nezz Samba Member
Joined: January 13, 2006 Posts: 412 Location: Coimbra-Portugal
Posted: Mon May 30, 2016 7:50 am Post subject: Re: Pics of stock width beams lowered beetles |
Motor60 Samba Member
Posted: Sat May 28, 2016 6:56 pm Post subject: |
mnelsonvw wrote: |
Dropped Spindles only on the front, one spline on the rear. |
does anyone know this guy or bug? Im having an issue fitting my 2 Liter wheels on my 1970 bug...with drop spindles only, stock beam. the lower ball joint is pretty much inside the wheel and ALMOST touching it. I have 195/65/15 but i already know i have to change those out. But do these come in different offsets? they are the empi 2 Liters. How do i get them away from the lower ball joint? and what size tire should I run? |
BerylGreen63 Samba Member
Posted: Tue Aug 11, 2015 3:39 pm Post subject: |
2.5 drop spindles and 175/55/15 tires
2.5 drop Spindles and 145 R15 tires
vdub8 Samba Member
Joined: February 24, 2007 Posts: 125 Location: SLC, UT
HotWhls Samba Member
Joined: December 01, 2006 Posts: 82 Location: North Carolina
Posted: Sat Aug 08, 2015 7:02 am Post subject: |
1968 with stock width beam, adjusters and 195/50 tires on 15 X 5.5 rims.
_________________ Jesus Saves |
Dirty Hippie Samba Member
Joined: July 19, 2007 Posts: 189 Location: Huntsville, Alabama
Posted: Fri Aug 07, 2015 5:49 pm Post subject: |
mnelsonvw Samba Member
Joined: December 29, 2007 Posts: 121 Location: Baltimore MD
Posted: Tue Aug 04, 2015 3:40 am Post subject: |
Dropped Spindles only on the front, one spline on the rear. _________________ MattyMatt
73 standard beetle |
Babyblue60 Samba Member
Joined: April 18, 2012 Posts: 49 Location: Puyallup,wa
Posted: Fri Jul 31, 2015 10:31 am Post subject: |
noslocars wrote: |
webberjames95 wrote: |
insane68 wrote: |
Zach Thomas wrote: |
stock beam. friends bug.
I don't think that's a stock beam. But I like it A little extreme on the rear, how wide are those steelies? |
It's not mine. But a friends. It is stock beam. He takes pride in having a super low stock beam bug. I believe 8 in the rear. Those are bus rims in the front. Only adjusters and dropped spindle in front |
so i found a person who had a bug this model, stock beam, bus rims, drop
,had to take it back apart and narrow the beam because the fenders were sitting on the tires, so this is a narrowed beam in this picture. physics never lie.... |
I can guarantee this is a stock beam. this is babyblue60's bug. builders never lie.
http://www.thesamba.com/vw/forum/viewtopic.php?t=199657&start=40
check it out yo. |
I want to see a tape measure picture measuring the beam. Guess I lived in the show me state for too long. |
This is my car. Stock with beam with adjusters. 2 1/2 drop spindles on bus wheels 165/45/15 tire. Read was 2 1/2 drop plates on 15x8s on 185/50/15 tire
Flat bottom panes. It no longer has that beam due to running 17" iozzio Cosmics with 944 hubs on Lp drop spindles and 17x10 rears |
mellowcmb Samba Member
Joined: October 12, 2014 Posts: 3 Location: South Pasadena, Ca
Posted: Thu Feb 05, 2015 6:43 pm Post subject: |
Front slightly lowered on stock beam. |
Higgy69 Samba Member
Joined: September 30, 2013 Posts: 10 Location: Kentucky
Posted: Sun Feb 01, 2015 1:34 pm Post subject: |
ol puddin head wrote: |
needs centerlines......and vintage fenders. |
Can't run centerlines here, some dude around Somerset hoardes all of the vintage centerlines up |
ol puddin head Samba Member
Joined: April 03, 2011 Posts: 50 Location: somerset ky
Posted: Sun Feb 01, 2015 1:13 pm Post subject: |
Higgy69 wrote: |
This was mine on stock width beam, I did go to a 4" narrow beam.
And narrowed
needs centerlines......and vintage fenders. _________________ Tired Arms...Achy Knees...Greasy, Bloody Knuckles
Nothing Says Weekend Fun Like A Full Restoration |
Posted: Sun Feb 01, 2015 12:06 pm Post subject: |
And narrowed
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11057 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Sun Feb 01, 2015 8:21 am Post subject: |
VOLKSWAGNUT wrote: |
Specs:
1967 Beetle
Stock transaxle (long axles)
Eagle Alloy 5 spokes. 15 x 5.5
Rear: Original unchanged ride height 185/65/15 tires
Front: Lowered front with CIP1 purchased spindles 1/4 offset and torsion adjusters welded in a stock length beam. 1 set of Caster shims and long beam bolts.
Front beam is 3 inches off the ground. 155/60/15 tires.
Nice mild raked look, they way I like it. It rides, drives and handles great. I hope these reference pics helps some other owners/builders.
Same car... same setup.. but with 15x4 stock 67 wheels..
Wheel change...in hopes it will help the sale..
.[/quote] _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
61Whitebeetle Samba Member
Posted: Sat Jan 31, 2015 1:43 pm Post subject: |
my 61 has a 2" narrowed beam but with drop spindles and CSP disc brakes making the track near standard width.
sixfootdan Samba Smartass
Joined: February 13, 2002 Posts: 4848 Location: \Lo*ca"tion\, n. 1. The act or process of locating.
Posted: Sun Jun 08, 2014 5:49 am Post subject: |
Just a stock width beam with adjusters and 135's, Going to lower the back a little bit. _________________ Schrodinger's cat walked into a bar and it didn't.
GO SEAHAWKS!!! |
dropped65 Samba Member
Posted: Sat Jun 07, 2014 6:09 am Post subject: |
2in widefive dropped spindles stock rear
175/65r15 front 195/60r15 rear |
vugbug68 Samba Member
Joined: June 25, 2006 Posts: 2696 Location: sacramento
Posted: Tue May 27, 2014 12:07 am Post subject: |
Friends 71 with 2.5 drop spindles and disc brakes, 155/60/15 up front
Old pic of my old 68, 2.5 drop spindles, stock drums, 195/50/15 up front
_________________ 71 Super - Backroad Thrasher
66 Corvair - Weekend Cruiser
90 4 Runner - Muddin |
ATHAFA Samba Member
Posted: Mon May 26, 2014 9:02 pm Post subject: . |
This worked for me. Not a bit of rub, even with aggressive driving.
77 beetle
dropped spindles(lowers 2.5 inch) with drum
one rear outer
The KYB Gas-a-Just front(raises 1 inch) and rear(raises a bit ?)
155/80/15 all four
EMPI Sprintstar
Wheel Width: 5 in.
Backspacing: 3.98 in.
Offset: +25 mm
shano63 Samba Member
Joined: October 06, 2006 Posts: 3596 Location: Stormville NY
Posted: Sat Oct 19, 2013 3:12 pm Post subject: |
Just adjusters...155/80s on 5.5in rim. Rear is untouched...
_________________ 63 T1 Ragtop Gulf Blue
08 Civic 5spd
22 Wrangler 6spd
78 F250 4x4 4spd
Chris
Take it as it comes-- Morrison |
bug59 Samba Member
Joined: November 03, 2003 Posts: 66 Location: belgium
Posted: Sat Oct 19, 2013 1:47 pm Post subject: |
Mine is stock width with adjusters and drop spindles,135 smart tyre
gtz _________________ vw bug 59
vw jetta 83 |
