burro_gordo Samba Member
Joined: March 12, 2024 Posts: 2 Location: Mojave River Valley, California
Posted: Mon Mar 18, 2024 11:45 am Post subject: Wiring - Oil pressure light |
First time poster here-
What is the best way to fish a wire from under the rear seat into the engine compartment? At some point in this bug's life, the wire from the Oil Pressure Light was lost.
Here's what I know:
Somewhere between the engine compartment and under the rear seat, all* of the wires have been cut and replaced with white wires. *all except the Oil Pressure Light wire.
There are 7 wires in the rear, only 6 out of the firewall.
Best I can tell, the blue Oil wire makes it to the rear.
03/19/2024 Update:
I was able to fish a new wire through the body using some #12AWG Solid wire as a 'fish tape'. I went in from the engine compartment and down to the access hole inside.
Thanks for your comments!
busman78 Samba Member
Joined: August 17, 2004 Posts: 4525 Location: Oklahoma City, OK
Posted: Mon Mar 18, 2024 1:41 pm Post subject: Re: Wiring - Oil pressure light |
Use one of the white wires to pull a string back into the vehicle, best way is to solder or crimp a wire to the pull wire, don't want is breaking off half way through. Attach the wire or wires you want to go back to the engine compartment and use the string/wire to pull them through. Be a good time to do a little wire color coding. |
slayer61 Samba Member
Posted: Mon Mar 18, 2024 2:58 pm Post subject: Re: Wiring - Oil pressure light |
busman78 wrote: |
And, use a little dish soap. _________________
Cusser wrote: |
... Most folks are idiots when it deals with electrical !!! |
67rustavenger wrote: |
3/4 race cam? What's missing, one of the lobes? |
Paul
'68 Manx clone... Sears??
2276 built on AS21 case
W-125 w/ GB 1.25:1 rockers
Mahle forged pistons
CB 4340 crank
CB H beam rods
deep sump
44 HPMX
EMPI GTV 2 STG II wedge ports
CB Magna spark
1 5/8 merged collector w/ hater stinger |
Posted: Wed Mar 20, 2024 1:35 pm Post subject: Re: Wiring - Oil pressure light |
Update:
Thanks for your comments! |
