Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10383 Location: Sunshine Coast B.C.
Posted: Fri Apr 05, 2024 11:44 am Post subject: Buy Online: 1.8 RV Exhaust Manifold Questions |
Hi folks.
As a used part, caveat emptor but....
During normal use, is the 1.8 8V exhaust typically prone to:
- cracking (at flanges or ?)
- damaged O2 threads
My Vanagon ABA engine conversion uses that manifold. Before install, O2 threads were unusable. But after ~ 60K kms on the conversion, no audible signs of cracking.
Never purchased something like this online. Vendor: https://canadacatalyst.ca
I see a negative review for them here:
https://www.thesamba.com/vw/forum/viewtopic.php?t=713158&highlight=https+canadacatalyst.ca
but I take reviews with a grain of salt. Regardless, feed back on them is welcome.
Thanks,
1988 West DIY 50º ABA
VE7TBN |
Joined: August 31, 2013 Posts: 12870 Location: North Carolina
Posted: Fri Apr 05, 2024 12:57 pm Post subject: Re: Buy Online: 1.8 RV Exhaust Manifold Questions |
Having worked on thousands of 85-92 VWs, I have never seen those manifolds crack, or have stripped threads. However, I was working on them regularly when they were 8-20 years old. They are quite scarce now & sure to have been put through a lot worse since then. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Sat Apr 06, 2024 8:51 pm Post subject: Re: Buy Online: 1.8 RV Exhaust Manifold Questions |
Ok cool. Thanks for that insight TDCTDI.
Even only several years ago I was still seeing Mk2 Mk3 parts on Vancouver BC craigslist. Not seeing much if any of that these days.
Times have changed!
VE7TBN |
timvw7476 Samba Member
Posted: Sun Apr 07, 2024 9:51 pm Post subject: Re: Buy Online: 1.8 RV Exhaust Manifold Questions |
the lower (cat side) flange may let go after 1/2 million miles +.(my experience)
But the actual cast iron top side? It's like the one-way clutch drum in those 010 auto trans of the same years. Everything else may get vaporized but the manifold will still be ready to bolt on another 8 valve...till about 2444AD. |
