Olli.D Samba Member
Posted: Sun Apr 14, 2024 1:28 am Post subject: Old body transport with newer rolling frame |
I like to pick up a 65' Karmann Gia Coupe Type 14 body without floor plate.
It is a 4 hour trip and we go with a car trailer.
We have a rolling frame, but that was made for a 69' Ghia convertible.
We would like to put the 65' Coupe on the massive built rolling frame.
There is a difference between the bodys with the srew points.
As wee see, the 65' screw points (2) in the back wheel arch are a bit deeper.
Only a bit deeper, but same alignment?
- Do you know, how mouch it is? Something around 2cm i guess...
- Are the front screw points idetical?
What about just add 2 distance pieces to the front screw points, same dimension as the difference in the back.
Would be nice, to get the body direct on the rolling frame. Better than transport it on wooden beams.
Thank you for information,
Olli |
Braukuche Samba Member
Posted: Sun Apr 14, 2024 9:20 am Post subject: Re: Old body transport with newer rolling frame |
Olli.D wrote: |
Olli |
The only difference is the shock tower. You can cut out the one on the body and move it. I think it shifts down? In any case it won’t prevent you from putting the body on the pan to move the vehicle. You can deal with it later. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Rome Samba Member
Joined: June 02, 2004 Posts: 9687 Location: Pearl River, NY
Posted: Wed Apr 17, 2024 8:30 pm Post subject: Re: Old body transport with newer rolling frame |
Hi, Olli. I understand your plan, and it'll work. The rear body mount can be cut a few cm up from the bottom bolt surface so that the body can fit along the chassis. Like this (JackVW1959) although this mount was cut quite high.
Then you can bolt the body onto the chassis along the chassis edge bolts, skipping every 2nd or even every 3rd bolt.
Instead of cutting the rear body mount, you can install an M10 x 1.5mm bolt into the mount so that it fastens to the chassis- they do align. Then place a ca. 2 cm thick wood board along the front of the chassis edge, in the transverse section that goes under the "Napolean's hat", or along the "dogleg" on the outer edges. Drill the wood for a few bolt holes and use longer M8 x 1.0 mm bolts to reach through from underneath, through the holes in the wood, and into the body. Again, only a few holes along the chassis will be needed to snug the body down.
Where in Germany are you located? |
Olli.D Samba Member
Posted: Thu Apr 18, 2024 8:30 pm Post subject: Re: Old body transport with newer rolling frame |
Braukuche and Rome, great!
Thank you for your input!
My description "rolling frame" was ab bit misunderstanding.
What we made for the convertible was that rolling frame:
But with your descriptions i understand, that will work.
With the older housing it will stay a little higher in the back, may be 2cm.
Before srewing in the front, i will add some distance pieces, just for the angles of the srewed parts.
And today we will pick up the Coupe. It is a housing from dry Arizona. Just prepairing the food for the trip
@Rome We live in the area of -Wuppertal- |
halbug Samba Member
Posted: Thu Apr 18, 2024 9:55 pm Post subject: Re: Old body transport with newer rolling frame |
Hi Olli, great, another KG with KTL treatment
How was your experience with CarBlast? I will have mine dipped and KTL treated as well, just do not know where. I had my steel rims done at CarBlast and was quite happy, but they told me that they send every car body throught their pyrolysis oven and that may melt the solder on our Ghias. This scared me away from them.
Please keep posting pictures from your restauration.
Cheers halbug _________________ Stealth Ghia Transformation: http://www.thesamba.com/vw/forum/viewtopic.php?p=7226044&highlight=#7226044
My Berg5: https://www.thesamba.com/vw/forum/viewtopic.php?t=730276&start=0
Rome Samba Member
Posted: Fri Apr 19, 2024 3:43 am Post subject: Re: Old body transport with newer rolling frame |
Olli, the reason I asked about your location in Germany is that I lived in Wolfsburg for 3 years (working for VW) and also have been to Munich many times on business since the late 1980's. But in my WOB time I never drove to Wuppertal.
Wishing you success for your Ghia move. |
Olli.D Samba Member
Posted: Fri Apr 19, 2024 10:16 pm Post subject: Re: Old body transport with newer rolling frame |
The 65' Ghia is at home and part of a new project, starting next autumm.
It fitted perfectly on the rolling frame.
And the quite good 58 Years old housing from Arizona:
Any kind of accident was the reason to put a new or another roof on it. May be fallen tree, or bridge to deep??
May be, you know this car?
Don't beet me up, but this car will be converted to 6-cylinder convertible.
I got the only convertible Ghia what has a legalized Porsche 6 cylinder in Germany. That has been done in late 70s. There is one other legal Ghia, but Coupe, with 6 cylinder here. Look for Bader Racing.
This 6-cylinder Ghia Convertible has a special history, so it has to get build up again.
I stripped it complete, paint remove, derust, KTL. After that, you see the truth. It was covered in underbody protection in and outside with 3-7 layers of paint and lost of spatula. It was not really clear, what comes out.
The convertible housing is a kind of dead, bad welded everywhere. I loved to get a dry desert housing (like my 914, got it 1990).
I had a look to some convertibles in Germany, but nothing worthwhile found.
I have to overwork the complete chassis and body with stiffening parts anyway. Swap the window frame and roof holder in the back in addition.
No problem, that the convertible sills have reinforcements inside.
May be, the sills from the Coupe will stay, because not welded and stock. Will have a closer look.
Pics of the Ghia Convertible:
@ halbug: i knew nothing about pyrolysis oven before. What i "bougth" was a chemical paint remove bathing, after that the derost bath and KTL and some intermediate steps.
Thanks for information, i will ask there next car if they do it with every car before chemical paint remove.
But on the other hand, i know some cars, what went through the process, no problems there. Classical race cars included. And some known companys let do the complete process there on their oldtimers. So i'am not worried. |
