mjust Samba Member
Posted: Tue Apr 16, 2024 4:48 pm Post subject: Re: 73 Super not turning over...with video UPDATE on wording and oil |
mjust Samba Member
Posted: Wed Apr 17, 2024 9:30 am Post subject: Re: 73 Super not turning over...with video UPDATE on wording and oil |
The reading was 11.06 |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31450 Location: Hot Arizona
Posted: Wed Apr 17, 2024 1:32 pm Post subject: Re: 73 Super not turning over...with video UPDATE on wording and oil |
Cusser wrote: |
mjust wrote: |
After it was started and rpm's were raised initially the battery would go from 12.56 to 13 then would slowly start to drop. It was like the battery was suppling power but not getting recharged. |
1. Voltage across battery terminals while at 2000-3000 rpm should be about 13.5 to 14.5 volts if charging system is OK.
2. Voltage across battery terminals while trying to crank/cranking the engine (pull coil wire out for this test) should be over 9.6 volts after about 5 full seconds if the battery is OK. |
mjust wrote: |
"The reading was 11.06". I'm sorry, English is my first language. Was the reading of 11.06 in response to Test 1 above or Test 2 ?????? _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
mjust Samba Member
Posted: Wed Apr 17, 2024 3:08 pm Post subject: Re: 73 Super not turning over...with video UPDATE on wording and oil |
Sorry
Test 1: 12.6
Test 2: 11.06 |
mjust Samba Member
Posted: Tue Apr 23, 2024 10:55 am Post subject: Re: 73 Super not turning over...with video UPDATE on wording and oil |
Going to replace the generator. Will let you know if that does the trick. |
Cusser Samba Member
Posted: Tue Apr 23, 2024 11:37 am Post subject: Re: 73 Super not turning over...with video UPDATE on wording and oil |
mjust wrote: |
Sorry
Test 1: 12.6
Test 2: 11.06 |
mjust wrote: |
Well - it definitely is not charging. However, there is a straightforward test to determine whether generator or voltage regulator is at fault:
https://speedyjim.net/htm/gen.htm _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
mjust Samba Member
Posted: Fri Apr 26, 2024 4:55 pm Post subject: Re: 73 Super not turning over...with video UPDATE on wording and oil |
Having a really hard time removing that pulley from the old generator. At this point I think its not going to come off. Can you buy one? |
Cusser Samba Member
Posted: Fri Apr 26, 2024 6:21 pm Post subject: Re: 73 Super not turning over...with video UPDATE on wording and oil |
mjust wrote: |
Sure, new pulley can be purchased, like https://www.jbugs.com/product/043903109.html
But if you cannot remove the pulley (try Autozone loaner gear puller), you'll need a brand-new woodruff key for your new generator.
https://www.jbugs.com/product/N127051.html
Getting a generator pulley off is typically way simpler than a generator replacement job will be - are you up to such task? And I haven't seen any pictures, so we're taking your word that you have a generator and not an alternator.
But - did you run the tests from Speedy Jim's page about determining that generator is bad or voltage regulator is bad like I posted earlier????? Or are you just going to throw a new generator on it and hope????? _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
mjust Samba Member
Posted: Sat Apr 27, 2024 1:34 pm Post subject: Re: 73 Super not turning over...with video UPDATE on wording and oil |
Yeah, we are just going to throw $$ at it and got a new generator. Slowly but surely we will have a new engine. The AutoZone loaner is a great idea! Already ordered a new one but will actually try that as well. |
mjust Samba Member
Posted: Wed May 08, 2024 7:48 am Post subject: Re: 73 Super not turning over...with video UPDATE on wording and oil |
Just a little update. We replaced the generator over the weekend and the car started right up and is holding a charge for the last few days. While it was a pretty straight forward job getting that nut off the fan was crazy hard. We both have bruises on our forearms from reaching behind the fan. Now on to the insanely bad gas smell. |
Cusser Samba Member
