DLarsen Samba Member
Joined: February 05, 2021 Posts: 15 Location: Stanbridge Station, Quebec
Posted: Thu Apr 04, 2024 5:34 am Post subject: 1944 Kubelwagen wiring diagram |
I'm starting the process of sorting out the electrical system on my newly acquired 1944 Kubelwagen. I cannot find a clear useable schematic anywhere. I need to figure out, among other things, what each position of the light knob activates on the notek lights and headlights. Does anyone have a clear PDF they could share?
Thanks!
_________________ 1944 Kubelwagen, Restored
1953 Black Zwitter, Restored
1956 Polar Silver Oval, Restored
1956 Panel, currently being restored
1958 Beetle survivor, patina road-warrior
1961 Microbus, companion of 30-years
Follow me on Instagram @larsenvintagevw |
finster Samba Member
Joined: May 26, 2012 Posts: 8071 Location: north o' the border
Posted: Thu Apr 04, 2024 7:16 am Post subject: Re: 1944 Kubelwagen wiring diagram |
according to the notek handbook the switch has 5 positions
O - front blackout lamp and rear convoy lamp off
H - (hinten?) front blackout lamp off, only rear convoy lamp on
V1 - front blackout lamp on dimmest setting, rear convoy lamp on
V2 - front blackout lamp on middle brightness, rear convoy lamp on
V3 - front blackout lamp on brightest setting, rear convoy lamp on
pdf of booklet can be found here https://www.olgiati-in-paraguay.org/kubel/Notek.pdf
includes generic wiring diagram
the best wiring diagram I can find for a late kubel with multi-position ignition switch is this
_________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
Posted: Thu Apr 04, 2024 9:41 am Post subject: Re: 1944 Kubelwagen wiring diagram |
Thanks Finster, that will be soooooo helpful!
North o' the border, eh! _________________ 1944 Kubelwagen, Restored
Martin Southwell Samba Member
Joined: November 24, 2010 Posts: 1002 Location: Bath, England
Posted: Fri Apr 05, 2024 7:21 am Post subject: Re: 1944 Kubelwagen wiring diagram |
What's the history of this Kubel, and how did it end up in Canada? |
Posted: Fri Apr 05, 2024 4:48 pm Post subject: Re: 1944 Kubelwagen wiring diagram |
It was brought back to Canada after the war by the Canadian army as war booty. It was sent to the Valcartier, Quebec base where it stayed until being sold at a surplus auction in the 60's. I recently bought it from the collector who completed the restoration, only leaving me a few tidbits to take care of. It has not been out of Quebec since the 40's.
This is perhaps the first Volkswagen to be on canadian soil!! _________________ 1944 Kubelwagen, Restored
T2_681 Samba Member
Joined: October 08, 2018 Posts: 69 Location: Czech republic
Posted: Fri Apr 05, 2024 10:48 pm Post subject: Re: 1944 Kubelwagen wiring diagram |
DLarsen wrote: |
It was brought back to Canada after the war... |
Brought BACK to Canada? |
hopkin Samba Member
Joined: June 25, 2012 Posts: 2485 Location: Ottawa, Ontario
Posted: Sat Apr 06, 2024 2:21 am Post subject: Re: 1944 Kubelwagen wiring diagram |
DLarsen wrote: |
It was brought back to Canada after the war by the Canadian army as war booty... |
Looks great, you should bring it the VW in Joliette, held every Sept. _________________ 1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
1991 Honda Civic (Original Owner)
1996 'Open Air' Mexican Beetle (current)
2015 Golf (current)
2017 Dune Edition (daughter's car) |
Posted: Sat Apr 06, 2024 8:23 am Post subject: Re: 1944 Kubelwagen wiring diagram |
T2_681 wrote: |
DLarsen wrote: |
'...by the canadian army as war booty.'
the full sentence gives this context so that it is quite clear that the 'back' refers to the action of the canadian army and not that the kubel had previously been in canada. _________________ "we're here on Earth to fart around" kurt vonnegut
T2_681 Samba Member
Posted: Sat Apr 06, 2024 10:27 am Post subject: Re: 1944 Kubelwagen wiring diagram |
Really? Always something new! |
Posted: Sat Apr 13, 2024 2:28 pm Post subject: Re: 1944 Kubelwagen wiring diagram |
The good news is that I have most of the wiring sorted out and almost everything works, except the brake light. There is no brake light switch to be found. Where was it mounted, in the front of the tunnel behind the brake cable adjustment cover? I don't see any mounting holes for a switch anywhere. Does anyone have pictures of their kubel brake switch setup? I see that a Porsche 911-914 switch can be used if an original cannot be found. I might go that route in the meantime, but would love to see how the original was mounted. Thanks! _________________ 1944 Kubelwagen, Restored
T2_681 Samba Member
Posted: Sat Apr 13, 2024 11:26 pm Post subject: Re: 1944 Kubelwagen wiring diagram |
This is, of course, the early type of switch on a 1943 Kübel. The 1944 design was pretty much different.
Posted: Sun Apr 14, 2024 10:40 am Post subject: Re: 1944 Kubelwagen wiring diagram |
pretty sure I've read somewhere that the brake light was not fitted in later (1944 -) years. looking at parts lists, the brake switch is shown early on but disappears from later editions which seems to support this...
and not on later wiring diagram (bulb missing from rear notek too)
the porsche 911 switch looks just like the vw cable brake part but with spade connectors!
standard beetle set-up
T2_681 Samba Member
Posted: Sun Apr 14, 2024 10:54 am Post subject: Re: 1944 Kubelwagen wiring diagram |
The brake light circuit was absent as early as in June 1943 manual. |
Posted: Sun Apr 14, 2024 4:45 pm Post subject: Re: 1944 Kubelwagen wiring diagram |
Thanks guys, this is very helpful. My wiring is exactly like the first schematic shared by Finster, which shows a brake light and switch. I have a fuse for the brake light, just like the schematic. I will need the brake light to get the car safetied. I think the simplest and most discreet way is to go with the 911 switch, even if it's not correct. At least nobody will be able to see it.
I have an original Marz (march) 1943 parts manual which does not show the brake switch, but the brake light circuit is still seen in the schematic. _________________ 1944 Kubelwagen, Restored
Fly-wheel Samba Member
Joined: February 25, 2018 Posts: 5 Location: United Kingdom
Posted: Sun Apr 21, 2024 7:12 am Post subject: Re: 1944 Kubelwagen wiring diagram |
[quote="finster"]according to the notek handbook the switch has 5 positions
[/quoteis
Thanks for sharing this. it okay to try to copy the colour diagram so i can print a copy. I dont know who owns the copyright or if there is a high grade copy as cant see it on the website. |
mikeandkirsti Samba Member
Posted: Mon Apr 22, 2024 2:28 am Post subject: Re: 1944 Kubelwagen wiring diagram |
finster wrote: |
A brake light was not fitted in my very original 30.11.1943 built Kübelwagen. The holes for the switch were NOT drilled. They are still that way (there was a simple Model A Ford pull switch behind the pedal installed after the war to comply with Finnish road safety, never changed it). Also no dimmer switch ever and no high beam but it has the newer dash so a later ignition switch was fitted with 3 positions including a high beam. |
