txoval Samba Member
Joined: January 23, 2004 Posts: 3556 Location: The Woodlands, TX
Posted: Fri Mar 22, 2024 2:33 am Post subject: Re: Installing engine and transaxle as one unit |
I agree and have never done it, or even thought about it.
b-man wrote: |
txoval wrote: |
An IRS beetle wouldn’t be bad…swingaxle forget about it |
It wouldn’t be bad at all.
It would be worse than bad. It would be a horrible choice to attempt that and would make absolutely no sense. |
gtixpress Samba Member
Joined: June 22, 2006 Posts: 283 Location: Mahomet, IL
Posted: Fri Mar 22, 2024 5:19 am Post subject: Re: Installing engine and transaxle as one unit |
It's actually recommended to pull it out as a unit in Type 3's with IRS, per the manual. It's just an awkward process in trying to keep it balanced. _________________ Joe P.
1969 VW Type 3 Squareback
2002 VW GTI 337 (Limited Edition)
2018 VW Atlas SE VR6 4Motion
2019 VW Beetle S Final Edition Convertible |
MarcVoss Samba Member
Posted: Sat Mar 23, 2024 3:04 am Post subject: Re: Installing engine and transaxle as one unit |
gtixpress wrote: |
It's just an awkward process in trying to keep it balanced. |
Yes, but this tool will help.
So, engine and transaxle will keep in balance.
But, of course, a second pair of hands will help during moving.
_________________ Best Regards from Germany, the origin country of Volkswagen.
Marc |
b-man Samba Member
Posted: Sat Mar 23, 2024 9:26 am Post subject: Re: Installing engine and transaxle as one unit |
On a car that’s designed to install the engine and trans as a unit it’s a no-brainer.
I balanced this Buick V6 bolted to the transaxle using a KEP adapter on a regular floor jack by simply using a piece of 2x10 wood and stuck it in there by myself. I performed this swap when I was 19 back in 1979.
At first I thought it was strange seeing there weren’t any frame horns to support the transaxle since I had never owned a VW built like that. It did make the installation of the engine and trans pretty easy, doing them together was how the job was meant to be performed.
_________________ 1956 Dove Blue Panel
1966 Velvet Green Single Cab
1957 L41 Black Oval Window Beetle |
nsracing Samba Member
Posted: Mon Mar 25, 2024 7:57 am Post subject: Re: Installing engine and transaxle as one unit |
so -someone wants to do them both same time?
I do Ford trucks like that - engine and trans same time. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76963 Location: Sneaking up behind you
Posted: Mon Mar 25, 2024 7:59 am Post subject: Re: Installing engine and transaxle as one unit |
nsracing wrote: |
So what does that have to do with VW?
Apples and bowling balls. _________________ Glenn
Member #1009
#BlueSquare |
