2type2 Samba Member
Joined: June 02, 2002 Posts: 990 Location: SW Colorado
Posted: Thu May 02, 2024 11:42 am Post subject: Flywheel converted to 12v confusion, sans o ring / edit |
My 66 Bus is running 2017 , AS21 case. Got leak at flywheel, anxiously yanked off flywheel before checking endplay, crap. Anyway I'm confused: flywheel originally 6v, has been re-ringed to 130 splines ,running autostick starter, works great.
Unfortunately No oring or any groove for one. So question is, ---Best to include metal, or no gasket between crank and flywheel?? I polished the 'snout 'glassy smooth. Reading more----.Some say use a thin loctite 518(anaerobic gasket sealant) between and the metal gasket. It's 8 dowelled and had a metal one. I'm well acquainted with seal installation, and have dial guage rig for end play. _________________ "A life of peace and happiness depends on your own gratefulness" |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14314 Location: Casa de Oro, California
Posted: Thu May 02, 2024 6:36 pm Post subject: Re: Flywheel converted to 12v confusion, sans o ring / edit |
Original 6 volt stepped non-o-ring flywheel had paper gasket. But I think you should use the way it was especially if you have 8 dowel.
If you had the OG 6 volt stepped flywheel you would set the endplay with the gasket counted in the shim stack. Then replace it with another fresh one.
Your metal 8 hole "gasket" will count in the shim stack as well. |
