Cmontoya9 Samba Member
Joined: August 15, 2012 Posts: 162 Location: Santa Fe, NM
Posted: Sat Jan 19, 2013 4:32 pm Post subject: |
Sure thing, I'm usually the one that's asking for help, glad I could help out for a change! |
Bud Osbourne Samba Member
Joined: May 25, 2005 Posts: 251 Location: Pittsburgh, PA.
Posted: Sat Jan 19, 2013 2:05 pm Post subject: |
That's BEAUTIFUL! I now have NO excuse for not getting these brackets just right.
Thank you, thank you, thank you!
Cmontoya9 wrote: |
Hey Bud, sorry for not getting back to you yesterday but here you go.
Brake line bracket base is 9 inches from center hump, base is about an inch
Centered at 3 1/2 inches from Napoleon's Hat
Bracket is 5 inches tall measured from pan, center of hole is at 4 inches, hole is 3/4 inch wide
Bracket sits at an outward angle, from center hump to top of bracket is 11 3/4 inches
Hope this helps, good luck! |
Posted: Sat Jan 19, 2013 1:52 pm Post subject: |
Posted: Thu Jan 17, 2013 8:37 pm Post subject: |
Cmontoya9 wrote: |
I can measure them for you tomorrow when I get to work, is it a standard? |
That would be perfect! Yes, it is a standard.
Thanks. |
Posted: Thu Jan 17, 2013 7:31 pm Post subject: |
Posted: Thu Jan 17, 2013 12:18 pm Post subject: looking for photos & dimensions, please |
I need some photos, as well as dimentions for the mounting bracket, on the frame head, where the hard lines, from the master cylinder, join the hoses from the wheel cylinders. I've got to fabricate and install them on my '73 Beetle frame and I have no other Beetle chassis handy to refer to.
This is for a car which will be driven, a LOT, so I'm not ready to accept "close enough".......yet
Thanks for any information you can provide. |
