AirCooledClassics Samba Member
Joined: August 20, 2004 Posts: 294 Location: Saskatoon, Sk Canada
Posted: Sun Jan 10, 2016 8:30 pm Post subject: New ratio rockers and lifters |
I've just looked into the new ratio rockers and lifters from Concept 1 for the 36 hp performance game. the lifters are a nice option to solve the pushrod bending problem (although they have been available from Blackline racing for several years.) The ratio rockers apply to anyone building a small 36 engine not a Bonneville monster. They bolt on only a tiny ratio increase but they claim they fit under stock Valve covers. I don't know if that applies if your running a heftey cam. Its great to see someone bringing parts to the vintage speed market. I think the price is great to but i'm confused on the tiny ratio on the arms. What do you think! _________________ 2010 Bonneville record holder Type 2, 36hp
NHRA Divisional Sports Compact Champion
My You-tube video
http://www.youtube.com/watch?v=GJoq3MtsPmc
My National Dragster article
http://www.dragracecentral.com/DRCStory.asp?ID=231552 |
pig-pen Samba Member
Joined: December 04, 2012 Posts: 570 Location: United Kingdom
Posted: Mon Jan 11, 2016 2:53 pm Post subject: Re: New ratio rockers and lifters |
do you have a link? _________________ 1954 L227 Type 113
1964 L31 Type 265 |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Mon Jan 11, 2016 4:27 pm Post subject: Re: New ratio rockers and lifters |
http://www.thesamba.com/vw/classifieds/detail.php?id=1880205 _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
gimmesomeshelter Samba Member
Joined: May 08, 2004 Posts: 1466 Location: San Carlos, CA
Posted: Tue Jan 12, 2016 11:01 am Post subject: Re: New ratio rockers and lifters |
These look interesting!
Much less expensive than Speedwell rockers, you don't have to buy special valve covers, and you're less likely to run into valve spring binding issues. Combine this with a cam from WW (
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111109021OK) and a set of 911 style adjustment screws, and you'll be ready to go!
Cheers,
Paul _________________ "I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman |
txoval Samba Member
Joined: January 23, 2004 Posts: 3571 Location: The Woodlands, TX
Posted: Thu Jan 14, 2016 7:31 pm Post subject: Re: New ratio rockers and lifters |
Ok if you are building an engine, but not for adding to a running engine since you have swap lifters ($229) and then buy cut to length pushrods
1.4 rockers from speedwell provide more performance and cost the same.
These lifters are $159 + $229 + pushrod cost.
1.15 isn't a big boost from 1.1...sorry |
Posted: Thu Jan 14, 2016 8:20 pm Post subject: Re: New ratio rockers and lifters |
I'm not sure I agree.
You'll need to switch to two piece lifters if you go to any ratio rocker setup.
The benefit of the 1.15 setup is that it's $200 less less expensive than the Speedwell rockers, you won't need aftermarket valve covers ($150), and you're very unlikely to have issues with coil binding, unlike the 1:1.4 rockers.
The downside of the 1.15's is obvious - they don't lift as high/won't flow as much.
BTW, the stock ratio is 1:1, not 1.1:1.
Cheers,
Richard Feynman |
txoval Samba Member
Posted: Fri Jan 15, 2016 5:21 am Post subject: Re: New ratio rockers and lifters |
Yes typo.
My point is that the speedwell rockers do NOT require two piece lifters/pushrods. Coil bind is not an issue with my Stage 2 cam.
I think these lifters are a great deal for a new build, but not for a running engine like the speedwell version.
I would not switch lifters on a broken in cam/lifter setup.
$390 for these (lifters + rocker arms)
$395 for speedwell, which also includes new shafts. Of course, finding Speedwell parts is a pain |
Posted: Sat Jan 16, 2016 1:06 am Post subject: Re: New ratio rockers and lifters |
ok, so I already have the speedwells... and I need new lifters anyway... so is it worth me buying these new lifters? I was only going to use my original cam, although I have a blank one I might do my own grind with. One day. When I pull my finger out of my ..... _________________ 1954 L227 Type 113
1964 L31 Type 265 |
pineapple_express Samba Member
Posted: Sun Jan 17, 2016 4:09 pm Post subject: Re: New ratio rockers and lifters |
quick question on the 1.4 Speedwell rockers, lash caps are not necessary correct? _________________ [Fiddy Whip] |
txoval Samba Member
Posted: Tue Jan 19, 2016 9:30 pm Post subject: Re: New ratio rockers and lifters |
Correct |
RichardinNZ Samba Member
Joined: September 16, 2011 Posts: 280 Location: Auckland, New Zealand
Posted: Fri Jun 24, 2016 12:23 am Post subject: Re: New ratio rockers and lifters |
Looking for ratio rockers for my dual carb 36hp. Looks like these new rockers aren't suitable given the comments above (is it is a built engine) but does anyone know who may have some Speedwell 1.25s in Stock?
Many thanks
Richard _________________ Richard
'58 Beetle; NZ Assembled
Dual Carb 36hp
My Car https://www.thesamba.com/vw/forum/album_page.php?pic_id=1750253 |
Robert Chambers Samba Member
Posted: Fri Jun 24, 2016 7:06 pm Post subject: Re: New ratio rockers and lifters |
Richard,
I saw some for sale on eBay from kokoparts. I think they are the new style mentioned on this Forum? Good luck! _________________ '63 OG 117 Herbie Replica
'56 Euro Oval Deluxe
'52 Standard Zwitter
'63 OG 117 |
Posted: Mon Jun 27, 2016 10:09 pm Post subject: Re: New ratio rockers and lifters |
Sorted. Thanks to a tip off from TX oval I have some 1.4s.
Won't get them until late July and then fit them late August.... _________________ Richard
Dual Carb 36hp
Mr.Ragtop Samba Member
Joined: February 04, 2010 Posts: 46 Location: colorado
Posted: Wed Aug 01, 2018 9:52 pm Post subject: Re: New ratio rockers and lifters |
Anyone running these rockers yet with a WW cam? Looking at doing this but not sure if I’ll clear the piston as I’m shooting for about 9:1 on my build. |
PeteSC Samba Member
Posted: Thu Aug 02, 2018 5:14 am Post subject: Re: New ratio rockers and lifters |
I'm using them on my 1397 build (that is if we're talking about the AA Performance 1.15:1 rockers) that has a WW hi-po cam. Engine has been run for break in only, so I don't have any real feedback on them yet, other than that the break-in went well. It'll be about a month before the engine is in the car and driving.
Huntd105 Samba Member
Joined: February 13, 2019 Posts: 22 Location: England
Posted: Wed Feb 13, 2019 3:33 pm Post subject: Re: New ratio rockers and lifters |
Has anyone got advice on these rockers . Ive bought some for my already built 30hp motor what exactly am i needing to do before i can run them.
Im still all fairly new to all of this you see any help would be great |
Posted: Wed Feb 13, 2019 7:34 pm Post subject: Re: New ratio rockers and lifters |
Make sure you're valve springs aren't binding and check your valve geometry. If it's too far off, you may of to use two piece lifters (https://aapistons.com/products/vw-36hp-2-piece-lifters-type-1-4-porsche-356-912-914-8pcs).
Cheers,
Richard Feynman |
Posted: Wed Feb 13, 2019 11:44 pm Post subject: Re: New ratio rockers and lifters |
I will look for thst . I imagine it Will only be a small difference from the standard rockers? . |
PEPPE Samba Member
Joined: August 24, 2003 Posts: 1068 Location: Roma Italy
Posted: Sun May 10, 2020 11:26 am Post subject: Re: New ratio rockers and lifters |
hallo, i am using this lifters with stock cam and stock pushrod setup. how much is the risk in using them without special pushrods? |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7248 Location: Videbaek Denmark
Posted: Sat May 16, 2020 7:30 am Post subject: Re: New ratio rockers and lifters |
No risk |
