HuffinesC Samba Member
Joined: October 19, 2021 Posts: 13 Location: Nashville, TN
Posted: Sun Mar 24, 2024 5:38 am Post subject: Carb Help |
So I have a 1915 running with empi dual 34pct stock carbs. To make this run better what size jetting should I change ? I’m not a carb person so most of this knowledge is unknown to me. Any ideas would be helpful.
1.75 Needle and Seat
- .150 Main Jet
- 0.55 Idle Jet
- .175 Air Correction Jet
This is current since it’s stock. I just want to cruise with this motor in my 69 Transporter. I live in Nashville TN if elevation matters. Thank you for any help. |
oprn Samba Member
Joined: November 13, 2016 Posts: 12755 Location: Western Canada
Posted: Sun Mar 24, 2024 5:45 pm Post subject: Re: Carb Help |
Two questions:
1) What is wrong with how it is running now that makes you think needs improvement?
2) What is your present tune? C/R, cam, heads, timing - initial final and RPMs, air fuel ratio at idle - light cruise and full throttle? _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Posted: Sun Mar 24, 2024 6:11 pm Post subject: Re: Carb Help |
While I am driving it bogs down and stays with pedal to the ground at 30 miles an hour. It’s like it doesn’t have the”go” I would expect. No black smoke. I am unaware of the build of this motor as I didn’t build it a gentleman from Rome Georgia is all I know. Please keep in mind I am learning how to work on these since I decided to own one. I have built a 1641. |
oprn Samba Member
Posted: Mon Mar 25, 2024 6:34 am Post subject: Re: Carb Help |
It could be a number of things besides the carbs:
Bad fuel pump
Plugged fuel filter
Intake manifold leaks
Ignition timing wrong
Bad coil
Fouled plugs
Bad plug wires
Cracked distributor cap
Worn ignition points
Bad condenser
Valve lash set too tight
And I am probably missing a few... _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6623 Location: Houston, Texas
Posted: Mon Mar 25, 2024 7:12 am Post subject: Re: Carb Help |
oprn wrote: |
Bad fuel pump
Plugged fuel filter
Bad coil
Fouled plugs
Bad plug wires
Bad condenser
And I am probably missing a few... |
I'd start by checking the timing and the point gap first. _________________ www.vwnos.com [email protected]
Posted: Tue Mar 26, 2024 7:38 pm Post subject: Re: Carb Help |
Timing got set using timing light. New wires, plugs, distributor with pertronix electronic ignition, coil, fuel filter is new,new gasket for manifold torqued to spec. Fuel pump isn’t new. |
