UniBug Samba Member
Joined: January 30, 2024 Posts: 31 Location: Minneapolis, North Carolina
Posted: Wed Mar 20, 2024 11:47 am Post subject: Engine build list for roasting |
Dpr counterbalanced 69mm crank
85,5 Mahle forged pistons and jugs
Dpr ac2 cam
HPMX 40 single carb
Chinese dual port heads
Stock heater boxes running into cleaned out stock muffler
034 dizzy
ChroMo 8mm studs (not “needed” I hear)
New case, drilled tapped
Cb full flow 26mm maxi pump to an external filter
Doghouse cooler and tins
Stainless windage tubes
Koblenschmidt mains rod and cam bearings .25 under
Rebuilt factory rockers
Dpr light weight flywheel
Target static compression ratio 8.4:1
Deck 035
The heads have a pretty decent three angle job on them, but haven’t been flycut to final volume yet.
What’s gonna be my issues?
C. |
UniBug Samba Member
Posted: Wed Mar 20, 2024 11:48 am Post subject: Re: Engine build list for roasting |
Sorry, purpose/application:
67 bug grocerygetter/fire road toy. |
richparker Samba Member
Joined: November 24, 2011 Posts: 6989 Location: Durango, CO
UniBug Samba Member
Posted: Wed Mar 20, 2024 2:10 pm Post subject: Re: Engine build list for roasting |
I get that perspective, but I decided smaller was ok.
C. |
Apostle_ Samba Member
Posted: Wed Mar 20, 2024 2:35 pm Post subject: Re: Engine build list for roasting |
Sounds like a smooth combo. Full balance? |
bcferrini Samba Member
Joined: December 29, 2023 Posts: 60 Location: S F Bay Area
Posted: Wed Mar 20, 2024 2:40 pm Post subject: Re: Engine build list for roasting |
Geeze-as long as you're doing a full new build, why not opt for a 74mm crank and 88mm thick-wall slip-ins. The added torque will be more than noticeable. Builds like a stock motor. _________________ " I measured twice, cut three times, and it's still too short!" |
UniBug Samba Member
Posted: Wed Mar 20, 2024 3:24 pm Post subject: Re: Engine build list for roasting |
Yes, full balance.
I debated engine size a lot, but ended up at a 1600 because I think that’s big enough and I don’t really want to have enough power that my brother can tear it up?
C. |
UniBug Samba Member
Posted: Wed Mar 20, 2024 3:26 pm Post subject: Re: Engine build list for roasting |
I understand that the general samba thing to be make it go faster, I want to also keep it a simple every,an car so my wife/brother/idiot friends can drive it without worrying too much about how hot this or that is.
Modern people ain’t good at that stuff.
C. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9779 Location: Oregon
Posted: Wed Mar 20, 2024 4:36 pm Post subject: Re: Engine build list for roasting |
What rods and rod bearings are you planning on using?
The single HPMX will work, but you'll need intake manifold heat to keep the atomized fuel in suspension all the way to the heads.
A better setup would be a set of dual 40 IDF clones from eBay. I have used them in the past and they work quite well.
For a simple carb setup. Just use a 34 pict3 carb to go with your 034 distributor.
You are correct, everyone here recommends building larger displacement engines.
I have four here. 1600SP, 1600DP, 1679DP and a 2276DP screamer.
The 1600's are dead simple to work on and damn near indestructible. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
UniBug Samba Member
Posted: Wed Mar 20, 2024 5:34 pm Post subject: Re: Engine build list for roasting |
I have a set of oem rods that I checked and balanced. I think they are good enough for this?
I will plan to keep the manifold heat. Thank you!
Charles |
UniBug Samba Member
Posted: Wed Mar 20, 2024 5:36 pm Post subject: Re: Engine build list for roasting |
I will look into my pic 34 options.
I thought about building it up like a low compression class 11, but I don’t think I’ll ever race it competitively enough to have a tear down… |
esde Samba Member
Joined: October 20, 2007 Posts: 5971 Location: central rust belt
Posted: Wed Mar 20, 2024 7:00 pm Post subject: Re: Engine build list for roasting |
A well detailed and thoughtfully built 1600 can drive like a larger motor.
I generally hate tuning single two barrel carbs, because you just reek of gas from changing jets and standing in front of the exhaust. But if you set the heat risers up so one side pulls vacuum, it can work ok. _________________ modok wrote:
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13852 Location: White Mountains Arizona
Posted: Thu Mar 21, 2024 7:12 am Post subject: Re: Engine build list for roasting |
As mentioned the stck 34 pict would be keeping it simple. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
early Samba Member
Joined: January 19, 2012 Posts: 190 Location: Glen Carbon, IL
Posted: Thu Mar 21, 2024 9:10 am Post subject: Re: Engine build list for roasting |
I built a similar engine to this last year.
DPR 69mm CW crank, Flywheel, pressure plate - balanced.
balanced DPR rebuilt rods
DPR AC2 reground Camshaft with -3 indexed cam gear
Mahle cast pistons - balanced to .4 grams
CSP SS muffler
Autolinea DP heads - 50cc chambers
.06 Deck height - 7.7:1 compression
CB aluminum pushrods cut to fit
CB solid rocker shafts with stock rocker arms shimmed to .03 .
i built this as a practice build before my 1835 bus engine that i am working on now.
remember you will have to cut pushrods to fit your rocker arm geometry because the AC2 cam is reground so it has a smaller Base Circle.
i'm running a SOLEX BROSOL H30/31 right now and I'm pretty happy with the way it sounds and runs !
zerotofifty Samba Member
Posted: Thu Mar 21, 2024 9:51 am Post subject: Re: Engine build list for roasting |
Fire roads.... a sand seal pulley should be considered. _________________ Give peace a chance. No American war with Russia! |
Posted: Thu Mar 21, 2024 9:54 am Post subject: Re: Engine build list for roasting |
I have heard that some aftermarket heads may have questionable valve seat install. I have had a shop redo the valve seats on new heads because of this. You dont want a seat to come loose. Sure it is more money up front, but peace of mind is worth it. a loose seat later can be pricey to fix, cheaper to fix now during the build. _________________ Give peace a chance. No American war with Russia! |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9974 Location: Huntington Beach, CA
Posted: Thu Mar 21, 2024 10:26 am Post subject: Re: Engine build list for roasting |
Why a lighter flywheel? Like by how much lighter?
Typical lightened flywheel is like driving, ON…OFF…ON…..OFF. You feel every movement of your foot! Not a great thing going through the neighborhood. But maybe it is what you have in mind.
If it were me, I would stick with a stock flywheel. Way better driving experience, in my opinion. Heck, you could even have just a tiny bit taken off at a machine shop. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
UniBug Samba Member
Posted: Thu Mar 21, 2024 11:23 am Post subject: Re: Engine build list for roasting |
I need to look into a sand seal perhaps. I don’t actually know what one is.
Lightened flywheel becuase thats what I got when I bought the mess of stuff.
Maybe I can find someone to buy the HPMX kit, it’s new in the box? |
rcooled Samba Member
Joined: September 20, 2008 Posts: 2510 Location: Santa Cruz, CA
Posted: Thu Mar 21, 2024 2:54 pm Post subject: Re: Engine build list for roasting |
VW_Jimbo wrote: |
Typical lightened flywheel is like driving, ON…OFF…ON…..OFF. You feel every movement of your foot! |
Not so.
I run a 12.5lb. lightened flywheel w/a counterweighted crank in my Ghia and the clutch/throttle operation is very smooth…not jerky at all. A big advantage of this setup is a noticeably improved throttle response.
There’s very little, if any, noticieable difference in overall driveability/smoothness when compared with the bone-stock 1600 in my Beetle. _________________ '63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
'62, '63, '65, '69 Bugs (all long gone) |
Posted: Thu Mar 21, 2024 3:17 pm Post subject: Re: Engine build list for roasting |
rcooled wrote: |
VW_Jimbo wrote: |
Not so.
There’s very little, if any, noticieable difference in overall driveability/smoothness when compared with the bone-stock 1600 in my Beetle. |
I disagree. My stock 1600 is smooth and the deceleration point after I let off of the accelerator is slow and smooth. No head jerking. In my 2127, with a counterweight crankshaft, H beams and a lightened flywheel, all dynamically balance with the pressure plate, I can whip my head whenever I push or let go of the accelerator. The wife gets into the Bug, buckles up and then rests her head against the head rest (guess it hurt her neck one time). In its defense, it is a very quick accelerating Bug. I cannot floor it because it will break the tires free. And Scott Sebastian from Metal Craft Motorsports told me, when we built the transmission, to NOT allow the wheels to loose traction during take offs. He had a diff that was broken to show me what happens to those poor fools!
Since I have been driving it more and more, I wish that I had just installed a stock flywheel. Oh well, next time. My 2 cents. _________________ Jimbo
TDCTDI wrote: |
