mattybobatty Samba Member
Posted: Fri Apr 26, 2024 9:14 am Post subject: tail light converter |
my buggy has 2, dual filament lights at each rear corner. in order to get the "brake" lights to blink for turn, i installed a cheapy tail light converter, from 3 to 2. basically makes the turn signal the brake signal also, but will cancel pending on what is commanded.
question: who else has something like this? using a curt product, its already failed. the next new one installed shows power must be jumping through it to the tail light circuit. meaning when i hit the brakes, or use the turn signal, i have parking lights coming on too, as well as the cluster lights.
i do not want to run another signal bulb/light out back _________________ junk |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20412 Location: Just a tiny bit west of Yosemite Valley
Posted: Fri Apr 26, 2024 9:48 am Post subject: Re: tail light converter |
Products from this seller seem to be first rate, have recommended it to people in past and have not had any negative feedback.... Found them after having 2 lesser expensive converters fail...
https://www.signaldynamics.com/lighting-control-modules/ _________________ “Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
Posted: Fri Apr 26, 2024 11:11 am Post subject: Re: tail light converter |
thanks dale. i just checked out the site, they're descriptors show i dont need to use a flasher because its internal to the module. not going to rewire too much, i'll see if anyone else posts suggested brands. im not opposed to rewiring and getting something more reliable though, but not quite yet. _________________ junk |
516swg Samba Member
Posted: Fri May 03, 2024 3:31 pm Post subject: Re: tail light converter |
Check out my thread called
Meet Samantha. I just went through this |
Bikerndiver Samba Member
Joined: December 05, 2023 Posts: 125 Location: Mid-Atlantic
Posted: Fri May 03, 2024 6:42 pm Post subject: Re: tail light converter |
I second Signal Dynamics. I've used their products on my motorcycles for 20 years and they are first rate. They also have a great customer service dept to help you if you have an issue _________________ 1966 Manx clone (possibly a Joe Poty Enterprises) named SANDY. '70 to '73 1300 cc w/1600 DP heads, twin carbs and headers |
