90mm 12V generator conversion questions
drksderob
drksderob is offline
PostPosted: Sat Mar 16, 2024 7:12 am    Post subject: 90mm 12V generator conversion questions Reply with quote
I have a 1956 Oval. Its been off the road for 7 years. I want to get it back on the road this year for 2 reasons. To enjoy it with my young family and to let my grandfather drive it. He was my citys very first VW technician in the early fifties and has said he would like to drive a beetle again. This is my mission now. The only thing holding me back is this generator. Its a 90mm 6V body and I bought this kit from ebay https://www.ebay.ca/itm/283701690294?itmmeta=01HS3...5DbuvnIYw.
My problem is that when I fit it all together it seems very tight still and rubs. Im looking for advice, install videos or pictures...really anything to help. The windings seem too thick and rub on the armature. Thanks for reading.
oldslow
oldslow is offline
PostPosted: Sat Mar 16, 2024 8:27 am    Post subject: Re: 90mm 12V generator conversion questions Reply with quote
You need something like a tailpipe expander. Compress the coils in place, and while expanded tighten the big screws on the side. Trying to tighten with the screws alone won’t get it done.
- better to drive a slow car fast than fast car slow -
drksderob
PostPosted: Sat Mar 16, 2024 12:05 pm    Post subject: Re: 90mm 12V generator conversion questions Reply with quote
You know what? I think you may be right. I tried a expander but not at the same time as trying to screw the plates tighter. I compressed, removed the tool and tried. Ill try it tonight. I hope youre right.
Thanks,
Rob
Robert Chambers
Robert Chambers is offline
PostPosted: Tue Mar 19, 2024 1:51 pm    Post subject: Re: 90mm 12V generator conversion questions Reply with quote
I used the same conversion kit. I did the same thing on my generator using my small tail pipe expander. It worked perfectly. Good luck!
'63 OG 117 Herbie Replica
'56 Euro Oval Deluxe
'52 Standard Zwitter
'63 OG 117
