asad Samba Member
Joined: October 07, 2004 Posts: 77 Location: Dhaka, Bangladesh
Posted: Thu Oct 07, 2004 7:07 am Post subject: my 69 bug! |
http://drivetimedhaka.com/photo_lib/displayimage.php?album=11&pos=0
this is my daily driver, a 69 BUG fitted with a 1600cc, disc brakes and custom free flow exhaust.
i am going to change the wheels and tires to FUCHS Porsche 16". with 205/55/16. i hope they fit, looking for adapters now for the transition.
do check out my website, and the cars in our country BANGLADESH. |
Skim Rants Master
Joined: April 15, 2001 Posts: 17082 Location: GFK 31 Year Vet
Posted: Thu Oct 07, 2004 7:24 am Post subject: Re: my 69 bug! |
asad wrote: |
Hi Asad, the 16" fuchs will fit but I would suggest a couple of things to make everything come together smoothly. Since you are running disk brakes, have the rotors drilled to the Porsche pattern (5x130 mm) and stay away from adapters. In the rear you can run pre-drilled Porsche pattern drums (Or have your 4 lug drums redrilled) That will save you an inch per wheel. Also, I would recommend narrowing the beam atleast 2 inches with 205x55 16"s.
CB Performance has all of this. good luck
http://www.cbperformance.com/
http://www.cbperformance.com/category.asp?categoryid=14 _________________ GFK
1953 Kabriolet
1954 Sunroof
1959 Lowlight Ghia vert
1963 Deluxe Turkis Walk Thru 15 Window OG Paint |
