ragtop man Samba Member
Posted: Fri Apr 26, 2024 4:03 am Post subject: 111.415.131 steering box? |
I have a good steering box with the part # 111.415.131. I am wondering what years beetle this will fit. any help would be appreciated. |
mukluk Samba Member
Joined: October 18, 2012 Posts: 7033 Location: Clyde, TX
Posted: Fri Apr 26, 2024 4:34 pm Post subject: Re: 111.415.131 steering box? |
That's the part number for the cover of a sector type steering box, used up through the '61 to early '62 Deluxe model (depending on market) or up through a '65 Standard model. It'll technically fit pretty much any front torsion beam suspension Type 1 if you want, but it was only originally used on the previously listed ones. _________________ 1960 Ragtop w/Semaphores "Inga" |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24830 Location: Olympia Wash Rinse & Repeat
Posted: Fri Apr 26, 2024 8:00 pm Post subject: Re: 111.415.131 steering box? |
The type 1 original VW dealer parts manual is here:
http://www.oacdp.org/
Thru the "Upcoming" button at upper right.
Just the exploded diagrams are worth the time to view. You can also do WW searches for VW parts by using the parts numbers in the VW parts manuals. For instance the rear drum part number add VW before it, for "VW 211501615" or put in dashes instead of the spaces Vw used "VW 211-501-615". Do leave off the letter suffix to keep things simpler, then look for the results with the "E".
Keep in mind about every nine digit VW part number:
A. That the very first digit is what model of VW the part was originally designed for. Lots of type 1 parts on the type 2s, some type 2 and 3 parts were used in the type 1. Other parts are only used on that type of VW and no other.
B. 2nd and 3rd digits are the model the part was originally designed for. Some parts are ONLY for that model. Others were later fitted to all VW models.
C. 4th digit tells you which section/chapter of the parts manual the part is found in.
D. The 5th thru 9th digits are the actual part number.
E. Letter suffix means it is an improved part over the last part without letter suffix, or as each letter ( A, B, C, D, etc.) is used the later letter means some change has been made. Sometimes each later part can be used directly in the same area, some can not without replacing other parts around it.
F. If you know a part is RH or LH ONLY, you can tell by the last digit of the part number which side it goes on. an even digit then the part is RH, odd digit and the part is LH. Easiest way to remember this is that a LH drive VW has to have at least the driver, so one person, which is an odd digit. A VW with one driver and one passenger is two people, so an even digit. _________________ In Stereo, Where Available! |
Posted: Sat Apr 27, 2024 3:59 am Post subject: Re: 111.415.131 steering box? |
Thank y'all, for your help! I really appreciate it. Thats what I needed to know. |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6666 Location: Houston, Texas
Posted: Sat Apr 27, 2024 3:06 pm Post subject: Re: 111.415.131 steering box? |
You can use any of the steering gearboxes from any of the years. You have the early box which was used up until 1961 when the new style of box was introduced. If you want to use the later style box on an early car you need a later style pitman arm. The large hole on the pitman arm is the main difference in usability between the two boxes. _________________ www.vwnos.com [email protected]
viiking Samba Member
Joined: May 10, 2013 Posts: 2682 Location: Sydney Australia
Posted: Sun Apr 28, 2024 2:29 pm Post subject: Re: 111.415.131 steering box? |
Eric&Barb wrote: |
F. If you know a part is RH or LH ONLY, you can tell by the last digit of the part number which side it goes on. an even digit then the part is RH, odd digit and the part is LH. Easiest way to remember this is that a LH drive VW has to have at least the driver, so one person, which is an odd digit. A VW with one driver and one passenger is two people, so an even digit. |
Great and detailed explanation for the newby except when you get here. My RHD VW only has to have one driver as well. 😊
The way I always remember it is for European based numeracy written left to right I.e. 1,2,3,4…, the first number (1) is left of the even number(2). _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
