kev mc Samba Member
Posted: Sun Sep 22, 2013 12:29 am Post subject: Eckel Herkules roofrack |
hi
recently come across this rack and was wondering if anyone can shed any light on it for me, any help would be appreciated.
_________________ dont hold your farts in they go up your spine into your brain and thats where shity ideas come from |
EverettB Administrator
Joined: April 11, 2000 Posts: 69834 Location: Phoenix Metro
kev mc Samba Member
Posted: Wed Sep 25, 2013 1:16 pm Post subject: |
thanks Everett, I had already seen those. this rack seems to be wider than a bug, so im guessing its not for a beetle. the search continues _________________ dont hold your farts in they go up your spine into your brain and thats where shity ideas come from |
IN2VWS Samba Member
Joined: January 29, 2006 Posts: 2521 Location: Australia
Posted: Wed Sep 25, 2013 2:01 pm Post subject: |
If your not going to give up the dimensions of it, then it is pretty hard to tell you what it fits. _________________ ( ⫏ ⫐ )
(ọ\ ¡ /ọ)¹⁹⁵⁴ ¹⁹⁵¹
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³
𝟵_𝟭_𝟰¹⁹⁷³ |
kev mc Samba Member
Posted: Thu Sep 26, 2013 9:42 am Post subject: |
Yes I've been meaning to get up the lock up recently. I'll be going tomorrow so I will post the measurements up then.
Cheers _________________ dont hold your farts in they go up your spine into your brain and thats where shity ideas come from |
Ellectronico Samba Member
Joined: May 09, 2002 Posts: 529 Location: porterville
Posted: Fri Sep 27, 2013 6:37 pm Post subject: |
that one is defiantly wider then the Eckel i have.
Mine is for a Beetle. A pic of it can be seen in one of the threads Everett posted
mine is aprox:
33 3/4 inches long from the inside of the front cup to the inside of the rear cup
its 30 1/2 inches wide from the inside of the left cup to the inside of the right cup
as for height clearance its about 4 inches from the bottom of the cup to the bottom of the rack _________________ www.56panel.com
www.killerjunk.com
"you need to lower it", "it would look better lowered", "Slam that bitch!", "That would be a slutty bitch if it was lowered", "That bitch would be a bitchin bitch of a bitch bitch bus if it was on its nuts, bitch" |
kev mc Samba Member
Posted: Sat Sep 28, 2013 4:52 am Post subject: |
ok had a measure up and its like this;
external rack dimentions are 46" x 46"
inside edge rubber to rubber 38.5" x 38"
also two of the clamps are 1.5" shorter than the other two.
cheers
kev _________________ dont hold your farts in they go up your spine into your brain and thats where shity ideas come from |
IN2VWS Samba Member
Posted: Sat Sep 28, 2013 5:09 am Post subject: |
The nearest Herkules rack to that size is 117cm x 117cm.
This size rack is listed for the following cars in a 1958 catalog:
BMW 309, 315, 319
BMW 501, 503
Borgward Isabella, 2400
Fiat 1400, 1900
Mercedes 170s, 220
Opel Kapitan 54/56
Volkswagen Bus _________________ ( ⫏ ⫐ )
(ọ\ ¡ /ọ)¹⁹⁵⁴ ¹⁹⁵¹
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³
𝟵_𝟭_𝟰¹⁹⁷³ |
