement!!!!
Jacks Samba Member
Posted: Sun Jun 01, 2014 5:18 pm Post subject: |
What is the current fuel pressure, cold, checked with a gauge? Does it seem to sometimes start just as you are giving up and releasing the key from the start position? _________________ Jack Staggs
Actual name |
