yel-mel Samba Member
Joined: May 07, 2015 Posts: 428 Location: Tampa Florida
Posted: Thu Apr 25, 2024 2:53 pm Post subject: Quick rpm question please |
Stock 1600 Beetle engine reading rpms at the belt with a touch tachometer and getting 8000 at idle. Is that good ? Im assuming the 8000 on the readout must correspond to 800rpm....not sure how that works
Using an extech 461895 meter |
bsairhead Samba Member
Joined: October 08, 2008 Posts: 3635 Location: viroqua wi.
Posted: Thu Apr 25, 2024 3:10 pm Post subject: Re: Quick rpm question please |
yel-mel wrote: |
You mean old school mechanical tachometer? |
Posted: Thu Apr 25, 2024 3:12 pm Post subject: Re: Quick rpm question please |
It does have a digital display readout, but the mechanism is a wheel that you hold against the belt or pully.
I dont have a tach in the car....is there a better tool to use ? Trying to dial in my carb
Thanks |
Posted: Thu Apr 25, 2024 3:37 pm Post subject: Re: Quick rpm question please |
yel-mel wrote: |
Thanks |
You need to use it on the crank pulley nut which you do not have easy access to. A dwell/rpm meter or strobe with tach is what you want. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51278 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Apr 25, 2024 4:09 pm Post subject: Re: Quick rpm question please |
The wheel reads feet per minute, you'll have to use math and determine the lower pulley's circumference. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Apr 25, 2024 4:10 pm Post subject: Re: Quick rpm question please |
bsairhead wrote: |
yel-mel wrote: |
Thanks |
I ciphered on it and and as long as the wheel on the tach reads 1=1 it should be same same. |
Posted: Thu Apr 25, 2024 4:13 pm Post subject: Re: Quick rpm question please |
bsairhead wrote: |
..... as long as the wheel on the tach reads 1=1 it should be same same. |
1:1 what(s)? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Apr 25, 2024 4:34 pm Post subject: Re: Quick rpm question please |
Sorry it's not super clear . Bottom line what is the best device to test engine idle RPMs & how to use it ,if your bug does not have a tachometer on the dash.
Thanks for your input, the wheel touch tachometer I'm using is a pain in the butt anyway, easier to get something better. |
Posted: Thu Apr 25, 2024 4:43 pm Post subject: Re: Quick rpm question please |
A dwell meter often includes a tachometer feature, to adjust your points properly you need a dwell meter. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Apr 25, 2024 4:55 pm Post subject: Re: Quick rpm question please |
busdaddy wrote: |
bsairhead wrote: |
1:1 what(s)? |
If it reads on the end, not on the side of the tach or the tach wheel is the same size as the drive wheel it will be right. Sounds like your tach's wheel circumference is 1/10 of the pulleys. That is if your reading 8000 and your only doing 800. |
kpf Samba Member
Joined: March 01, 2017 Posts: 867 Location: California, US
Posted: Fri Apr 26, 2024 8:34 am Post subject: Re: Quick rpm question please |
The Extech 461895 meter has three modes:
- Photo rpm
- Contact rpm
- Surface speed ft/minute or m/minute
Holding the little wheel against the belt can be done with the surface speed setting, but as was mentioned, you'll have to use math (and a ruler) to get from feet per minute to crankshaft rpm.
The best of those three modes to use for an air-cooled VW will be the photo mode. You'll have to add a small piece of reflective white tape to your crankshaft pulley, then point the photo sensor at the face of the spinning pulley. The readout will be in RPM directly (no math involved).
See: https://www.manualslib.com/manual/1384380/Extech-Instruments-461895.html?page=3#manual _________________ 1971 Super Beetle |
