Chris coe Samba Member
Posted: Mon Apr 22, 2024 6:02 am Post subject: Beetle bogs down and splatters only on drive |
Hi all can any 1 put some light on this problem 1600cc 1972 idles fine revs fine but when you put it in gear it bogs and chough and splatters things that been changed plugs twice leads twice whole dizzy now bk to points new fuel pump new fuel lines and filter new coil twice 2nd carb striped cleaned new jets float and needle and gaskets and measured the squit of fuel and that's all good values checked and all good standard air filter no vacuum leaks and wires have been checked il lost any help |
jinx758 Samba Member
Joined: October 04, 2014 Posts: 710 Location: half a bubble from plumb
Posted: Mon Apr 22, 2024 9:14 am Post subject: Re: Beetle bogs down and splatters only on drive |
This hurts my brain - use punctuation!
Good luck ... stay safe
jinx _________________ " It's not valuable unless you learn something from an experience. " Henry Ford
It's not unlike the same difference
You can't push a rope
Why did the cowboy get a Dachshund?
Someone told him to "get a long little doggy".
What did the fish say when it swam into the wall ?
"DAM" !
My Craigslist rescued 100 footer :
1971 Standard Bug
1776cc dual port
034 distributor
38mm EGAS Carburetor |
Posted: Mon Apr 22, 2024 11:22 am Post subject: Re: Beetle bogs down and splatters only on drive |
Values set cold, points are gapped runs the same on electronic ignition, timing is bang on ,carb was set when engine was hot and turned and all grounds are done |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6658 Location: Houston, Texas
Posted: Tue Apr 23, 2024 8:57 am Post subject: Re: Beetle bogs down and splatters only on drive |
Can you start from the beginning? What happens when you start the car? What happens when you press the gas pedal? _________________ www.vwnos.com [email protected]
Posted: Tue Apr 23, 2024 9:27 am Post subject: Re: Beetle bogs down and splatters only on drive |
Hi.it starts fine idles fine you can rev it all good it's when put her in gear go to drive as soon as you push the gas it bogs down and chough and splatters the plugs get black sooty but the fuel from the carb is bang been measured and the carb has been turned so on idle the co is all good |
Posted: Tue Apr 23, 2024 12:29 pm Post subject: Re: Beetle bogs down and splatters only on drive |
Some may-bees :
*Brakes dragging/E-brake not engaging
*Distributor not advancing
*Clutch outta adjustment
*Weak spark
*Plugs fouled
*Accelerator pump squirt weak/not aimed correctly
*Bad condenser
*Dwell/timing off
Good luck... stay safe
"DAM" !
1971 Standard Bug
1776cc dual port
034 distributor
Posted: Tue Apr 23, 2024 11:23 pm Post subject: Re: Beetle bogs down and splatters only on drive |
All of them have been checked and nothing wrong there so lost |
Prazeres Samba Member
Posted: Wed Apr 24, 2024 12:35 am Post subject: Re: Beetle bogs down and splatters only on drive |
Most folks are going to recomend perform standard tune-up steps, prior to any further troubleshooting and potential fix ideas
1) check and adjust the valves (engine cold)
2) check spark plugs forcorrect gaps
3) check and adjust points for correct gap / dwell setting
4) check and adjust timing at high rpm and idle
5) adjust idle speed via carburetor adjustment screw(s)
6)"Coil test With the coil completely disconnected, test the resistance between the #15 and #1 terminals. A stock coil should read between 3~4ohms. |
Posted: Wed Apr 24, 2024 2:50 am Post subject: Re: Beetle bogs down and splatters only on drive |
Thanks for the help but all that has been done every thing is bang |
Joined: August 31, 2013 Posts: 12883 Location: North Carolina
Posted: Wed Apr 24, 2024 6:26 am Post subject: Re: Beetle bogs down and splatters only on drive |
It would be much easier to help if you’d lose whatever local slang you’re using & describe the symptoms with proper terminology.
WTF is “splatters”?!?
Wait…. Am I actually telling someone in England to use proper English?!? _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
PatJr Samba Member
Posted: Wed Apr 24, 2024 7:05 am Post subject: Re: Beetle bogs down and splatters only on drive |
hear's a wild shot in the dark, do a compression test and see if you can match up #1 TDC with the crank pully, maybe the cam had had an issue? _________________ #############################################
1970 Transporter a orange one
Posted: Wed Apr 24, 2024 7:21 am Post subject: Re: Beetle bogs down and splatters only on drive |
First check the wires from plugs to distributor, if fitted in the correct order.
If that is ok, then try replacing the spark plugs |
Tom K. Samba Member
Joined: March 10, 2005 Posts: 1606 Location: Central Pennsylvania
