pop.pop1955 Samba Member
Joined: October 31, 2021 Posts: 47 Location: Palm Coast, Fl.
Posted: Thu Apr 25, 2024 7:19 am Post subject: Death wobble |
71 Super sometimes at 45 MPH i get the death wobble in the steering, doesn't happen all the time. Tie rod ends and centerlink are new, everything else in the front end looks good. Just had an alignment. What should I be looking at? Again it doesn't happen all the time _________________ let your conscious be your guide |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34102 Location: Conejo Valley, CA
Posted: Thu Apr 25, 2024 7:43 am Post subject: Re: Death wobble |
Bent rim? Are they balanced? _________________ Current Fleet:
'71 Fastback
'69 Westfalia
Retired:
'67 Beetle
'65 Beetle (x2)
'65 Bus
'71 Squareback |
74VWSunBug Samba Member
Posted: Thu Apr 25, 2024 9:04 am Post subject: Re: Death wobble |
Back in the day when my SunBug was new, I got that death wobble a few times & a call to the dealership always got this answer: "adjust the front tires air pressure to as recommended in the manual & be sure that both are set the same."
It worked. |
bhartwell59 Samba Member
Joined: December 28, 2014 Posts: 797 Location: dallas, tx
Posted: Thu Apr 25, 2024 10:38 am Post subject: Re: Death wobble |
Ball joints? _________________ '74 Zambezi green Ghia vert, autostick, 101k
'87 Jeep Wrangler, 4.2, 330k |
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4432 Location: Stuck in Ohio
bsairhead Samba Member
Joined: October 08, 2008 Posts: 3628 Location: viroqua wi.
Posted: Thu Apr 25, 2024 10:55 am Post subject: Re: Death wobble |
pop.pop1955 wrote: |
71 Super sometimes at 45 MPH i get the death wobble in the steering, doesn't happen all the time. Tie rod ends and centerlink are new, everything else in the front end looks good. Just had an alignment. What should I be looking at? Again it doesn't happen all the time |
"Just had an alignment" It did it before? Right. |
lboos Samba Member
Joined: November 20, 2015 Posts: 411 Location: Marietta GA.
Posted: Thu Apr 25, 2024 10:59 am Post subject: Re: Death wobble |
How old are your tires ?
Are they worn ?
If so replace them.
Take your bug to a tire shop that can still balance the front tires while on the car [speed balancing] a lot of them still do. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31453 Location: Hot Arizona
Posted: Thu Apr 25, 2024 11:14 am Post subject: Re: Death wobble |
Super Beetle Shimmy !!!
I fixed mine about 25 years ago by getting new idler arm bushing, new tie rod ends, new front bushings. I think the front bushings still had some life left in them.
_________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
talljordan Samba Member
Joined: January 10, 2012 Posts: 983 Location: San Francisco, CA
Posted: Thu Apr 25, 2024 12:55 pm Post subject: Re: Death wobble |
Upper and lower control arm bushings. You cant inspect them without removing the control arms from the frame.
This is the issue 9/10 times _________________ 1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
Wanted: Male computer diagnostic plug end |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 10026 Location: Huntington Beach, CA
Posted: Thu Apr 25, 2024 1:43 pm Post subject: Re: Death wobble |
Inner control arm bushings. Where they attach to the pan. That is it EVERYTIME!
And who the hell did the alignment? That’s a big oversight!
Take a medium size prybar and wedge it in between the pan and the bushing. Give it a bit of pressure towards the tire. It should have a lot of resistance. If it moves more than an 1/16”, get a bright flashlight and get a good look at it! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
vamram Samba Member
Posted: Fri Apr 26, 2024 6:45 am Post subject: Re: Death wobble |
VW_Jimbo wrote: |
Jimbo - in my experience, bad ball joints will cause the shimmy as well as a "clunk." _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
Starbucket Samba Member
Posted: Fri Apr 26, 2024 7:02 am Post subject: Re: Death wobble |
What size are the front tires? Wide rims and wide tires magnify any worn bushings and will cause the shimmy at 45 - 55. |
dennismcd707 Samba Member
Joined: October 09, 2017 Posts: 523 Location: Burbs of Detroit
Posted: Fri Apr 26, 2024 10:47 am Post subject: Re: Death wobble |
My 71 Super had the shimmy at 50mph. I had the track arm bushings replaced, and no more shimmy. I think the track arm is also called the control arm? I'm not sure on this. _________________ 1971 Super Beetle, 1776, dual Weber's, roller crank, big valve modified racing heads, close ratio trans, lowered suspension, 4 wheel disc brakes, car has over 368,000 actual miles. (RIP 1970 Beetle/Baja, 1986 GTI, 1999 Jetta, 2002 Jetta) |
passionre Samba Member
Joined: November 28, 2021 Posts: 70 Location: Oklahoma
Posted: Fri Apr 26, 2024 2:40 pm Post subject: Re: Death wobble |
Have the balance checked on your tires first. If not that, replaced all bushings with Neoprene and lube with Silicone grease only. Take a look at your lower ball joints and look at the steering joints closely. Supers can be made to drive vibration free if you cover your bases. |
kpf Samba Member
Joined: March 01, 2017 Posts: 867 Location: California, US
Posted: Fri Apr 26, 2024 4:15 pm Post subject: Re: Death wobble |
As mentioned, check tire pressure (it's free, quick, and easy!). Factory spec is 18 psi for the front tires. Yes, 18. _________________ 1971 Super Beetle |
Posted: Fri Apr 26, 2024 4:53 pm Post subject: Re: Death wobble |
Yeah, we all tend to get over eager here when it comes to wobble, but start with the free things before paying for stuff.
In order, check:
-Tire Pressure
-Ball Joints
-Inner control arm bushings
-Steering idler
-Tie rod ends
THEN start thinking about buying parts and paying for things like
-Alignment
-Wheel Balance.
The rest of us should probably wait for OP to respond back with what they have inspected.
[/list] _________________ 1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
Cusser Samba Member
Posted: Fri Apr 26, 2024 4:59 pm Post subject: Re: Death wobble |
In 2022 my 1988 Mazda B2200 truck had similar steering wobble at high speed. My rear tires needed replacing, so I couldn't try the rear tires on the front.
I had lifetime warranty and closeout front end parts, so I installed new ball joints, tie rod ends, tensioner bushings, and sway bar bushings, and fixed a loose steering coupler, but stayed the same. Since I needed new rear tires, I went to tire store who said the fronts needed re-balancing - but weren't sure if that was enough to cause my issue. So I had the 2 brand-new tires put on the front, that fixed mine _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
volksworld Samba Member
Joined: November 26, 2011 Posts: 2530 Location: formerly NY currently NC
Posted: Sat Apr 27, 2024 7:26 am Post subject: Re: Death wobble |
lower inner bushings were the usual suspect...and were only cured by genuine VW bushings...the rubber on the aftermarket ones was too soft and the center sleeve too thin so they shook worse than the ones you just replaced....since i havent seen a real bushing in 15 yrs this is one of the few occasions that i recommend urethane ones...they dont rotate enough to squeak in this application....another issue i've seen are tie rod ends that have a raised "derby hat" shape...the extra bump houses a spring that should help prevent play in a worn joint but instead allows it to wobble when enough pressure is applied....so stick to the ones with the flat tops....rims and tires need to be round, many aftermarket (even stock) ones arent....and and a perfectly balanced tire that isnt round will still shake....additionally if the car has been driven long enough with a bad front end the tires will have a "hop" worn into them that will persist even after you replace all the front end parts....so theres plenty of reasons why the "everything in the front end is new" cars still shake |
Posted: Sat Apr 27, 2024 9:21 am Post subject: Re: Death wobble |
First let me say thank you to everybody that answered. I had checked ball joints and bushings etc. and everything checked out. It never occurred to me to check the tire pressure and low and behold the tire shop that did the alignment saw fit to air all the tires to 30psi _________________ let your conscious be your guide |
Cusser Samba Member
Posted: Sat Apr 27, 2024 11:25 am Post subject: Re: Death wobble |
. It never occurred to me to check the tire pressure and low and behold the tire shop that did the alignment saw fit to air all the tires to 30psi |
When getting brand-new tires, even if I tell them which pressures I want (from door sticker), I ALWAYS double check the pressures myself when I get home. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
