Mikedrevguy Samba Member
Joined: October 15, 2008 Posts: 2241 Location: Medford, OR
Posted: Wed Oct 31, 2018 11:11 am Post subject: Re: Tires Tires Tires |
31x10.5 on rear.
235/70/15. On front.
Federal Couragia on all four corners.
_________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
"The wise speak because they have something to say; while the foolish speak because they have to say something." Plato
Illigitimi non-Carborundum!! |
dustymojave Samba Member
Posted: Wed Oct 31, 2018 10:54 pm Post subject: Re: Tires Tires Tires |
Those are those same Federal Couragia M/T tires we were talking about on the last page. They look good.
Real pretty Baja too. I like the colors. _________________ Richard
SoCalBajas Member
GeoJack Samba Member
Posted: Wed Mar 20, 2019 5:00 pm Post subject: Re: Tires Tires Tires |
I'm pulling the trigger on some 15" x 6 rims, came with 14" and also going with the Federal Couragia M/T Mud-Terrain Tire- LT235/75R15 6 PR 104/101Q.
Any problems with having the same tire on all corners?
Yanking the 1500 and pumping in a fresh 1915 to push it over the hills. |
rayjay Samba Member
Joined: March 26, 2008 Posts: 1507 Location: Buford GA
Rex lucy Samba Member
Joined: April 10, 2008 Posts: 497 Location: pleasant plains arkansas
Posted: Fri Oct 18, 2019 6:26 am Post subject: Re: Tires Tires Tires |
I put the federal couragia 31x10.50x15 0n my humbug and can now cross the creek. like that tread and looks. 290. for two at Walmart on line. |
Bakerby Samba Member
Posted: Tue Nov 12, 2019 5:30 pm Post subject: Re: Tires Tires Tires |
My son embarrassed his best friend muddling a while back with the federal couragia on his bug. His buddy has an old ram charger and could not keep up, not even close. In the mud at least these things rule. |
hendersoned Samba Member
Joined: November 23, 2007 Posts: 80 Location: Las Vegas, NV
Posted: Sun Apr 26, 2020 3:48 pm Post subject: Re: Tires Tires Tires |
Yokohama geolander ats 245-75 16” front (Almost 10 years old) and now has 265-70 16” pathfinder at from discount tire 8 got for $30 when one of the Yokohama went way out of round. All 4 yokos pictured.
Pez Samba Member
Joined: September 16, 2003 Posts: 583 Location: Texarkana
dirtkeeper Samba Member
Joined: February 19, 2008 Posts: 3200 Location: Left of everywhere
Posted: Sat Jul 04, 2020 8:27 am Post subject: Re: Tires Tires Tires |
I like that tool. Problem seems is that I have never found a tire that is the “actual” advertised size when installed. |
Pez Samba Member
Posted: Sat Jul 04, 2020 9:56 pm Post subject: Re: Tires Tires Tires |
dirtkeeper wrote: |
Too true, nothing can replace physically going down to the tire shop with a tape measure. The tool has at least allowed me to somewhat wrap my head around tire size vs aspect ratio. Never been something I could decipher easy. _________________ Always chasing Squirrel's. |
oobleck Samba Member
Joined: December 18, 2019 Posts: 13 Location: Redmond, OR
Posted: Mon Oct 12, 2020 8:13 am Post subject: Re: Tires Tires Tires |
Anyone have an opinion about running the Firestone 700-15 NDT's on the front of a baja? the shoulders are rounded and the price is not much more than the Deestones/Power Kings |
shakinjoe Samba Member
Posted: Sat Nov 28, 2020 11:54 am Post subject: Re: Tires Tires Tires |
great subject matter |
oprn Samba Member
Joined: November 13, 2016 Posts: 12760 Location: Western Canada
Posted: Sun Dec 20, 2020 8:38 pm Post subject: Re: Tires Tires Tires |
I just found this thread today and spent all afternoon reading through it. Wow! lots of options for folks out there. Too bad most of the pictures and links don't work anymore.
The best tires so much depend on what you do, where you go and how aggressive you drive. So I will just briefly share my set up in case someone is interested.
Driving style - old fart, exploring the hills and back country, not street legal, 1600SP Bus transaxle. 14" ATV tires on the back 4 psi, 15" 5 rib implements on the front 8 psi. Have not tried these in pure sand yet.
Wheeljack Samba Member
Joined: January 20, 2020 Posts: 99 Location: Utica, Nebraska
Posted: Sun Jan 24, 2021 5:43 pm Post subject: Re: Tires Tires Tires |
I'm kind of surprised no one brought up this gear ratio calculator http://www.grimmjeeper.com/gears.html might not be the most popular one used, since it's mostly for 4x4 setups. Also, anyone try the EMPI Electronic Speedometer transducer kit? I'm wondering if it'll help to get an accurate speedometer reading. Get an electric speedo and then calibrate it to the new tire size. https://www.jbugs.com/product/16-9290.html Could help with the odometer and mileage calculations than trying to figure out the tire size difference by hand. |
Posted: Sun Jan 24, 2021 6:33 pm Post subject: Re: Tires Tires Tires |
Wheeljack wrote: |
That item seems a little pricey for the job , you could get a speedometer for less. I think most aftermarket speedometer even the old ones can be set to calibrate your actual speed. Mine does. Usually by using road markers and a button. Lot of people using gps now. And that unit still has the cable . I think the latest thing now would be to have a wired transducer instead of the cable. |
Posted: Sun Jan 24, 2021 7:24 pm Post subject: Re: Tires Tires Tires |
dirtkeeper wrote: |
Wheeljack wrote: |
Glow shift sells a kit for $20 for a mechanical to electronic speedo. Found the same EMPI kit elsewhere for $125. Most of the Hall effect ones are for Ford, GM, and Dodge transmissions.
My donor buggy has an original VW mechanical speedometer. I haven't found much for different kits to calibrate for larger tires. So I was thinking going the electronic speedometer route, but most of what I'm seeing, are not for classic VW. I'll keep searching though. |
Posted: Mon Jan 25, 2021 3:25 pm Post subject: Re: Tires Tires Tires |
At least for the Autometer electric speedometers, the sender units require a CV axle. I have a swing axle, so I'll have to get either a different tooth count to get an accurate speedometer or, that transducer. Found the same transducer cheaper elsewhere.
Also, is it beneficial to run a wider tire in back (supposedly running a wider tire acts like an anti-sway bar) than the front and are there any issues just running the same size tire front and rear on a Warrior frame with a swing axle? |
Posted: Wed Jan 27, 2021 5:53 pm Post subject: Re: Tires Tires Tires |
Wheeljack wrote: |
There are a number of reasons to use a bigger rear tire than front on a tube frame buggy based on VW components.
1 - The rears do all the push work
2 - The rears carry the vast majority of the load. Most of the car's weight is at the back of the car. INCLUDING the passengers.
3 - Wider tires on the front apply road forces to the spindles and steering mechanism with a LOT more leverage and make it MUCH more likely to damage the front suspension. Bend/break spindles, tie rods, rod ends, steering box, etc. Stock 4" wide front rims with narrow tires place the loads on the spindle about the middle of the spindle shaft. 30 x 9.50 tires on 6" or 8" wide rimes put those loads out past the end of the spindle shank.
4 - Steering forces go WAY up with wide front tires and rims. That's when people start feeling a need to add power steering.
5 - Turning radius goes WAY up with wide front tires and rims. My Baja with stock front rims and 165 tires can turn a U-turn in my street with a few feet left over. With the Centerlines with only a 3.5" wide rim but more offset, I can only get a little more than 1/2 of that U-turn. _________________ Richard
SoCalBajas Member
Posted: Wed Jan 27, 2021 8:02 pm Post subject: Re: Tires Tires Tires |
So what should the absolute widest be for the front before needing to go with a stronger spindle? I'm more concerned with tire size availability in a pinch than anything else. It's one thing to be able to order tires online, its wholly different when you need to replace a tire when riding and you get a non-repairable hole in the tire or what have you. |
Posted: Wed Jan 27, 2021 11:48 pm Post subject: Re: Tires Tires Tires |
I'm not going to tell you an "ABSOLUTE".
The widest I go for on the front of a VW-based buggy or Baja is 7.00-15 on a 4" wide rim. And I prefer stock 3-3/4" back space for that 4" wide rim. Like a Centerline "bubble" rim.
In more common sizes in places like Nebraska, try a 215-75 x 15 tire. All-Terrain ("A/T") is good. Local Walmart had a good looking Douglas in that size a while back at a good price. So is a 6.70-15 5-rib DOT Implement tire. (Load Range B or C. NOT Load Range D or E.)
It's a buggy. NOT a lifted Chevy 4X. _________________ Richard
SoCalBajas Member
