cletus_zuber Samba Member
Joined: January 08, 2010 Posts: 2409 Location: Gladstone, Ore
Posted: Mon Mar 18, 2024 7:23 pm Post subject: Re: 74 Bug value help |
just be a bigger a**hole to the neighbor and maybe he'll move. _________________ 1972 1302
HPMX 40's & 019 |
rusty_74_bug Samba Member
Joined: November 22, 2019 Posts: 321 Location: Vancouver, WA
Posted: Mon Mar 18, 2024 7:44 pm Post subject: Re: 74 Bug value help |
cletus_zuber wrote: |
just be a bigger a**hole to the neighbor and maybe he'll move. |
I actually tried. Didn't work. Not risking legal problems...he wins. I'm too much of a nice guy anyways _________________ '74 Standard Bug |
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4429 Location: Stuck in Ohio
Posted: Mon Mar 18, 2024 8:14 pm Post subject: Re: 74 Bug value help |
Buggeee wrote: |
There's plenty of bugs out there. Take the vett money, the bug money, land in a safe spot and wait for next aircooled to arrive. That's how it works. It will find you! Ha Ha |
Yep, that's the plan! _________________ '74 Standard Bug |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9977 Location: Huntington Beach, CA
Posted: Mon Mar 18, 2024 11:25 pm Post subject: Re: 74 Bug value help |
Around here, 1500 to 3500 _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
OTTO 1303 Samba Member
Joined: March 17, 2020 Posts: 638 Location: Louisiana
Posted: Tue Mar 19, 2024 7:01 am Post subject: Re: 74 Bug value help |
rusty_74_bug wrote: |
Buggeee wrote: |
Yep, that's the plan! |
Good plan
Good Luck _________________ 74 Super Sun Bug - OTTO
74 Super - DANZIG
74 Super - HERZOG |
Starbucket Samba Member
Posted: Tue Mar 19, 2024 7:07 am Post subject: Re: 74 Bug value help |
It will help to get pictures of the pan, it it's not rotted through $2500. |
Posted: Tue Mar 19, 2024 7:12 am Post subject: Re: 74 Bug value help |
Starbucket wrote: |
I'm sure it's not perfect but I also don't see any huge holes _________________ '74 Standard Bug |
Posted: Tue Mar 19, 2024 8:30 am Post subject: Re: 74 Bug value help |
Starbucket wrote: |
I'm sure it's not perfect but I also don't see any huge holes |
Just curious, aren't the pans one of the most common rust problem with these Bugs?
So it shouldn't be surprising and almost expected? I guess it depends on where the car spent most of its life. _________________ '74 Standard Bug |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76977 Location: Sneaking up behind you
Posted: Tue Mar 19, 2024 9:19 am Post subject: Re: 74 Bug value help |
Starbucket wrote: |
So it shouldn't be surprising and almost expected? I guess it depends on where the car spent most of its life. |
Based on the extensive at the rear window, I would be surprised if there's not rust/rot other places. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Tue Mar 19, 2024 9:31 am Post subject: Re: 74 Bug value help |
Glenn wrote: |
Starbucket wrote: |
Based on the extensive at the rear window, I would be surprised if there's not rust/rot other places. |
I'm sure you're right there's rot in other places...it is a 50 year old car. I am curious about what you're referring to on the rear window?? I just went out and took some more pics and will upload in a new comment shortly. _________________ '74 Standard Bug |
Posted: Tue Mar 19, 2024 9:42 am Post subject: Re: 74 Bug value help |
Are you referring to the gunk around the window seal and the seal itself? I pulled back the insulation on the inside as far as I could without damaging it. I don't see any rust or rot. I can't confirm in the storage area without ripping up that carpet which I don't want to do.
I know this bug spent a few years outside under some trees in the PNW (I actually found out who owned it before based on some stuff left in the car and contacted them. If I remember correctly, the lady drove it as a daily driver until sometime in 2012. BTW, she was an actual hippie )
Glenn Mr. 010
Posted: Tue Mar 19, 2024 10:46 am Post subject: Re: 74 Bug value help |
This stuff.
Rot/rust is an iceberg, you are only seeing 10%, there's 90% you can't see. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Tue Mar 19, 2024 10:57 am Post subject: Re: 74 Bug value help |
Glenn wrote: |
This stuff.
Rot/rust is an iceberg, you are only seeing 10%, there's 90% you can't see. |
Ah yep. Well I mentioned it in my ad as well as pictures. Up to interested party if they think my asking price is worth it to them I guess. Like I said in my original post, I don't want to screw over anyone, just want best I can get. The '74 super I sold in '22 had the death foam problem and its hole was a million times worse...it was huge. Speed holes i guess _________________ '74 Standard Bug |
Blue Baron VW Aficionado
Joined: June 16, 2006 Posts: 24167 Location: Southeast USA
Posted: Tue Mar 19, 2024 11:54 pm Post subject: Re: 74 Bug value help |
It's a common rust area on '70s Beetles due to the foam insulation used by the factory. I've seen this section rusted from the inside out on otherwise solid cars. _________________ We are striving for perfection, to make our cars run forever, if possible.
Heinz Nordhoff |
Posted: Wed Mar 20, 2024 4:54 am Post subject: Re: 74 Bug value help |
Blue Baron wrote: |
It's a common rust area on '70s Beetles due to the foam insulation used by the factory. I've seen this section rusted from the inside out on otherwise solid cars. |
Yep. The 74 Super I had then sold a couple of years ago had it really bad on the passenger side. Like REALLY big hole. Luckily the guy that bought it didn't care because he was doing a full restore on it. _________________ '74 Standard Bug |
Posted: Tue Apr 02, 2024 2:56 pm Post subject: Re: 74 Bug value help |
So the ad has been up a couple weeks...getting tired of the obvious scammers and not so obvious ones. I talked to the boss lady and looks like I'm gonna keep Bumblebee (yes, that's what I named it ) for now and hope I can get a little more for the Vette. Even if I sold it for what I wanted it wouldn't make much of a dent in our $$$ goal anyways so I might as well keep her. Going to deactivate the ad now. _________________ '74 Standard Bug |
