nextgen Samba Member
Joined: August 19, 2004 Posts: 6035 Location: CONGERS, N.Y.
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76966 Location: Sneaking up behind you
94touring Samba Member
Joined: October 24, 2020 Posts: 313 Location: Oklahoma - OK
Posted: Tue Mar 26, 2024 9:49 am Post subject: Re: what is a replacement for a B5ES SPARK PLUG |
Do I dare post a link to Amazon...
On NGK/sparkplugs.com those 5s only come with resistors. The 6s you asked about come as you want, just in a wider gap. But we've been over this. |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3450 Location: San Diego
Posted: Tue Mar 26, 2024 10:14 am Post subject: Re: what is a replacement for a B5ES SPARK PLUG |
The 5 or 6 is the heat range. The R in the designation means resistor. Alot of businesses will give you resistor plugs as they have been told they are suitable replacements |
Stripped66 Samba Member
Joined: May 31, 2005 Posts: 3470 Location: Charleston, SC
The "R" refers to having a resistor: B5ES has no resistor, BR5ES has a resistor. The number refers to the inverse of heat range: BR5ES is a hotter plug than a BR6ES. _________________
66brm wrote: |
Bodacious wrote: |
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor. |
I don't think electrickery works that way |
Posted: Tue Mar 26, 2024 10:16 am Post subject: Re: what is a replacement for a B5ES SPARK PLUG |
The link to the chart I posted breaks down what the letters and numbers signify on a spark plug for NGKs. You get to pick your poison accordingly. 5s or 6s or go even colder! Resistor or no resistor and so on. Then you just need to decide where you can and want to buy them. |
74 Thing Samba Member
Posted: Tue Mar 26, 2024 10:30 am Post subject: Re: what is a replacement for a B5ES SPARK PLUG |
94touring wrote: |
You can lead a horse to water... |
Posted: Tue Mar 26, 2024 2:04 pm Post subject: Re: what is a replacement for a B5ES SPARK PLUG |
. I was able to get 4 Old Stock B5ES, from Advanced Auto.
For years I have been running the 5, but recently guys said I should be running the 6... So as for as leading the horse to water, Screw it, I am sticking with the 5. Rather not have the resistor , I don't have a radio in my bug. Another example is were the radio was I put my switches upside. Ha they were not made to read NO NO NO NO etc and I got used to it, ha.
_________________ email: [email protected]
The TYPE IV UPRIGHT CONVERSION MANUAL
BEETLE MAGNETIC DEFLECTOR SHIELDS
LETS TALK DUBS https://www.youtube.com/results?search_query=joe+cali+ghia https://letstalkdubs.libsyn.com/ep-200-joe-cali-ty...qI3xJTCzjs |
Posted: Tue Mar 26, 2024 2:13 pm Post subject: Re: what is a replacement for a B5ES SPARK PLUG |
I run heat range 7 non resistor. But I have a pretty lively 2180. Nothing wrong with the 5s depending what you're putting them in. |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6627 Location: Houston, Texas
