igtoth Samba Member
Joined: May 09, 2006 Posts: 385 Location: Ribeirão Preto, SP, Brazil
Posted: Mon Jun 06, 2016 9:17 am Post subject: Re: Vintage speed cam from WW |
Would this work inside a stock 25hp engine? _________________ 1957 Typ 113 - Polarsilver
1959 Typ 113 - Flint Grey
1975 Typ 221 - Last yr Brazilian Split Window
Ighor Toth |
txoval Samba Member
Joined: January 23, 2004 Posts: 3557 Location: The Woodlands, TX
Posted: Sat Jul 26, 2014 5:19 pm Post subject: |
Post up the boost numbers! Yours or my old one? |
Mr. Motorhead Mad Scientist
Joined: January 06, 2004 Posts: 717 Location: Practitioner of 36hp alchemy
Posted: Sat Jul 26, 2014 4:40 pm Post subject: |
I've been wanting to run one of these cams, as I have not seen much if any feedback from anyone running one. It's a little bumpy on idle, but smooths out at higher RPM. That may be because I'm running a single 28PCI. Makes good power, I set it straight up on the gears as it was pretty close to spec. Static compression is 8.1/1 and it doesn't seem to run hot even on this 100 degree day we're having today. In fact it seems a little cold blooded as the manifold base takes about 5-10 minutes to warm up to produce a steady idle (yes, my preheat tube is clear and works perfect). Although I think this cam would be better suited for a dual setup, I'm happy. I think I may try my blower on it (I put a port on the manifold to measure boost). _________________ 30 years experience in the sales of new and used auto parts!
36 horsepower parts for sale at http://www.aircooledresearch.com/
Or the new site at http://www.bugparts.com
Check out the Bonneville project:
http://aircooledresearch.com/docs/thebonnevilleproject.html#
"All limitations are self imposed."
Some Chinese guy |
splitpile Samba's Worst Speller
Joined: May 03, 2000 Posts: 5927 Location: back to living where hell meets the suface
Posted: Wed May 22, 2013 9:20 am Post subject: |
gimmesomeshelter wrote: |
Mr. Motorhead-
Do you know who makes the blanks? How long will it take to see if the blanks are made correctly?
Cheers,
Paul |
When I had WEB Camshafts grind some of WW blanks for me they tested the blanks for whatever a cam grinder test them for. The only extra thing they did was heat treat them after grinding (along with parkerizing) the get the hardness correct for using 36 hp cam followers.
I do have a couple of the WEB grind cams out there with 0 issues and 1 WW grind with 0 issues also. but none running in my own stuff yet.
WW cams are ground in the U S of A
I haven't run this cam yet as it's in the supercharged engine with some monster lift and spring pressures. Taking it to the extreme.
The blanks are made in China _________________ Stocking distributor of "The Funky Green Panels"
"no more hacking my sig line" |
Posted: Tue May 21, 2013 9:29 pm Post subject: |
The blanks are made by Wolfsburg west, same blank they use for their grind. Not really too much you can screw up other than the machining. The blank comes with the journals turned and the lobes raw. I have three, the one I just put in an engine (WW grind) set up just fine. _________________ 30 years experience in the sales of new and used auto parts!
Some Chinese guy |
gimmesomeshelter Samba Member
Joined: May 08, 2004 Posts: 1466 Location: San Carlos, CA
Posted: Tue May 21, 2013 8:23 pm Post subject: |
Mr. Motorhead-
Cheers,
Paul _________________ "I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman |
Posted: Tue May 21, 2013 11:48 am Post subject: |
Wolfsburg West will also sell you a new cam blank to put your preferred grind on. I just got mine back from the grinder yesterday and I now have them in a kit form along with the WW grind. I'll be driving the newest 36hp build in a couple weeks, it has the WW grind in it. _________________ 30 years experience in the sales of new and used auto parts!
Some Chinese guy |
oldbusboy Samba Member
Joined: June 25, 2006 Posts: 604 Location: Bowen Island, BC Canada
Posted: Tue Mar 26, 2013 7:36 pm Post subject: |
Straight cut gears work fine, the bolt holes are tapped for 8mm x 1.25 pitch bolts. WW sells no cam gears so you are on your own if you want to run a stock aluminum gear. Sometimes I get good gears on some of the cams I have reground, but lately not very many. The billets are nice, I'm getting ready to run one in one of my cars. _________________ 30 years experience in the sales of new and used auto parts!
Some Chinese guy |
Posted: Tue Mar 26, 2013 6:11 pm Post subject: |
I assume if I wanted to use straight cut cam gears I could bolt them to this cam?
Trevor _________________ 1968 porsche |
Posted: Thu Aug 30, 2012 1:30 pm Post subject: |
Hello-
Has anyone tried this cam yet?
Cheers,
Richard Feynman |
Altema Samba Member
Joined: June 20, 2010 Posts: 2904 Location: Lower Michigan
Posted: Sat Aug 18, 2012 6:44 pm Post subject: |
I almost choked on that! |
slalombuggy Samba Member
Posted: Tue Aug 07, 2012 9:35 am Post subject: |
brad |
avus Samba Member
Joined: November 11, 2005 Posts: 268 Location: Drain, Oregon
Posted: Tue Aug 07, 2012 8:24 am Post subject: |
slalombuggy wrote: |
Do they make an SA rated version?????
brad |
No HANS device required--Just a hole in the roll cage with a rubber grommet!! |
Posted: Tue Aug 07, 2012 7:28 am Post subject: |
brad |
avus Samba Member
Posted: Fri Aug 03, 2012 7:40 pm Post subject: |
Watch out for your ragtop!
Braukuche Samba Member
Posted: Fri Aug 03, 2012 3:45 pm Post subject: |
Hello-
In their monthly email they said the lobe center was 105 degrees.
Cheers,
Paul |
Makensen in your avatar?? _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Posted: Fri Aug 03, 2012 2:36 pm Post subject: |
Hello-
Cheers,
Richard Feynman |
