Vintage speed cam from WW
gimmesomeshelter
gimmesomeshelter is offline
PostPosted: Wed Aug 01, 2012 4:31 pm    Post subject: Vintage speed cam from WW Reply with quote
Hello-
WW does it again!
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111109021OK
BTW, I noticed that the lift is .345". I wonder if it will work with 356 crank/rods?
Cheers,
Paul
"I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman
Braukuche
Braukuche is online now
PostPosted: Wed Aug 01, 2012 4:52 pm    Post subject: Re: Vintage speed cam from WW Reply with quote
gimmesomeshelter wrote:
Hello-
WW does it again!
Cheers,
Paul
They keep giving all the lame asses with '60 and earlier type 1s and '58 and earlier type 2s fewer and fewer excuses to not use the correct engine in their vehicle.
Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
L378
L378 is offline
PostPosted: Wed Aug 01, 2012 5:00 pm    Post subject: Reply with quote
and only $119 Shocked Very Happy
splitpile
Samba's Worst Speller
splitpile is offline
PostPosted: Wed Aug 01, 2012 5:18 pm    Post subject: Reply with quote
I'm going to test fit one next week with a Porsche crank.
They also now sell BERG 36hp sumps!
"no more hacking my sig line"
Braukuche
PostPosted: Wed Aug 01, 2012 7:19 pm    Post subject: Reply with quote
Looks nice, but I want one of those early round ones.
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
bdub475
bdub475 is offline
PostPosted: Thu Aug 02, 2012 4:42 pm    Post subject: Reply with quote
Is the grind of the cam the same as the okrasa cam?
36hplandspeedracer
36hplandspeedracer is offline
PostPosted: Thu Aug 02, 2012 5:40 pm    Post subject: Reply with quote
Thanx again Tony and Shaun.
The 36hp world has come alive again with both stock and high performance parts availability. Now the cam! We owe a deep dept of gratitude to Wolfsberg West for investing so deeply as to make a true difference is what and how we can now approach 36hp high performance engines!
And remember, they are providing a $1000.00 contingency award to the fastest record setting DSS Bug, Bus or Ghia equipped with Wolfsburg West dual port heads this September at the World of Speed.
Gotta love-em! ! !
Burly
Alstrup
Alstrup is offline
PostPosted: Fri Aug 03, 2012 1:43 pm    Post subject: Reply with quote
They fail to inform about LC.
-I guess/hope it is about 108, because the stock cam actually has 240 degree @ 0,040, but much less lift, AND is on 100 LC.
I think the cam can have good potential in theur own Okrasa replica kit
T
gimmesomeshelter
PostPosted: Fri Aug 03, 2012 2:36 pm    Post subject: Reply with quote
Hello-
In their monthly email they said the lobe center was 105 degrees. Confused
Cheers,
Paul
Richard Feynman
Braukuche
PostPosted: Fri Aug 03, 2012 3:45 pm    Post subject: Reply with quote
Hello-
Cheers,
Paul
Makensen in your avatar??
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
gimmesomeshelter
PostPosted: Fri Aug 03, 2012 3:53 pm    Post subject: Reply with quote
Braukuche-
OT alert!
Yes.
BTW, I've always felt that I was born in the wrong century. I go ga-ga over stuff like this:
http://www.kaisersbunker.com/pt/pelzmutze.htm
http://www.kaisersbunker.com/pt/tschapka.htm
P-
Richard Feynman
avus
avus is offline
PostPosted: Fri Aug 03, 2012 7:40 pm    Post subject: Reply with quote
Watch out for your ragtop!
Braukuche-
OT alert!
Yes.
P-
slalombuggy
slalombuggy is offline
PostPosted: Tue Aug 07, 2012 7:28 am    Post subject: Reply with quote
Braukuche-
OT alert!
Yes.
P-
Do they make an SA rated version????? Shocked Laughing
brad
avus
avus is offline
PostPosted: Tue Aug 07, 2012 8:24 am    Post subject: Reply with quote
Braukuche-
OT alert!
Yes.
P-
brad
No HANS device required--Just a hole in the roll cage with a rubber grommet!!
slalombuggy
PostPosted: Tue Aug 07, 2012 9:35 am    Post subject: Reply with quote
Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing
brad
Altema
Altema is offline
PostPosted: Sat Aug 18, 2012 6:44 pm    Post subject: Reply with quote
I almost choked on that! Laughing
gimmesomeshelter
PostPosted: Thu Aug 30, 2012 1:30 pm    Post subject: Reply with quote
Hello-
Has anyone tried this cam yet?
Cheers,
Paul
Richard Feynman
oldbusboy
oldbusboy is offline
PostPosted: Tue Mar 26, 2013 6:11 pm    Post subject: Reply with quote
I assume if I wanted to use straight cut cam gears I could bolt them to this cam?
Trevor
1968 porsche
Mr. Motorhead
Mad Scientist
Mr. Motorhead is offline
PostPosted: Tue Mar 26, 2013 7:36 pm    Post subject: Reply with quote
Straight cut gears work fine, the bolt holes are tapped for 8mm x 1.25 pitch bolts. WW sells no cam gears so you are on your own if you want to run a stock aluminum gear. Sometimes I get good gears on some of the cams I have reground, but lately not very many. The billets are nice, I'm getting ready to run one in one of my cars.
30 years experience in the sales of new and used auto parts!
36 horsepower parts for sale at http://www.aircooledresearch.com/
Or the new site at http://www.bugparts.com
Check out the Bonneville project:
http://aircooledresearch.com/docs/thebonnevilleproject.html#
"All limitations are self imposed."
Some Chinese guy
oldbusboy
PostPosted: Tue Mar 26, 2013 8:10 pm    Post subject: Reply with quote
Do you still have these in stock and are these the ones you you would suggest using with the WW cam mentioned above?
http://www.aircooledresearch.com/docs/parts_cam_gear_std.html
Trevor
1968 porsche
