NerdyGunny Samba Member
Joined: August 10, 2005 Posts: 381 Location: Tucson, AZ
Posted: Thu Apr 11, 2024 9:21 pm Post subject: Found some Weber 40 IDF from a different set up |
Will these work for a VW? It looks like if I was to pull these carbs off of what they’re mounted to then they might work.
Sidenote, what’s a good price for these?
Slow-N-Rusty Samba Member
Posted: Thu Apr 11, 2024 11:07 pm Post subject: Re: Found some Weber 40 IDF from a different set up |
Those are Weber DCOE carbs. They're side draft and with the right manifold will work on inline watercooled VWs, but for a flat 4 aircooled engine you'll need IDFs which are down draft. (though they are used in some turbocharged setups as a single sidedraft carb)
Those seem to range in price between a couple hundred to several hundred for the pair depending on condition. |
Posted: Fri Apr 12, 2024 6:30 am Post subject: Re: Found some Weber 40 IDF from a different set up |
Slow-N-Rusty wrote: |
THANK YOU! I will definitely pass on them. |
