Thelovelylimey Samba Member
Posted: Mon Mar 25, 2024 11:54 am Post subject: 67 beetle fuel pump |
Hi guys,
The fuel pump on my 67 was leaking, so I am trying to replace it. The problem is that the bolt holding on the carb is in the way, and having tried two different pumps am now asking the hive.
My question is, how in the hell do I remove this headless bolt if I want to replace the carb, or you know, change the fuel pump?
Here's is the clearance
Any input would be greatly appreciated! |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34023 Location: Conejo Valley, CA
Posted: Mon Mar 25, 2024 12:21 pm Post subject: Re: 67 beetle fuel pump |
That stud should be screwed further up into the carb flange.
It looks like removing the nut spun the stud loose.
Remove the carb, and use some loktite on the upper threads of that stud, and screw it far enough that the protrusion below the manifold flange is just enough to fully engage the nut threads, no more. _________________ Current Fleet:
'71 Fastback
'69 Westfalia
Retired:
'67 Beetle
'65 Beetle (x2)
'65 Bus
'71 Squareback |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Mon Mar 25, 2024 12:28 pm Post subject: Re: 67 beetle fuel pump |
you'd be better off switching to an angled / alternator style pump (since you have an alternator), but also know that the angled pump uses a shorter pushrod, so you need to change that too.
Thanks KTPhil, I appreciate it. Got it
Edit, thanks hazetguy too. I'll look at the alternator style of pump too, but I'm going to install this one for now |
PWB Samba Member
Posted: Wed Mar 27, 2024 12:15 pm Post subject: Re: 67 beetle fuel pump |
Just be sure to check the fuel pressure with a gauge after the new pump in installed and running. Many new or aftermarket pumps produce many times the max rated pressure of the carb's needle and seat out of the box.
Should not exceed ~2.5 psi. If it does, the fuel pump push rod must be ground down, and the pressure rechecked.
edit:
Also, may want to ditch the 009 distributor for a proper vacuum advance style. just a suggestion. |
indianpeaksjoe Samba Member
Posted: Wed Mar 27, 2024 12:28 pm Post subject: Re: 67 beetle fuel pump |
I highly recommend getting a pump from https://www.sparxwerks.com/ . I replaced mine with one from him that brand new.
You may be able to spin that stud back up with a pair of angled pliers.
Cheers,
-Joe _________________ Adventures in owning a 66 beetle |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6627 Location: Houston, Texas
Posted: Thu Mar 28, 2024 4:25 pm Post subject: Re: 67 beetle fuel pump |
Grab one of the Brosol alternator units just like you have. I think I have one on the shelf that I can't use if you want it.
This is the one you want: https://www2.cip1.com/vwc-113-127-025-gbr/
If you need a new rod let me know. I have stacks of used ones. _________________ www.vwnos.com [email protected]
Cusser Samba Member
Joined: October 02, 2006 Posts: 31392 Location: Hot Arizona
Posted: Thu Mar 28, 2024 5:29 pm Post subject: Re: 67 beetle fuel pump |
I don't understand - why not just remove the front (front is front) nut mounting the carburetor and lift it straight up.
Better yet: fix that rear stud while you have the carburetor off !!! Not much more to completely remove the carburetor to fix right. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
wcfvw69 Samba Purist
Posted: Thu Mar 28, 2024 7:57 pm Post subject: Re: 67 beetle fuel pump |
Absolutely check the fuel pressure on that aftermarket fuel pump. I have many customers who bought one of those inexpensive fuel pumps report back over 5 PSI which causes lots of issues with the carb. The German dome tops and square tops put out 3 psi which is what VW called for.
BTW, a generator upright fuel pump bolts right onto an engine with an alternator as long as the fuel pump studs are the correct factory height and the studs holding the carb to the manifold are the correct length. _________________ Contact me at [email protected]
The Samba member since 2004.
