LED tail lights and turn signals for 1965 beetle
dougnkaren
dougnkaren is offline
PostPosted: Sun Sep 09, 2012 6:29 pm    Post subject: LED tail lights and turn signals for 1965 beetle Reply with quote
Does anyone make LED tail light assemblies and turn signal assemblies.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun Sep 09, 2012 6:32 pm    Post subject: Reply with quote
You can get LED bulbs, just not sure if they make them in 6 volts.
Glenn
Member #1009
#BlueSquare
dougnkaren
PostPosted: Sun Sep 09, 2012 6:41 pm    Post subject: LED Bulbs Reply with quote
Where can you get them? I've tried Mid America, Airhead, Wolfsburg and a couple others. Can't find them. Have a link?
Thanks
Doug
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Mon Sep 10, 2012 10:04 am    Post subject: Reply with quote
There's a few here:
http://www.superbrightleds.com/cgi-bin/store/index...12-24V.htm
esde
esde is offline
PostPosted: Mon Sep 10, 2012 10:13 am    Post subject: Reply with quote
Led snowflakes:
http://www.thesamba.com/vw/forum/viewtopic.php?t=380541&highlight=led+snowflake
if you search LED tail light in the 58-67 forum, it will keep you reading for a while..
fluxcap
fluxcap is offline
PostPosted: Mon Sep 10, 2012 10:36 am    Post subject: Reply with quote
You wanting a whole unit? or just the bulbs?
There are a couple of whole unit set-ups in the classified here, they are 12v though, and honestly don't look very bright to me in the pictures.
http://www.thesamba.com/vw/classifieds/detail.php?id=1267895
http://www.thesamba.com/vw/classifieds/detail.php?id=1268796
If you just want the bulbs, most auto parts stores have them, assuming you have converted to 12v. If you are still 6v, probably not gonna find them in stores easily.
Eric - 1966 camper bus
"It's like, how much more black could this be, and the answer is none.......none more black."
Hugo Stiglitz
Hugo Stiglitz is offline
PostPosted: Mon Sep 10, 2012 1:15 pm    Post subject: Reply with quote
glutamodo wrote:
There's a few here:
That's where I got mine. No need for a "unit". Just buy the bulbs.
From someone who has gone this route, be prepared to spend $200 to convert your brake/running lights, front turns and rear turns over to LED bulbs. It's wise to get an LED flasher relay as well.
You need to use the 45 LED bulbs for the rear to be bright enough during daytime use. At $25 a pop, it gets pricey quickly.
'63 slow n low build thread...
Jay Leno's Garage
(o\ ! /o) | o \/ o | (o)=|=(o) [o\|_|_|/o]
dougnkaren
PostPosted: Mon Sep 10, 2012 5:10 pm    Post subject: Thanks Reply with quote
Thanks to all of you that replied. I have some research to do. I need to look into the LED compatible relay. Didn't even think about that. The superbrightlight website had both 6volt and 12 volt replacements. I need the 6. I have emailed them. We will see what they say. Thanks again to all. I'll be reading for hours it looks like by the forum link! LOL
The Android
PostPosted: Mon Sep 10, 2012 7:13 pm    Post subject: Reply with quote
Too bad those seem to be fairly weak LEDs. (16/3 lumen for the red one.)
Here's another one I came across - they don't give any intensity specs though.
http://www.ledlight.com/s25-24-led-light-6-volt-dc.aspx
dougnkaren
PostPosted: Tue Sep 11, 2012 3:00 am    Post subject: Single / Double Reply with quote
the tail lights are double and this one is single pole. Wont work for the 65 tail lights. It's got to be a replacement style for a 1157
reedwesd
reedwesd is offline
PostPosted: Tue Sep 11, 2012 7:20 pm    Post subject: Reply with quote
I know you can pick up led 1157 bulbs at the parts house here and and truck stops since they have started to convert over. If you need 6v then you could try Ron Francis. They are price but may be able to find them cheaper somewhere else.
http://www.ronfrancis.com/prodinfo.asp?number=LR%2D67
BTW I have converted my 65 over and you may need to run a load res if you have problems with them flashing to fast.
dougnkaren
PostPosted: Wed Sep 12, 2012 6:20 pm    Post subject: Thanks Reply with quote
Thanks Reedwesd those were a bit pricey and I've already ordered some from another site. I'll see how they look and someone else had sent a link from past forum posts on this subject and that was very informative. I will post the results of my experiments one way or the other.
911GT2
911GT2 is offline
PostPosted: Sat Jan 19, 2013 10:10 am    Post subject: Reply with quote
I'm very curious of your findings.
Could you please post some feedback?
I'm especially interested in these lights. Das anybody got them?
dougnkaren
PostPosted: Sun Jan 20, 2013 10:26 am    Post subject: LED Lights Reply with quote
I don't have much to tell. I ordered the incorrect lights and the new tail light assemblies I ordered to remedy the corrosion would not fit even though I ordered the right year make and model. Just some bad luck. I ended up just polishing the existing assemblies and made sure all contacts were bright and shiny and we've just been doing fine with those. I looked at the lights you posted about and they look good. If you buy them and use them let me know how they work. I am selling my house and retiring so all projects are on hold until I get to my next house and get a garage set up. I'll try something then guaranteed. Sorry I was no help just yet.
Doug
'69Custom
'69Custom is offline
PostPosted: Wed Jan 23, 2013 11:07 am    Post subject: Reply with quote
http://www.cool-leds.com/1962-67-vw-led.htm
-Tim
1969 Frankenbug
1965 Ford Mustang
:2gunfire: F-U-M-P!
~"I thought I was wrong once, but I was mistaken." ~The Boss
Please excuse any typos as my iPhone doesn't speak English very well.
tham64 wrote:
Why tune a big round again and again????? For me.... 1 hour will solve the case Cool
www.endlesscustomz.com
The Android
PostPosted: Wed Jan 23, 2013 3:54 pm    Post subject: Reply with quote
Ouch, those kits are expensive. And even worse - they effectively convert the rear lights to "one bulb" operation - and for someone like myself who has Euro style tail light lenses, that is not an option. I would like to know how well they look and work for someone with stock USA-spec all-red taillight lenses.
I'd rather put in matching-color LED bulbs myself, if I was going to LEDs.
-Andy
VOLKSWAGNUT
Fastest VW Belt Changer
Location: Flippin' a Belt........ .... Off-n-On ... NC USA
VOLKSWAGNUT is offline
PostPosted: Wed Jan 23, 2013 4:29 pm    Post subject: Reply with quote
And judging by the videos... they look like Sick ....
Id like to witness those in person, to see if they acaually illuminate the entire lens, or are typical LED directional as the video appears..
aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited
'69Custom
PostPosted: Wed Jan 23, 2013 7:15 pm    Post subject: Reply with quote
-Andy
Agreed, Andy. I've seen demos of that Technostalgia set up with US spec lenses I concluded it was a half-assed attempt and a shoddy result. About all it has going for it is the rapid pulse, but so what?
United Pacific began producing exactly what you and I would love to see, individual areas devoted to each bulb represented but, so far as I'm aware they only make one for the late model Bug.
Until someone makes something quality and worth the investment, I'll stick to seperate LEDs. I have a car-wide set on its way in the mail as we speak.
-Tim
1969 Frankenbug
1965 Ford Mustang
:2gunfire: F-U-M-P!
'69Custom
PostPosted: Wed Jan 23, 2013 7:18 pm    Post subject: Reply with quote
Behind a lens they are exactly what you'd expect Sick . I only provided that link because options were asked for, not as an endorsement.
-Tim
1969 Frankenbug
1965 Ford Mustang
:2gunfire: F-U-M-P!
vs-works
vs-works is offline
PostPosted: Wed Jan 30, 2013 3:09 pm    Post subject: LED tailights from Chip Reply with quote
esde wrote:
Led snowflakes:
Chip made a set for my 61...Great Job...and he is super cool guy. They had to be sanded down a little on the side....maybe I can get you a pic of them later tonight.
VS
