Question about connection inner rocker / pillar
Ring-Free
Ring-Free is offline
PostPosted: Sat Mar 23, 2024 2:52 pm    Post subject: Question about connection inner rocker / pillar Reply with quote
Since I have been asked and am also unsure myself, here is a question for everyone
Are the vertical pillars and supports connected to the inner rocker (welded) or is the connection to the floor panel sufficient? Shorter and not welded would be better because of water?
Depending on the supplier, they are sometimes longer or shorter
Does anyone have a photo of the original?
Thanx
my current challenge
https://www.thesamba.com/vw/forum/viewtopic.php?t=779910
Ring-Free
PostPosted: Thu Mar 28, 2024 11:37 am    Post subject: Re: Question about connection inner rocker / pillar Reply with quote
No one has any information on this. I would be really interested to know if they were welded at the bottom
DSweinhagen
DSweinhagen is offline
PostPosted: Thu Mar 28, 2024 2:47 pm    Post subject: Re: Question about connection inner rocker / pillar Reply with quote
No, the upright supports and inner rocker are not connected. The outer panel and floor will tie them together, but they are not directly connected.
Looks good!
David S
Huetti_1989
Huetti_1989 is offline
PostPosted: Thu Mar 28, 2024 3:45 pm    Post subject: Re: Question about connection inner rocker / pillar Reply with quote
No welds there what i believe when i take my 67 apart.
If you want to hold the pillars in place and have a good feeling with it you can tack them to the rocker in the lower area with some spots, maybe that's easier to continue the work on the outer panel.
-Christian
My 1957 semaphore Single Cab:
http://www.thesamba.com/vw/forum/viewtopic.php?t=605363&postdays=0&postorder=asc&start=0
MY 1967 Sparsamba:
https://www.thesamba.com/vw/forum/viewtopic.php?t=757182
My 1954 Deutsche Bundespost Barndoor:
http://www.thesamba.com/vw/forum/viewtopic.php?t=621802
My 1961 SO34 Flipseat Westfalia:
https://www.thesamba.com/vw/forum/viewtopic.php?t=716285
My 1991 Westfalia California:
http://www.thesamba.com/vw/forum/viewtopic.php?t=650751
