Later trans WITHOUT bus nose cone?
GMendoza
GMendoza is offline
PostPosted: Tue Mar 26, 2024 4:08 pm    Post subject: Later trans WITHOUT bus nose cone? Reply with quote
Has anyone installed a later trans in an early oval by welding in a new front mount rather than using a bus nose cone?
If so, any other issues to be aware of?
Bruce
Bruce is offline
PostPosted: Wed Mar 27, 2024 1:40 am    Post subject: Re: Later trans WITHOUT bus nose cone? Reply with quote
It will cause the front of the trans to be too low by 40mm (or maybe it's 60mm??). This will cause your muffler to be too high.
Don't create problems, use the Bus nose cone.
the dominator
the dominator is offline
PostPosted: Wed Mar 27, 2024 2:38 am    Post subject: Re: Later trans WITHOUT bus nose cone? Reply with quote
same opinion overhere, I would leave the chassis original and mount the bus nosecone.
I have recently mounted the bus nosecone, then it is plug and play
54 iceland green oval, done!
52 Zwitter standard ragtop, parts hunting
67 T2A candywaxred en chestnutbrown
1988 T3 doka synco 2.1WBX
splitjunkie
splitjunkie is offline
PostPosted: Wed Mar 27, 2024 3:48 am    Post subject: Re: Later trans WITHOUT bus nose cone? Reply with quote
He is talking about welding in the front mounting plate to the front torsion tube so this won't be a true statement.
https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111701173c
However, the original front mounting plate is actually cast into the center part of the torsion tube and will be difficult to remove. It will require a lot of cutting and grinding. Just get a bus nosecone and be done with it.
Chris
esde
esde is offline
PostPosted: Wed Mar 27, 2024 5:36 am    Post subject: Re: Later trans WITHOUT bus nose cone? Reply with quote
I haven't had a bus and beetle noise cone side by side for a while, but I recall it's not just the mount that is different, it's the shift rod height too. So raising the mount won't do any good, as now the shift rod would be above the tunnel and the nosecone will likely be hitting the floor.
modok wrote:
jitbba
jitbba is offline
PostPosted: Wed Mar 27, 2024 7:28 am    Post subject: Re: Later trans WITHOUT bus nose cone? Reply with quote
I welded in that exact front mount for mine and used the regular nose cone for my transmission. No problems and pretty straight forward
My other ride is a Zildjian
splitjunkie
PostPosted: Wed Mar 27, 2024 7:47 am    Post subject: Re: Later trans WITHOUT bus nose cone? Reply with quote
Yes, the orientation of the mount holes and the shift rod are different between the two.
Use the stock mount plate on the torsion tube and you have to use the bus nose cone. Everything will line up.
Weld in the late style front mount plate on the torsion tube and you can use the standard sedan nose cone. Everything will line up.
He is suggesting the second option.
Chris
GMendoza
GMendoza is offline
PostPosted: Thu Mar 28, 2024 9:09 am    Post subject: Re: Later trans WITHOUT bus nose cone? Reply with quote
Thanks guys for all the info, very useful!
Bruce
Bruce is offline
PostPosted: Sun Mar 31, 2024 2:38 am    Post subject: Re: Later trans WITHOUT bus nose cone? Reply with quote
If you weld on that bracket and use a late Beetle nose cone, the hockey stick will be centered in the hole going into the tunnel. This will cause the next casting on the trans (gear carrier) to be lower than if you use a Bus nose cone and the original mount. In other words, the front of the trans is tilted down. Causing the tail pipes to ride higher, possibly hitting the rear apron.
The nose cone and hockey stick will line up, but it pulls the rest of the front of the trans down.
jitbba
jitbba is offline
PostPosted: Mon Apr 01, 2024 7:44 am    Post subject: Re: Later trans WITHOUT bus nose cone? Reply with quote
maybe I was lucky, but this was not the case when I did mine. Welded in that front transmission mount, used the mid-60s transmission, and everything lined up perfect. No issues with the tailpipes, how the engine sits, engine seals, etc.
My only complaint is the new transmission makes the stock 36hp engine slower but I'll use the motor until it gives up the ghost, then opt for something more powerful
Ian M
Ian M is offline
PostPosted: Tue Apr 02, 2024 7:40 am    Post subject: Re: Later trans WITHOUT bus nose cone? Reply with quote
Bus nosecone is the way to go. Bolt in easy.
The hockey stick is lower on a bus nosecone,that's why they are also used with '60s cars that have raised transmission mounts-to keep the shift rod in the tunnel.
My oval had a later tunnel case mount like welded in decades ago,like mentioned here previously it resulted in the nosecone being too low and the rear of the engine being too high. Probably worked ok as a beater with the 40hp that was in it,but...
In my case, I welded in a solid mid mount (cal look car,not concerned with noise) and ran a bus nose cone to keep the shift rod in the stock location,simply eliminating the nose cone mount altogether.
56Cabrio
56Cabrio is offline
PostPosted: Tue Apr 02, 2024 9:43 am    Post subject: Re: Later trans WITHOUT bus nose cone? Reply with quote
This is the route I took, super easy..
Fits 60 and earlier Beetle and 67 and earlier bus. Perfect for installing full syncro box into 60 and earlier Beetle.
https://ranchotransaxles.com/product/type-2-nose-cone/
F#CK CANCER
Make a donation
1956 Rag Top owned since 1988
1963 Hard Top
RIP Dad 4/20/1951 - 2/4/2023
splitjunkie
PostPosted: Wed Apr 03, 2024 5:38 am    Post subject: Re: Later trans WITHOUT bus nose cone? Reply with quote
That's your standard bus nosecone which is what the OP was asking if he could avoid using. Wolfsburg West as well as others sell them. Definitely the best way to go, although a '60 presents a problem because of the one year only front mount. Best option for a '60 is to remove the front mount and weld in the later front mount plate and use a standard sedan nose cone.
Chris
jitbba
jitbba is offline
PostPosted: Wed Apr 03, 2024 7:30 am    Post subject: Re: Later trans WITHOUT bus nose cone? Reply with quote
The reason I went with welding in a new mount was to avoid mutt parts. In my mind, it made it too complicated to have to keep track of which years/models were with what parts if I ever had to service anything.
Chip26
Chip26 is offline
PostPosted: Wed Apr 03, 2024 10:01 pm    Post subject: Re: Later trans WITHOUT bus nose cone? Reply with quote
Consider using a bus nose cone or welding in a new mount while considering shift rod height and transmission compatibility, and consulting with experts for a safe and reliable installation of a later transmission in an early oval VW.
splitjunkie
PostPosted: Thu Apr 04, 2024 4:05 pm    Post subject: Re: Later trans WITHOUT bus nose cone? Reply with quote
It's really not that hard.
You have a '59 and earlier, not including splits with the doughnut mount, and you don't want to modify the pan, you use a bus nosecone.
You don't mind modifying the pan, cut off the old mount plate as necessary and weld in a late model front mount plate and use a standard sedan nosecone.
Easy Peasy. I don't know why people over complicate it.
Chris
