Intermittent ABS "buzz" under normal braking 2003 EV MV
Forum Index -> Eurovan Share: Facebook Twitter
dbeeby
dbeeby is offline
PostPosted: Wed Apr 17, 2024 9:29 am    Post subject: Intermittent ABS "buzz" under normal braking 2003 EV MV Reply with quote
Hello folks,
My 2003 Eurovan is occasionally activating ABS under normal braking. There's just a very brief (less than a second) "buzz" coming from the pedal and behind the firewall. No dash lights (ESP/TC) illuminate when the buzzing happens.
I've done a bit of research and most forums point to dirty/failed ABS wheel sensors or ABS control unit. I have not scanned it, but I will when I get my VCDS back. There are no dashboard lights at all.
Thoughts?
Thanks,
Dan
[email protected]
samscholz96@gmail.com is offline
PostPosted: Wed Apr 17, 2024 5:05 pm    Post subject: Re: Intermittent ABS "buzz" under normal braking 2003 EV MV Reply with quote
my 2001 eurovan does this.
I have a new axle,the old axle outer boot tore open and gooped the wheel well and I assume my wheel sensor and sprockets.
I have also replaced the tone ring on the old axle before as the old one was cracked, very much buzzing before the fix.
Someone on here ordered new ones from England to update theirs, they crack.
My axle had 208k on it
2001 eurovn weekender 207k fresh batteries
dbeeby
dbeeby is offline
PostPosted: Thu Apr 18, 2024 8:54 am    Post subject: Re: Intermittent ABS "buzz" under normal braking 2003 EV MV Reply with quote
Thank you [email protected]!
This thread you posted is super helpful.
https://www.thesamba.com/vw/forum/viewtopic.php?t=752280&postorder=asc
Looks like this CV shaft kit (or two) will do the trick, but I'll check with my mechanic:
https://www.fcpeuro.com/products/volkswagen-drive-shaft-cv-joint-kit-701498099c
Reply to topic    Forum Index -> Eurovan All times are Mountain Standard Time/Pacific Daylight Savings Time
