madster Samba Member
Joined: November 01, 2006 Posts: 180 Location: Rio Grande Valley Texas
Posted: Wed Feb 07, 2024 10:33 pm Post subject: Re: Barn Find THING, Full Restoration, 27,000 Original Miles. |
_________________ 1966 BEETLE @ 1973 THING |
fuscazul72 Samba Member
Joined: September 19, 2006 Posts: 25 Location: Florianopolis - SC - Brasil
Posted: Mon Apr 03, 2023 6:31 pm Post subject: Re: Barn Find THING, Full Restoration, 27,000 Original Miles. |
News? _________________ Fernando Fuscazul72
Brazil |
oscarsnapkin Samba Member
Joined: October 22, 2013 Posts: 558 Location: Bucks County, PA
Posted: Sun Dec 27, 2020 3:59 am Post subject: Re: Barn Find THING, Full Restoration, 27,000 Original Miles. |
I skimmed through page 1 and skipped right to the last. Amazing work. Definitely will be reading through the thread for ideas/inspiration. Beautiful Thing. _________________ - 1977 CEI Sunroof Bus 2.0L F.I. Hydraulic Lifters
- 1973 Thing
"It’s so easy to laugh, it’s so easy to hate, it takes strength to be gentle and kind." |
randybriscoe Samba Member
Joined: December 26, 2007 Posts: 241 Location: chicago
Posted: Sat Dec 26, 2020 8:10 pm Post subject: Re: Barn Find THING, Full Restoration, 27,000 Original Miles. |
Installing the front fenders was more difficult than I thought i would be, we finally ended up using tape to hold the clips in place |
Posted: Sat Dec 26, 2020 8:01 pm Post subject: Re: Barn Find THING, Full Restoration, 27,000 Original Miles. |
Test fitting the original front seats that have been in storage since 1978 |
Posted: Thu Dec 12, 2019 6:01 pm Post subject: Re: Barn Find THING, Full Restoration, 27,000 Original Miles. |
So we ended up having to turn the voltage regulator to clear the dual carbs |
Posted: Mon Aug 13, 2018 8:37 am Post subject: Re: Barn Find THING, Full Restoration, 27,000 Original Miles. |
Posted: Thu Feb 08, 2018 11:08 pm Post subject: Re: Barn Find THING, Full Restoration, 27,000 Original Miles. |
Some wire bundles we heated up a little so they would lay in place |
Posted: Thu Feb 08, 2018 11:06 pm Post subject: Re: Barn Find THING, Full Restoration, 27,000 Original Miles. |
The new solid state voltage regulator. Lots of fun cleaning and installing the original wiring harness |
Posted: Thu Feb 08, 2018 10:52 pm Post subject: Re: Barn Find THING, Full Restoration, 27,000 Original Miles. |
A little out of sequence...revisiting the steering assemble. A sketch I made of the steering column assemble on the steering wheel end. We added a plastic spacer in place of the felt to help keep the anti rattle bushing in place.
Mike Basso at Thing Parts hooked us up with all the original steering column hardeware
Test fitting the steering column
Inserting the horn ground wire through the steering wheel
Through trial and error we finally got a good gap/spacing on the steering column assemble. A lot of small variables at play here, both top and bottom |
Posted: Sun Jan 07, 2018 11:26 pm Post subject: Re: Barn Find THING, Full Restoration, 27,000 Original Miles. |
Well we're back...here's the first test fitting of the controversial 82 x 94 stock head engine. |
Posted: Fri Sep 22, 2017 9:29 am Post subject: Re: Barn Find THING, Full Restoration, 27,000 Original Miles. |
77kafer Samba Member
Joined: April 08, 2008 Posts: 823 Location: New Windsor, NY
Posted: Fri Jun 02, 2017 4:22 am Post subject: Re: Barn Find THING, Full Restoration, 27,000 Original Miles. |
people who drive a vw thing (type 181/182)
it is not a build thread, he is just posting that it is together, and that it drives. short videos of test drives etc.
Now if you want to read through an interesting one on here, check this one out (all 18 pages): https://www.thesamba.com/vw/forum/viewtopic.php?t=389726&highlight=schwimmer _________________ Supposed to be 77käfer, but there are no umlauts on an american keyboard
Overheard on 27 June 07, one lady to another when they saw my Harli in a parking lot at West Point, "maybe he found it on the clearance aisle at the Volkswagen dealer" |
zohami Samba Member
Posted: Thu Jun 01, 2017 9:45 pm Post subject: Re: Barn Find THING, Full Restoration, 27,000 Original Miles. |
Just read all 12 pages, took a few days. Killer project!
Which Facebook page; not finding it? _________________ Sold the Doka, now it's a '74 Thing |
Posted: Tue May 30, 2017 4:30 am Post subject: Re: Barn Find THING, Full Restoration, 27,000 Original Miles. |
madster, you will be eating a lot of pop-corn.
Since Randy found the thing facebook page a few months ago, he has not been back here to finish up. _________________ Supposed to be 77käfer, but there are no umlauts on an american keyboard
Posted: Mon May 29, 2017 8:36 pm Post subject: Re: Barn Find THING, Full Restoration, 27,000 Original Miles. |
Chitty1 Samba Member
Joined: April 28, 2016 Posts: 20 Location: Ontario Canada
Posted: Thu Jan 26, 2017 7:11 pm Post subject: Re: Barn Find THING, Full Restoration, 27,000 Original Miles. |
[quote="randybriscoe"]IT's Fuel Tank Time
[img]
Did you not use any gaskets either side of the plastic filter, or are you counting on the filter flange to seal both leak paths? I bought the same kit from cip1 and it recommended gaskets be used with this filter. Also, did you use the loose washer under the nut?
Great job on the restoration and the step-by-step posts. _________________ 1963 Bug, 1600DP, 12V alternator conversion
2012 Mustang GT
1998 New Beetle (wife's)
Plus 2 other non-descript DD's |
Posted: Tue Jan 10, 2017 9:39 pm Post subject: Re: Barn Find THING, Full Restoration, 27,000 Original Miles. |
Posted: Tue Sep 06, 2016 5:52 pm Post subject: Re: Barn Find THING, Full Restoration, 27,000 Original Miles. |
So what you're saying is...install the "T" fitting, we're good to go! |
frogman_94 Samba Member
Posted: Tue Sep 06, 2016 12:10 pm Post subject: Re: Barn Find THING, Full Restoration, 27,000 Original Miles. |
randybriscoe wrote: |
Maybe we can use this pump for the heater also? |
The pump for the heater is a solenoid type pump and operates by contacts in the fan. |
