CowardVenus15 Samba Member
Joined: August 03, 2023 Posts: 19 Location: Monterey, CA
Posted: Sat Apr 27, 2024 6:27 pm Post subject: Adjustable clutch lever lash mod |
I broke the nose off my clutch lever and decided to fix it in a way that’s adjustable. Let me know what you think!
vanis13 Samba Member
Joined: August 15, 2010 Posts: 3150 Location: ABQ NM USA.... Except when not
Posted: Sat Apr 27, 2024 6:32 pm Post subject: Re: Adjustable clutch lever lash mod |
Clever.
Though I think the hydraulic slave cylinder auto adjusts.
And there have been issues with piston length distance variations so this may also be a good solution for that scenario.
Looking forward to hearing how it holds up.
Nice work! _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
iceracer Samba Member
Joined: February 28, 2006 Posts: 951 Location: Milwaukee, Wisconsin
Posted: Mon Apr 29, 2024 10:33 am Post subject: Re: Adjustable clutch lever lash mod |
If you are doing this because you clutch pedal has too much travel, you probably have a worn clutch pedal clevis pin. That is the fix you need. I like your idea but i think it is a temporary fix. _________________ 86 Syncro Wolfsburg edition
63 Beetle (The Iceracer) |
Posted: Mon Apr 29, 2024 1:13 pm Post subject: Re: Adjustable clutch lever lash mod |
CowardVenus15 wrote: |
I broke the nose off my clutch lever |
