RicMcK Samba Member
Posted: Thu Mar 28, 2024 7:07 am Post subject: Radiator fan replacement? |
My 89 Westfailia has about 260k miles on it (I don't know the age of the radiator), thus I'm thinking it's a good idea to replace it & the baffles. The rest of coolant system has been R&R'ed. The fan sounds OK, but as we all know it's NOISY. I'm thinking about replacing it with on the these.
https://www.summitracing.com/parts/FLX-119#overview
What does the community think about this?
Thanks _________________ Rick McK
Seattle
New to me 89 Westfalia
2006 TDI Jetta
1936 Ford Pick up |
SCM Samba Member
Joined: January 26, 2011 Posts: 3119 Location: Bozeman MT
Posted: Thu Mar 28, 2024 7:53 am Post subject: Re: Radiator fan replacement? |
I only notice my fan being noisy if the second (high) speed kicks in, which is almost never. Could be that your radiator is clogged causing that high speed to turn on more than it should. But I understand wanting to deal with it while the you’re in there.
Sorry, I have no experience with the Summit fan. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9811 Location: Mt Lemmon, AZ
Posted: Thu Mar 28, 2024 8:11 am Post subject: Re: Radiator fan replacement? |
Do you know the CFM of the stock fan (I don't)?
The late fan you have is a pretty good unit IMO, I put one on my 84, replacing the earlier style fan when I reworked the AC. Yes, it's noisy, especially on high speed. |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6368 Location: Honolulu,Hawaii and France
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4353 Location: United States, Iowa
Posted: Thu Mar 28, 2024 12:26 pm Post subject: Re: Radiator fan replacement? |
RicMcK wrote: |
Careful now. New radiators (at least in my experience) seem to be less able to cool, are thinner, etc. than the originals. Be sure to check around to find out who has equivalent units, good name brands, etc. I sure wish I had known more back when I ordered one just to have on hand (figured I'd need one some day, saw a new one for a good price, and had it sitting in my garage 3 years before I developed a leak on one side of my radiator 'tanks').
As for the fan, I've also looked at the fan described above, and sure wish I had seen that info prior to the radiator job, since mine is loud and getting louder, AND I'll still have to drop my radiator and A/C condenser AGAIN to do either or both of the radiator and fan jobs.
My major complaint with the new radiator I found is that the heat builds up something like twice as fast now when I am going slow, like in traffic jams, or being the second vehicle in line at a drive through coffee place, etc.
In addition to a change out of the radiator and fan, I suggest looking into sending your high speed fan relay an extra + wire from a switch on your dash, so when you know you are getting hot, you can turn it on by hand. My PO spent a lot of time in mountains and had one rigged up when I took possession of the rig in 2015.
-bobby _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
RicMcK Samba Member
Posted: Thu Mar 28, 2024 12:35 pm Post subject: Re: Radiator fan replacement? |
To clearify. The current fan operates properly (tested both speeds & new sendor & resistor) and sounds fine (just its typical noisy self). It cycles on low speed just like it should. No current over heating issues, now or before the rebuild so I'm confident the radiator is not compromised. I'm in Seattle so there's little chance of getting to high speed while driving until summer comes.
Revised question is:
What's the typical service life of the radiator, and fan? Is it a good assumption that at 220k (mi) the rad and or fan should be replaced? I've replaced everything else WRT the cooling & fuel systems, with the new 2.2 WBX engine build. _________________ Rick McK
Seattle
2006 TDI Jetta
1936 Ford Pick up |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17162 Location: Retired South Florida
Posted: Thu Mar 28, 2024 2:40 pm Post subject: Re: Radiator fan replacement? |
Unless you are running AC, most conditions the fan rarely runs. It runs on high even less. But it’s hard to predict when it might seize.
As far as the universal fans, I’d only use one when an original was wasn’t available. _________________ ☮️ |
markswagen Samba Member
Joined: January 28, 2018 Posts: 1040 Location: san diego
Posted: Thu Mar 28, 2024 3:00 pm Post subject: Re: Radiator fan replacement? |
l see it as one of those, if it ain't broke, don't fix it, moments.
if it bothers you that much buy the stock replacement parts, and put them away until they are needed.
in 10 years of working in san diego, l've yet to need to replace a dead radiator fan, radiators yes, fans no. _________________ markswagen {mobile mechanic} san diego area all early VW's cared for.
619 201 0310 |
RicMcK Samba Member
Posted: Thu Mar 28, 2024 3:38 pm Post subject: Re: Radiator fan replacement? |
Mark & Mark thanks for the advice. I like if it ain't broke don't fix it right now as I've done too much fixing lately 🙂 _________________ Rick McK
Seattle
2006 TDI Jetta
1936 Ford Pick up |
