oktr6r Samba Member
Joined: March 02, 2008 Posts: 1436 Location: Sand Springs, Ok
Posted: Wed May 28, 2008 8:09 pm Post subject: Emergency kit: parts, tools, misc. to pack? |
As I found out this weekend, spare pushrods and tubes should be in a spares kit, along with hose, clamps, wire ties, for temp. repairs.
Spares:
Pushrods and tubes
Hose, clamps, ties for patching tubes
Spare fan belt
Brake fluid
Oil
Fuses
Wire, various gauges
Electrical tape
Tire
Tools I've been carrying:
Hydraulic floor jack (In a kit w/ impact below)
12VDC electric impact
Sockets for above
Ball peen hammer
Socket set w/ ratchets and extensions
Screwdrivers
Pliers
Wire strippers
What spares and/or tools have you needed? _________________ Les
'73 Thing - Offroad project
'68 Lightning Bug Baja
'66 Type 1 waiting heart transplant
'60 Baja Volkstruckin' future project
'58 Chassis w/ Beau Hickory Virgo body
Quote from RLAP: "dude i think the last thing you need in your bug is more horsepower, you would only get yourself into trouble" |
pafree Samba Member
Joined: August 16, 2005 Posts: 2298 Location: dayton, the one in texas
Posted: Wed May 28, 2008 9:02 pm Post subject: |
after last time we went out for a big weekend. i added a couple of things.
alternator pulley and nut
i brought a spare clutch but forgot the centering pin and flywheel lock.
a box of extra nuts and bolts 10,13,17s
extra air filter for those dusty days.
heavy duty ratchet strap to hold the motor up when you blowout the nose cone mount.
WD 40
an extra dist. i have found it is easier to change the whole dist than just the point and condensor. timing lights.
extra coil |
dirtkeeper Samba Member
Joined: February 19, 2008 Posts: 3200 Location: Left of everywhere
Posted: Thu May 29, 2008 7:52 am Post subject: |
aluminum tape and aluminum foil and bailing wire.
On a trip across the country and canada once i found auto parts stores rare and far in between. with aluminum foil and bailing wire i was able to repair exhaust leaks and it would get me many miles before it would wear out.
i also carried along
xtra coil and some tie rod ends and a regulator and some of the items mentioned by others. ... and xtra keys |
turboblue Samba Member
Joined: October 09, 2003 Posts: 4216 Location: Central Indiana
Posted: Thu May 29, 2008 8:37 am Post subject: |
Learned this tip from a buddy of mine.
Put a extra nut on every bolt that has the threads exposed.
Easy way to carry extras w/o the hassle of a container. _________________ Gary
Turbo VW Sand Drag Buggy
"If you don't run into the Devil every once in awhile, you must be going in the same direction!" |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20386 Location: Just a tiny bit west of Yosemite Valley
Posted: Thu May 29, 2008 9:33 am Post subject: |
What brand "electric impact" and how would you rate it?
baja72 Samba Member
Joined: January 17, 2008 Posts: 456 Location: Bremen , Ga.
Posted: Thu May 29, 2008 9:58 am Post subject: |
Even if you have a winch, I would carry a come-a-long and a good tow strap. Don't forget about extra gas. I know that sounds like a DUH, but you never know what might happen. |
turnaround89 Samba Member
Joined: June 05, 2006 Posts: 493 Location: Rockford, Illinois
Posted: Thu May 29, 2008 10:17 am Post subject: |
JB weld, comes in handy is some weird situations!! _________________ 1971 Baja Bug
1972 Porsche 914 |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5606 Location: 37.5N 77.1W
Posted: Thu May 29, 2008 10:40 am Post subject: |
Can of 'Fix-a-Flat"
Fuel pump
Vise Grips...small to large size
Various springs to hold stuff on and throttle return
A 'Hammer Wrench', or whatever those things are called, for the rear axle nuts
A ratchet strap comes in handy for seating the beads on a tubeless tire that has lost all of it's air
Hose clamps...small to large
Crazy Glue |
Ace Samba Member
Posted: Thu May 29, 2008 10:45 am Post subject: |
a coil of baling wire will save your butt too. |
oktr6r Samba Member
Posted: Thu May 29, 2008 10:51 am Post subject: |
Dale M. wrote: |
Dale |
AC Delco, from the local Oreilly's Auto Parts. It has more torque than my air impact. I've broke bolts loose with it that my air impact and a 1/2" break over wouldn't touch. The kit contains the impact with sockets for lug nuts and a 2 ton floor jack for $49.99.
http://www.oreillyauto.com/EW3/ProductDetail.do?id...rentPage=0 _________________ Les
bajaherbie Samba Sooner
Joined: November 27, 2003 Posts: 2985 Location: altus, oklahoma
Posted: Thu May 29, 2008 11:01 am Post subject: |
cellphone... _________________ blank |
seabeebuggy Samba Member
Joined: October 03, 2005 Posts: 2395 Location: NM, CA, UT and now NV
Posted: Thu May 29, 2008 4:06 pm Post subject: |
I have 500$ worth of parts in my kit. most of everything above and things like Jets for places the car may not like, carb rebuild kits. Oil hose to bypass a filter if busted. wire , duct tape, pulleys nuts bolts ,belts, fuel line, flares, lug nuts, hose clamps , oil,oil, oil. parts to remove oil slump if broke , compressor, Pushrods , pushrod tubes, rockers, extra valve and lock for each size, vacuum line, complete ignition 685, red lock tight, springs, plugs for brake line, extra brake line brake fluid, Ham radio, water, MRE's Flashlights, e blanket, 45 colt, ammo , ear plugs, first aid kit, Extra burn cream, Someone all ways needs it. cb radio, Rope, Chalks for tires, jack, fire, light bulbs, test light, Turbo parts, there is more. It all fits into a large ammo can. _________________ Seabee turbo buggy build
(Quote Runslikeapenguin said)
so to everyone else whos not a retarded butt pirate marine with an tacky ugly ass car covered in auto zone bolt and stick on s**t. (end quote)
A better place to talk offroad |
2gr8dgs Samba Member
Joined: June 20, 2005 Posts: 491 Location: salem,oregon
Posted: Thu May 29, 2008 8:18 pm Post subject: |
to add to the list, extra throttle cable, spare clutch cable. 12v tire inflator |
Mr. Unpopular Samba Member
Joined: September 20, 2005 Posts: 3715 Location: Tampa Florida
Posted: Fri May 30, 2008 10:12 am Post subject: |
Lets expand the topic a bit. Show us HOW you carry these items. As the owner of a Berrien warrior buggy, I need some tips on where to stuff all of this stuff _________________ "In any racing engine, the nearer you are to it disintegrating, the better it's performance will be"
-Keith Duckworth, creator of the Ford/Cosworth DFV |
DesertBob Samba Member
Joined: February 09, 2004 Posts: 1245 Location: Goodlettsville, Tennessee
Posted: Fri May 30, 2008 10:18 am Post subject: |
Here's a link to the Sticky on the Thing forum. It has lots of good info on what to carry that would be applicable to our Baja/Rail use.
http://www.thesamba.com/vw/forum/viewtopic.php?t=183148 _________________ All it takes is a little imagination, some mechanical ability, and neighbors who mind their own business
74 Super Beetle (German Look Project)
Full Flow 1776 with 36 Dells, 4 wheel drilled and slotted disc brakes, Porsche 7x17 Turbo Twists, Topline Maxx Struts, Camber kit, 7/8" Front Sway bar, Rear Sway bar, Urethane bushings all around. |
bigpapakamen Samba Member
Joined: March 16, 2007 Posts: 293 Location: denison tx
Posted: Fri May 30, 2008 12:52 pm Post subject: |
i cant believe that only one person put duck tape
duck tape
zip ties
high lift jack
come along/rachet strap/ chain at least one
a small tool box full of wrenches sockets ratchets
a flash lite
grease rags
beer _________________ proud owner of half ass customs |
nukeworker Samba Member
Joined: September 21, 2005 Posts: 490 Location: Area 51
Posted: Fri May 30, 2008 4:45 pm Post subject: |
Instead of a 12V air pump, I found a cool one at walmart that can be used by hand or stepping on a foot pedal. Less than 10 bucks plus if the battery is low or dead, I can still use it. If the battery is dead, and you're on a hill, you can still roll start. |
Posted: Fri May 30, 2008 4:56 pm Post subject: |
old photo but everything is on top.
[img][/img]
end view.
baja kid Samba Member
Joined: May 04, 2007 Posts: 663 Location: sunny san diego!!!!!!
Posted: Fri May 30, 2008 5:06 pm Post subject: |
bajaherbie wrote: |
cellphone... |
thats all one really needs and of course racer tape also know as duct tape but it just sounds way cooler haha _________________ My old Baja Bug thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=243718 |
cr250250r Samba Member
Posted: Fri May 30, 2008 7:35 pm Post subject: |
I always have a first aid kit. Just put alot of extra asprin for hangovers. People don't know how hung over they are until they hear something loud. |
